    Alphabet to sketch(up)
    208 Posts 7 Posters 54.8k Views 7 Watching
    • ntxdaveN
      ntxdave
      I have looked through it many times and find it very inspiring. I would recommend it to anyone who enjoys sketching! 👍 👍
      Press F1...thank me later
      • majidM
        majid
        I am overwhelmed and appreciate your support. 👍 👍
        I am more than happy that you have found it inspiring.
        Due to my experiences, creativity is a state of mind that one may get used to. I hope you find it inspiring during your creative process.
          Moving on a bit.
          The 'A' frame crossed to form four arms, to which apartments are attached, I know, not all the supporting framework is in place. Just sorting out the lie of the land.
          Viewed from the top, the 'X' will be evident while decor on the outside of the apartments will initially be the 'E'.
          I need to work out where the bungee cords, sorry, lifts and stairs will go but probably two of each.
          • majidM
            majid
            You are developing your personal style!
            I am happy to see that the book's essence - inspiration and creativity- has transferred.
              That is meant to be a whatif of apartments, a little craziness if you will. There is a central lift shaft etc but no stairs yet, or ever perhaps.
              The fire escape method consists of a bungee cord system and the user just steps out of the building wearing the harness.
              They will of course have to unclip the harness the moment their feet touch the ground and it could get messy if there is anyone above you when that happens. You might also need an umberella in that case too.
              No, it rhymes with Mooo.
              • ntxdaveN
                ntxdave
                Wow, makes me feel old fashion with one I am working on. This one is “out there”. 👍 👍 👍
                  Ta mate, I think I am l;eaning towards a prefabricated unit setup where the frame is universal and the units are the alphabet.
                  Pardon the intrusion, the Badgers are here for supper so I popped out to deliver commestibles.
                  I reckon prefab units have a lot going for them when done right, seen a fair bit about Huf ( https://www.huf-haus.com/en-uk/ ) designs about the interweb and on Grand Designs where they appeared to be pretty good value for money etc.
                  Using a skeleton would possibly just be extending this idea a bit further so, rather like a bridge idea.
                  Services could be an issue, anyone have any thoughts on that? Possibly extend the alphabet to include units for this within a framework?
                  • majidM
                    majid
                    Combining the ideas is highly welcomed ( in creativity )!
                    To solve the service question you may see the similar vertical tower projects and see how they have solved it. Alternatively, you may solve it by breaking the question down: The question is getting up from one level to another. So just adding an stair case to each unit, then a short path to the next stair case might be a solution. Also you may consider it as a futuristic project where all commuting is by drones...!
                    Here is a personal project example:
                    Final
                      When I was in school, a LOooooong time ago, it was predicted that less than ten percent of us would even leave home to work (By 2020) so commuting, would be history.
                      Yeah well that worked out, right?
                      Seriously, what can we expect in the future? City sized tower blocks where all ammenities are available on each level, like a termite mound? Where people do not need to leave their partucular level?
                      If this means we can landscape the rest and remove the majority of human detritus, I am all for it.
                      By this time I should think we will have clean energy and be able to run homes much more efficintly or, so I would hope. We m,ight even have a Scott me up beamy working.
                      • ntxdaveN
                        ntxdave
                        @mike amos said:
                        When I was in school, a LOooooong time ago……..
                        Not as long ago as me I am sure………. 😍
                          I left school in 1975 so a fair while ago mate.
                          • ntxdaveN
                            ntxdave
                            I graduated high school in 1959! After getting out of the Army I went to college (night school - took several years while working over 40 hours per week) and graduated in 1976! 😄 At least I finally graduated. 😄
                            • majidM
                              majid
                              Your debate is really motivating to me. 👍
                              P.S : Sorry for my English, Your chatting about the age is inspiring.
                              • ntxdaveN
                                ntxdave
                                What detate?
                                • majidM
                                  majid
                                  Modified my post.
                                  • ntxdaveN
                                    ntxdave
                                    Sometimes age is somewhat of a defining factor in the thought process. 😲
                                    I am still playing with the “X” building and hope to be able to share it soon (been dealing with some other things). It is not as “modern” or as “far out there” as you guys come up with but I hope you guys will like it. 😄
                                      I find your designs very motivating tbh, more organic than mine which are more an exercise in simple graphics.
                                      Different styles and all that which is what this place really does bring out into the open.
                                      As far as being 'out there' goes, spoke to my ex recently and she thought I was on the way back from 'there'.
                                      I know, friends eh?
                                      More thoughts on the way but looking forwards to the 'X', it is going to be good mate.
                                      • majidM
                                        majid
                                        As far as I know, a very important key factor in the design process is "developing".
                                        Develop a simple idea and it turns out to be a master-piece, or leave it "unripe" and it will spoil even if it is a wonderful idea.
                                          Sorry mate, I cannot see that.
                                          • ntxdaveN
                                            ntxdave
                                            OK guys, here are some quick renders of the "X" building I have been/am working on. There are a bunch of things I am not happy with but thought I would at least let you know that I am still working on it. It might be a little while before I finish.
                                            Having some issues with the model:
                                            • Placing windows on the octagonal shaped buildings. As you can see, some of them I have not even gotten to yet.
                                            • Need to redo the foliage.
                                            • Not happy with the roofing.
                                            • Thinking about making the passage between the buildings different (several ideas).
                                            • Not happy with the background image but do not have a better one to use. 😞
                                            So, here are the quick renders:
                                            • 11
                                            • 8 / 11
