    How to use Fredo tools offline?
    19 Posts 4 Posters 1.7k Views 4 Watching
    • G
      goldkeyequipment Newcomers
      To use Fredo Tools offline, you would need to have already installed the necessary software or plugins on your computer. Once the tools are installed, you can typically use them without an internet connection.
      However, it's important to note that some functionalities or features may require occasional online connectivity, such as initial installation, updates, or license verification.
      Therefore, it's recommended to check the specific documentation or user guides provided by Fredo Tools to understand the offline capabilities and any potential limitations of the tools you are using.
        j_jones
        @rich o brien said:
        @j_jones said:
        Everything is looking better now seems I can work offline. Thank you so much! ❤️
        Great, just try and keep on top of your extension updates and you should be ok.
        If you https://sketchucation.com/webshop/my-licences.php page doesn't allow releasing then those devices are running the older license system.
        Glad it's sorted. 👍
        I'm sorry to report the problem has returned without any explanation...
        Here's the output of Window->Libfredo Settings -> Fredo6 Plugins Information for Sketchucation Support
        Fredo6 Plugins Information on 2023-07-30 19;43;17 -0700
        - Platform; x86_64-darwin14 - Ruby; 2.2.4
        - Sketchup; 17.3.116
        - LibFredo6; v13.9a
        - LibFredo6 Binary loaded
        - Sketchucation ExtensionStore; 4.3.1
        - SCFLicense; v6.1a - 72
        - Fredo6 Plugins
            > TopoShaper v2.6a - licensed FULL
            > ToolsOnSurface v2.5a - licensed FULL
            > Curviloft v1.9a
            > FredoTools v4.3a
            > FredoGuides v2.4a
            > FredoSketch v1.2a
            > JointPushPull v4.6a - licensed FULL
            > Curvizard v2.4b - licensed FULL
            > FredoScale v3.5a - licensed FULL
            > ThruPaint v2.2a
            > FredoPortrait v2.8a
            > RoundCorner v3.3a - licensed FULL
            > VisuHole v1.4b - licensed FULL
            > FredoGhost v2.0a
            > FredoCorner v2.6a - licensed FULL
        - SCFLicense directory present
            > Signature File; 2022-06-29 18;42;44 -0700
            > Curvizard; 2023-07-03 12;35;06 -0700
            > JointPushPull; 2023-07-03 12;34;56 -0700
            > ToolsOnSurface; 2023-07-03 12;34;29 -0700
            > VisuHole; 2023-07-03 12;35;58 -0700
            > RoundCorner; 2023-07-03 12;35;50 -0700
            > TopoShaper; 2023-07-03 12;34;17 -0700
            > FredoCorner; 2023-07-03 12;36;19 -0700
            > FredoScale; 2023-07-03 12;35;14 -0700
        Launching the Extension Store, the window title shows 4.3.1
        What is the problem now I wonder?
          Update your Libfredo.
          SketchUp Plugins | PluginStore | SketchUcation
          SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
          (sketchucation.com)
            j_jones
            (sketchucation.com)
            Ah! Thank you sir! I'm updated to LibFredo6: v14.1a
            Hope that'll do it, thanks again
              j_jones
              It's happening again, this time I can't even use the tool even if I validate the license!
              Everything was fine for a while but now it says I can't use Curviloft. So, I go online, reactivate the license, but as soon as I try to use it again, it says it's invalid....
              not again
              After validating the license through the web, I turn of the wifi off again
              license never satisfied
              But as soon as I try to use the tool, again, the same error, as above....
              I can't use the tool at all now...
              Here is the output of the Fredo plugins information
              Fredo6 Plugins Information on 2023-09-06 17:34:45 -0700
              • Platform: x86_64-darwin14 - Ruby: 2.2.4
              • Sketchup: 17.3.116
              • LibFredo6: v14.1a
              • LibFredo6 Binary loaded
              • Sketchucation ExtensionStore: 4.3.1
              • SCFLicense: v6.1a - 72
              • Fredo6 Plugins
                Curviloft v1.9a - licensed FULL
                FredoTools v4.3a
                FredoSketch v1.2a
                Animator v3.8a
                ThruPaint v2.2a
                FredoPortrait v2.8a
                FredoGhost v2.0a
                FredoCorner v2.6a
                Signature File: 2022-06-29 18:42:44 -0700
                Curvizard: 2023-07-30 19:53:00 -0700
                JointPushPull: 2023-07-30 19:52:44 -0700
                ToolsOnSurface: 2023-07-30 19:52:12 -0700
                VisuHole: 2023-07-30 19:54:11 -0700
                Curviloft: 2023-09-06 17:33:49 -0700
                RoundCorner: 2023-07-30 19:53:54 -0700
                TopoShaper: 2023-07-30 19:51:46 -0700
                FredoScale: 2023-07-30 19:53:14 -0700
              Thank you for any help
              -j_jones
                j_jones
                now the crazy thing is appeased somehow, probably because I posted about it!
                Don't know how long it will behave though...
                  It could be that your running Libfredo 14.1 and its recently updated to 14.2
                  I need to check with Fredo to see if something changed that could cause this to happen.
                    j_jones
                    @rich o brien said:
                    It could be that your running Libfredo 14.1 and its recently updated to 14.2 ...
                    Thank you again! I updated LibFredo and hopefully no more issues...
                      Until 14.3 😳
                      We are working on a better prompt for helping users to update necessary extensions.
                        rtrowski Newcomers
                        Glad it's sorted. 👍
                        I'm having an issue releasing licenses on my 3 seats. I use a virtual desktop from VMware for work and I had assumed it was because the computer "wipes" itself every night. Is there any other way I can release these seats?
                          I released your seats. Please make sure your devices are running Sketchucation Tools 4.3 and Libfredo 14+
                          Once you have those you can manage seats at https://sketchucation.com/webshop/my-licences.php
