    Irregular hexagon drawing
    11 Posts 4 Posters 1.1k Views 4 Watching
      krunge11
      Hey!
      This is my first post here. I have been working with SketchUp about 6 years- mostly on hottubes and tubesaunas. Today i find something interesting in my office and now i´m in trouble. I can´t find out how can i draw those hexagons You see on picture. They are irregular (sort off), red sides is same legth and angle (120°), green sides also same length (but not same length as red sides). Same storu with yellow sides- they have same length but not same length as other color sides. Those pieces glued into plywood as tiles and as You can see they fit perfectly side to side and top-bottom. I think i need some mathematical or geometrical knowledge to draw those pieces in SketchUp. I have Trilateration plugin so i can make perfect triangles, but how to do it so they fit as on the picture?
      Any help would be greatly appreciated! Sorry for my english.
      Indrek.
        All internal angles must total 720d.
        But if you know the lengths of each green and red edge can you get the length of the base. If you could then you can work out the angle
        https://i.imgur.com/7iaBZjf.png
        Then use some online tool to calculate the angles...
        https://www.omnicalculator.com/math/triangle-angle
        https://i.imgur.com/GDuHL4G.png
        A hexagon is a triangle with 3 triangle attached the each edge...
        https://i.imgur.com/nyDo5ZB.png
        There's likely a very simple solution to this but my brain is too smooth to see it yet.
        • Gus RG Offline
          Gus R
          Something like this?
          www.instagram.com/gusrobatto/
          www.facebook.com/gusrobatto
          • Gus RG Offline
            Gus R
            Get the "Random Tools" extension either from here or using Extension Warehouse in Sketchup.
            I did this flat on the ground or a top view.
            Create a hexagon pattern like this.
            Select all and click the second icon (Random Vertex Positions) in the Random Tools menu.
            Apply something like the following setting. You may have to play with it depending on the size and units of your model.
            Results.
            You should be able to take it from there by adding random texture positions, border elements, etc.
            • Gus RG Offline
              Gus R
              You can dimension them all as needed and send it to your carpenter from there.
              • Gus RG Offline
                Gus R
                I should mention that the hexagons are simply circles drawn with six (6) sides. If you're not familiar that's done by entering 6S (six "s" as in Sam) in the units field.
                • Gus RG Offline
                  Gus R
                  Thea Render in Presto with 512 passes.
                    I thought the original query was that they have this irregular hexagon shape that fits together in a certain pattern?
                    • Gus RG Offline
                      Gus R
                      I don't know. 💚
                      • U Offline
                        unearthed
                        I wanted an irregular but repeatable tile recently and ended up using type 4 from here. I wanted to cut shapes from concrete waste, so I wanted a shape with not too tight angles to reduce breakage and simplify handling.
                        Angles amd tile variations here: page 15 https://arxiv.org/pdf/1708.00274.pdf
                        type 4 tile Growplan.JPG the dots are a visual guide for drawings to help place tiles.
                        Growplan - People ∩ Plants ∩ Place
                        windows 7 64b, 4GB RAM, SU 8.0.16846
                        Gimp, QGIS, Vectorworks 12, Bricscad 11
                          krunge11
                          Hey!
                          Thanks for You effort. Maybe i didn´t explain myself very correctly. All those irregular hexagons in tile is exactly the same. But they fit if You take same tile and place it on the side or top. I think i have to try this 3 triangle solution mentioned here. I also find some intresting pages from internet.
                          Thank You,
                          Indrek
