    Point Clouds - Point Cloud Transformation - Rotations ???
    2 Posts 2 Posters 277 Views 2 Watching
    • H
      Howard leslie
      In the Point Cloud Manager there is a Point Cloud Transformation Panel showing X, Y, Z offsets for the Point Cloud that is loaded into the SketchUp file.
      These offsets can be viewed and also edited here - which is great.
      What about Rotations ???
      Would be great to see Rotations (ie degrees) about the X,Y,Z axes also - so that they can be viewed and edited
      Is this possible ???
      I'm aware that the point cloud can be rotated with rotation tool - but it would be great if u could see what the rotations are and edit them
      Editing all this data in dialog boxes is great because it allows fine adjustment and also allows you to save the settings if reqd
      Any help would be much appreciated
      Regards
      Howard L'
        I presume you have looked at udnet?
        SketchUp point cloud plugin to create 3D models from scan data | Undet
        A feature-rich SketchUp point cloud plugin for fast & easy scan data import from any 3D laser scanner, UAV drone or photogrammetry software.
        UNDET (www.undet.com)
        It's pricey at 500/yr but there is a trial for 14days.
        I'd watch the videos first to see what transforms it can do.
