    Random rotate on different axis x,y,z
    5 Posts 2 Posters 239 Views 2 Watching
    • alexpacio2013A Offline
      alexpacio2013
      Random rotate on different axis x,y,z simultaneously there is a plugin
      example, the numbered balls of a billiard table.
      All the plugins I've tried rotate one axis only
      • Rich O BrienR Online
        Install TIG's Free Rotate
        https://i.imgur.com/03GPtTF.png
        https://i.imgur.com/ZLpbqg8.png
          alexpacio2013
          I meant to select a series of objects, set the maximum degrees of random rotation for each axis and execute the command at the same timeSenza titolo.png
            Pixero's Chaos ??
            https://i.imgur.com/7vJo1W1.png
            You'll need to run it per axis
              alexpacio2013
              @rich o brien said:
              Pixero's Chaos ??
              However, only one axis works at a time. And I couldn't block the move?
