    Multiple overlapping faces
    3 Posts 3 Posters 178 Views 3 Watching
    • H Offline
      hofofo
      Hello, I have a problem that repeats itself in all versions since 2020.
      Sketchup produces multiple overlapping faces when the face is edited
      After a lot of effort and research, I found that the only solution for this is by moving the entire model each time to the origin of the axes in the area I am working on in the model - something that greatly delays the work. Very frustrating - I’d appreciate it if someone has another solution to this frustrating problem. Thanks
        If geo is far from world origin you will run into clipping issues. Are you seeing extra geometry or graphical artifacts? Because both are different issues.
        Sounds graphical. Is your issue similar to this?
        https://i.imgur.com/PPtOX5D.png
        You can see my scene is 5km long and the problem area has geometry separated in Z by 5cm
        https://i.imgur.com/zAJkzYt.png
        SketchUp cannot render the small distance whilst also considering the scene scale. SketchUp doesn't expose the camera clipping values to the user but Sam Tallet's Clipping Fix does try...
        Clipping Fix | SketchUcation
        (sketchucation.com)
        ...but its a problem in 3D in general. A camera needs to have bounds. When you want to to see extrememly close and extremely far you hit the clipping issue.
          Share the model file so we can see what you're working with.
