[Plugin Library] LibFredo6 - v14.6a - 18 Sep 24
The current version of the SketchUcation toolset [and therefore the licensing system] is 4.3.1
Update to that using the ExtensionStore³ and restart SketchUp... -
Well, I've done this:
- Uninstalled SketchUp and all plugins
- Cleaned registry and checked no left folders were forgotten
- Restarted
- Installed SU 2022
- Installed SketchUcation Extension Store 4.3.1
- Installed LibFredo6 and JointPushPull
...and the same issues: got to double click in Fredo6 plugin buttons to work and when I press on License... button, nothing happens. I'm really lost
I get this in "View Trace log files":
>>>> 1690819617.4827344;top_libfredo6.rbe;171; in `open' DATE / TIME; 2023-07-31 17;06;57 +0100 SKETCHUP VERSION; 22.0.354 RUBY_PLATFORM; x64-mswin64_140 LOG FILE; LibFredo6Trace_22_1690819617466.txt >>>> 1690819617.4824693;top_libfredo6.rbe;171; in `open' LibFredo6; Starting up Fredo6_!LibFredo6.rb >>>> 1690819617.4833517;top_libfredo6.rbe;171; in `open' LibFredo6 Root top directory; C;/Users/Javi/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins >>>> 1690819617.4867444;top_libfredo6.rbe;171; in `open' APPDATA Sketchup directory; C;/Users/Javi/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles >>>> 1690819617.4884648;top_libfredo6.rbe;171; in `open' Temp Files directory; C;/Users/Javi/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles >>>> 1690819617.4887896;top_libfredo6.rbe;171; in `open' LibFredo6 Data directory folder; C;/Users/Javi/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/LIBFREDO6_DATA_Dir >>>> 1690819617.4891112;top_libfredo6.rbe;171; in `open' Default Parameters folder; C;/Users/Javi/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/LIBFREDO6_DATA_Dir/DefaultParameters >>>> 1690819617.489658;top_libfredo6.rbe;171; in `open' LibFredo6; Beginning of loading Cycle***+ >>>> 1690819617.498;top_libfredo6.rbe;171; in `open' LibFredo6 Core; Fredo6_!LibFredo6/Lib6Core successfully loaded >>>> 1690819617.5130002;top_libfredo6.rbe;171; in `open' LibFredo6 14.1a; Effective Load - #0 >>>> 1690819617.6435053;top_libfredo6.rbe;171; in `open' LibFredo6 14.1a; Ruby files loaded [128 ms] >>>> 1690819617.69337;top_libfredo6.rbe;171; in `open' add Command Set Preferred Languages... >>>> 1690819617.7229025;top_libfredo6.rbe;171; in `open' add Command Check Fredo6 Plugins for Update... >>>> 1690819617.7235732;top_libfredo6.rbe;171; in `open' add Command Purge Obsolete files... >>>> 1690819617.724171;top_libfredo6.rbe;171; in `open' add Command Performances... >>>> 1690819617.7247324;top_libfredo6.rbe;171; in `open' add Command View Trace log files... >>>> 1690819617.7253218;top_libfredo6.rbe;171; in `open' add Command About LibFredo6 v14.1a... >>>> 1690819617.7258954;top_libfredo6.rbe;171; in `open' add Command Fredo6 Plugins Information for Sketchucation Support >>>> 1690819617.729547;top_libfredo6.rbe;171; in `open' add Command Plugin Information [Sketchucation]... >>>> 1690819617.7304456;top_libfredo6.rbe;171; in `open' add Command Default Parameters... >>>> 1690819617.731032;top_libfredo6.rbe;171; in `open' add Command Language Translation... >>>> 1690819617.7316;top_libfredo6.rbe;171; in `open' LibFredo6 14.1a; Startup (creating menus and icons) [87 ms] >>>> 1690819617.7360392;top_libfredo6.rbe;171; in `open' Found valid plugin; JointPushPull >>>> 1690819617.7437222;top_libfredo6.rbe;171; in `open' Plugin to Load [0]; ["JointPushPull", "Fredo6_JointPushPull"] >>>> 1690819617.762328;top_libfredo6.rbe;171; in `open' JointPushPull 4.7a; Effective Load - #1 >>>> 1690819617.7658203;top_libfredo6.rbe;171; in `open' JointPushPull 4.7a; Bootstrap Ruby files loaded [3 ms] >>>> 1690819617.7719476;top_libfredo6.rbe;171; in `open' add Command Quick Launcher... >>>> 1690819617.773006;top_libfredo6.rbe;171; in `open' add Command Thickener >>>> 1690819617.774016;top_libfredo6.rbe;171; in `open' add Command Joint Push Pull >>>> 1690819617.7750082;top_libfredo6.rbe;171; in `open' add Command Round Push Pull >>>> 1690819617.7760384;top_libfredo6.rbe;171; in `open' add Command Vector Push Pull >>>> 1690819617.7770388;top_libfredo6.rbe;171; in `open' add Command Normal Push Pull >>>> 1690819617.77803;top_libfredo6.rbe;171; in `open' add Command Extrude Push Pull >>>> 1690819617.779052;top_libfredo6.rbe;171; in `open' add Command Follow Push Pull >>>> 1690819617.7800918;top_libfredo6.rbe;171; in `open' add Command About JointPushPull v4.7a... >>>> 1690819617.7806354;top_libfredo6.rbe;171; in `open' add Command Fredo6 Plugins Information for Sketchucation Support >>>> 1690819617.781276;top_libfredo6.rbe;171; in `open' add Command License... >>>> 1690819617.781851;top_libfredo6.rbe;171; in `open' add Command Trial Period Expiration... >>>> 1690819617.7856922;top_libfredo6.rbe;171; in `open' add Command Plugin Information [Sketchucation]... >>>> 1690819617.7862692;top_libfredo6.rbe;171; in `open' add Command Check Fredo6 Plugins for Update... >>>> 1690819617.787161;top_libfredo6.rbe;171; in `open' add Command Default Parameters... >>>> 1690819617.7877538;top_libfredo6.rbe;171; in `open' add Command Language Translation... >>>> 1690819617.8170905;top_libfredo6.rbe;171; in `open' JointPushPull 4.7a; Startup (creating menus and icons) [50 ms] >>>> 1690819621.4929304;top_libfredo6.rbe;171; in `open' LibFredo6; End of loading Cycle***- >>>> 1690819637.1511135;top_libfredo6.rbe;171; in `open' Lib6_txtmsg; Loading body code from body_Lib6_txtmsg [65 ms] status = true >>>> 1690819637.202284;top_libfredo6.rbe;171; in `open' Lib6G6; Loading body code from body_Lib6G6 [49 ms] status = true >>>> 1690819637.2348042;top_libfredo6.rbe;171; in `open' LibFredo6; Loaded Binary C;/Users/Javi/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU22/bin_body_Lib6G6.so >>>> 1690819637.238742;top_libfredo6.rbe;171; in `open' Lib6FaceSelector; Loading body code from body_Lib6FaceSelector [3 ms] status = true >>>> 1690819637.2419019;top_libfredo6.rbe;171; in `open' Lib6SelMode; Loading body code from body_Lib6SelMode [2 ms] status = true >>>> 1690819637.255253;top_libfredo6.rbe;171; in `open' Lib6Tool; Loading body code from body_Lib6Tool [8 ms] status = true >>>> 1690819637.2560437;top_libfredo6.rbe;171; in `open' Lib6Translate; Loading body code from body_Lib6Translate [13 ms] status = true >>>> 1690819637.2730222;top_libfredo6.rbe;171; in `open' Lib6RoundingProfiler; Loading body code from body_Lib6RoundingProfiler [9 ms] status = true >>>> 1690819637.2738245;top_libfredo6.rbe;171; in `open' Lib6Spline; Loading body code from body_Lib6Spline [17 ms] status = true >>>> 1690819637.280123;top_libfredo6.rbe;171; in `open' Lib6WebHtml; Loading body code from body_Lib6WebHtml [5 ms] status = true >>>> 1690819637.2830093;top_libfredo6.rbe;171; in `open' Lib6Marshall; Loading body code from body_Lib6Marshall [2 ms] status = true >>>> 1690819637.287629;top_libfredo6.rbe;171; in `open' Lib6Algo; Loading body code from body_Lib6Algo [4 ms] status = true >>>> 1690819637.292542;top_libfredo6.rbe;171; in `open' Lib6Contour; Loading body code from body_Lib6Contour [4 ms] status = true >>>> 1690819637.295534;top_libfredo6.rbe;171; in `open' Lib6Offset3d; Loading body code from body_Lib6Offset3d [2 ms] status = true >>>> 1690819637.3007681;top_libfredo6.rbe;171; in `open' Lib6Transform; Loading body code from body_Lib6Transform [4 ms] status = true >>>> 1690819637.3045552;top_libfredo6.rbe;171; in `open' Lib6Mark; Loading body code from body_Lib6Mark [3 ms] status = true >>>> 1690819637.307747;top_libfredo6.rbe;171; in `open' Lib6ParameterManager; Loading body code from body_Lib6ParameterManager [2 ms] status = true >>>> 1690819637.3221846;top_libfredo6.rbe;171; in `open' Lib6EdgePicker; Loading body code from body_Lib6EdgePicker [13 ms] status = true >>>> 1690819637.3277051;top_libfredo6.rbe;171; in `open' Lib6CameraManager; Loading body code from body_Lib6CameraManager [4 ms] status = true >>>> 1690819637.3340962;top_libfredo6.rbe;171; in `open' DATALIB; LibFredo6_datalib60.dat >>>> 1690819637.353655;top_libfredo6.rbe;171; in `open' DATALIB; LibFredo6_datalib61.dat >>>> 1690819637.3897786;top_libfredo6.rbe;171; in `open' DATALIB; LibFredo6_datalib62.dat >>>> 1690819637.4235947;top_libfredo6.rbe;171; in `open' DATALIB; LibFredo6_datalib64.dat >>>> 1690819642.1811182;top_libfredo6.rbe;171; in `open' Lib6Triangulation; Loading body code from body_Lib6Triangulation [6 ms] status = true >>>> 1690819642.1824887;top_libfredo6.rbe;171; in `open' JointPushPull 4.7a; Ruby files loaded [86 ms] >>>> 1690819642.1852403;top_libfredo6.rbe;171; in `open' DATALIB; JointPushPull_datalib60.dat >>>> 1690819642.198856;top_libfredo6.rbe;171; in `open' Lib6FaceSelector; Loading body code from body_Lib6FaceSelector [1 ms] >>>> 1690819642.2151365;top_libfredo6.rbe;171; in `open' Lib6OriginTargetPicker; Loading body code from body_Lib6OriginTargetPicker [15 ms] >>>> 1690819642.2216973;top_libfredo6.rbe;171; in `open' Lib6OpenglPicto; Loading body code from body_Lib6OpenglPicto [6 ms] >>>> 1690819642.2397647;top_libfredo6.rbe;171; in `open' Lib6Opengl; Loading body code from body_Lib6Opengl [17 ms] >>>> 1690819642.2428188;top_libfredo6.rbe;171; in `open' Lib6Triangulation; Loading body code from body_Lib6Triangulation [1 ms] >>>> 1690819642.2462184;top_libfredo6.rbe;171; in `open' Lib6DirectionManager; Loading body code from body_Lib6DirectionManager [3 ms] >>>> 1690819642.263066;top_libfredo6.rbe;171; in `open' Lib6Palette; Loading body code from body_Lib6Palette [13 ms] >>>> 1690819642.2738054;top_libfredo6.rbe;171; in `open' Lib6Input; Loading body code from body_Lib6Input [2 ms] >>>> 1690819642.2913103;top_libfredo6.rbe;171; in `open' Lib6VCB; Loading body code from body_Lib6VCB [2 ms] >>>> 1690819642.3207726;top_libfredo6.rbe;171; in `open' Lib6Marshall; Loading body code from body_Lib6Marshall [1 ms] >>>> 1690819751.0617495;top_libfredo6.rbe;171; in `open' Lib6PluginDialogs; Loading body code from body_Lib6PluginDialogs [28 ms] >>>> 1690819751.0755687;top_libfredo6.rbe;171; in `open' Lib6ChromiumJS; Loading body code from body_Lib6ChromiumJS [11 ms] >>>> 1690819751.1272552;top_libfredo6.rbe;171; in `open' Lib6Onglets; Loading body code from body_Lib6Onglets [8 ms] status = true >>>> 1690819751.128928;top_libfredo6.rbe;171; in `open' Lib6ChromiumWdlg; Loading body code from body_Lib6ChromiumWdlg [51 ms] >>>> 1690819751.1330724;top_libfredo6.rbe;171; in `open' Lib6Vault; Loading body code from body_Lib6Vault [3 ms] >>>> 1690819759.0988104;top_libfredo6.rbe;171; in `open' Lib6WebXTable; Loading body code from body_Lib6WebXTable [22 ms]
Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste text into your reply
This is what I got:
Fredo6 Plugins Information on 2023-07-31 18;49;07 +0100 -------------------------- - Platform; x64-mswin64_140 - Ruby; 2.7.2 - Sketchup; 22.0.354 - LibFredo6; v14.1a - LibFredo6 Binary loaded - Sketchucation ExtensionStore; 4.3.1 - SCFLicense; v6.1a - 72 - Fredo6 Plugins Error; #<TypeError; no implicit conversion of nil into String> c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;603;in `exist?' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;603;in `licensed?' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;331;in `initialize' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;73;in `new' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;73;in `licensed?' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;797;in `block in info' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;791;in `each' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;791;in `info' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;368;in `block in populate_support_menu' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1385;in `block in add_command'
This is what I got in my work's laptop:
Fredo6 Plugins Information on 2023-07-31 19;09;52 +0100 -------------------------- - Platform; x64-mswin64_140 - Ruby; 2.7.2 - Sketchup; 23.0.397 - LibFredo6; v14.1a - LibFredo6 Binary loaded - Sketchucation ExtensionStore; 4.3.1 - SCFLicense; v6.1a - 72 - Fredo6 Plugins > Curviloft v1.9b - licensed FULL > FredoScale v3.5a - licensed FULL > FredoTools v4.3a > JointPushPull v4.7a - licensed FULL > MrHide v1.7a > RoundCorner v3.3a > ThruPaint v2.2a > ToolsOnSurface v2.5a - licensed FULL > TopoShaper v2.6a - SCFLicense directory present > Signature File; 2022-04-19 07;29;12 +0100 > Curviloft; 2022-05-04 11;38;20 +0100 > FredoScale; 2022-04-29 14;15;01 +0100 > JointPushPull; 2023-07-31 18;25;32 +0100 > ToolsOnSurface; 2022-05-06 10;32;19 +0100
Does it seem SCFLicense problem?
Can you download the sketchup installer, right click it and Run as Administrator, Then choose Repair.
https://www.sketchup.com/download/all
Then reinstall Sketchucation Tools and rrestart SketchUp.
On restart run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support and see if the error is gone.
It looks like there's an OS issue creating the SCF License folder which is usually your OS protecting you from yourself.
Do you have C:\Users\SomeName\AppData\Local\SCF Licenses folder?
Thanks a lot Rich. I'll do that. I have SCF Licenses folder right where it must be. There're some SCFLicense_XXXXX_this_computer.txt files inside and one SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt.
Now I have to add another issue: I installed Clothworks. After this, if a draw anything, select it and right click... SU freezes at all. Same effect when try to expand Edition menu instead right click.
If you have a SCF Licenses folder and content like SCFLicense_XXXXX_this_computer.txt then that says at some point you activated a license.
Close SketchUp
Delete to contents of C:\Users\SomeName\AppData\Local\SCF Licenses folder including the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file
In your plugins folder delete Fredo6_!LibFredo6 folder and Fredo6_!LibFredo6.rb file
Start Sketchup and install Libfredo 14.1a
Restart SketchUp
Run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support
Then try activating a license per the guide...
https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
Close SketchUp
Restart SketchUp
Somehow it seems an SCFLicense problem. I followed all that steps and got the same result.
Then I went to Extension Manager, uninstalled SCFLicense (keeping Sketchucation), and now JointPushPull works perfectly. When SCFLicense is installed, I need to double click to make it work
I don't know what kind of dependencies needs SCFLicense to work, but somehow SCFL is the problem.
It is certainly an issue on that device.
Your original post was for SketchUp 2021, your Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support output is for SketchUp 2022 and your work laptop is SketchUp 2023.
Your work laptop is behaving correctly.
If we look at your activation we see everything activated last year on 3 separate devices.
Have you issue on these devices?
What's different on this device that led to this instability? How did you migrate extensions?
You don't have a license for Clothworks associated to your account.
Hi Rich. My original post certainly was for SketchUp 2021. As I couldn't solve this problem, I uninstalled SketchUp 2021 and installed SketchUp 2022, but the problem persisted from the first start.
I checked my work laptop (SketchUp 2023) and it works perfectly.
I use three devices:
- This home PC, where i'm getting this issue (it was the first device for plugins activation)
- Work laptop (SU 2023 - no problem)
- Work PC (SU 2022 - no problem)
I don't know what caused this problem. It started suddenly one day to another. Even uninstalling everything, deleting all involved folders and registry references and then installing a clean new version, the problem keeps going.
I tried to release all license seats, but some keep unreleasable, don't know why...
Which device is unreleasable?
I'll point Fredo towards this thread to see if he has ideas. Everything points towards a funky/corrupt license environment.
You didn't copy your plugins and scf licenses for other to this one? Or something in line with that?
With Sketchucation Tools 4.3.1 and Libfredo 14.1 installed you should just get the licenses folder setup ready for accepting licenses and activation.
If you want to go to extreme lengths you could rename your plugins folder to !!!plugins to prevent it loading. SketchUp will create a new plugins folder when you start it.
Then install a fresh Sketchucation Tools and Libfredo and a single bundle extension. If that is still the same then delete this new plugins folder and rename !!!plugins back to plugins to restore it.
I don't expect it to work as the issue is around scf license.
I've pinged Fredo to see if he can help better than me
I really don't know which device is unreleaseable, because i don't know where to find HW ID to compare.
I first activated plugins in home PC, then at work PC and laptop. Everything went ok until now.
I tried something in my home PC and work laptop, as I know in my laptop works ok:
- Deleted C:\Users\SomeName\AppData\Local\SCF Licenses
Then restarted SU at both:
- my work laptop creates again SCF folder, home PC doesn't.
- None of them creates again SCF Licenses folder.
- I noticed work laptop has LIBFREDO6_DATA_Dir, home PC doesn't.
Could it be about this folders? Let's see.
Thanks for your help Rich.
Last try this morning:
Repaired SU 2022, deleted Plugins folder, installed just SketchUcation Tools and LibFredo6:
Fredo6 Plugins Information on 2023-08-01 09;42;07 +0100 -------------------------- - Platform; x64-mswin64_140 - Ruby; 2.7.2 - Sketchup; 22.0.354 - LibFredo6; v14.1a - LibFredo6 Binary loaded - Sketchucation ExtensionStore; 4.3.1 - SCFLicense; v6.1a - 72 - Fredo6 Plugins - SCFLicense directory absent
Then installed one random Fredo6 plugin (VisuHole):
Fredo6 Plugins Information on 2023-08-01 09;46;37 +0100 -------------------------- - Platform; x64-mswin64_140 - Ruby; 2.7.2 - Sketchup; 22.0.354 - LibFredo6; v14.1a - LibFredo6 Binary loaded - Sketchucation ExtensionStore; 4.3.1 - SCFLicense; v6.1a - 72 - Fredo6 Plugins Error; #<TypeError; no implicit conversion of nil into String> c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;603;in `exist?' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;603;in `licensed?' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;331;in `initialize' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;73;in `new' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;73;in `licensed?' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;797;in `block in info' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;791;in `each' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;791;in `info' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;368;in `block in populate_support_menu' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1385;in `block in add_command'
If the SCFLicense folder is missing something is stopping it being created, or found.
Is this folder there ?
C:\Users\javi\AppData\Local\SCF Licenses
Check the permissions to your Local folder allow folders to be added and files made/read...Also look in your Roaming folder and ensure that its contents are writable etc...
Perhaps SketchUp is having an issue with the contents of subfolders in Plugins etc...The folder named exactly "
SCFLicense
" is part of the installation of the SketchUcation extension installation... It contains many vital files and subfolders used in the licensing system.
Is it there ?
C:\Users\javi\AppData\Roaming\SketchUp\SketchUp 2022\SketchUp\Plugins\SketchUcation\SCFLicense
If it's not there please try reinstalling the latest toolset from the SCF Plugin|ExtensionStore [v4.3.1].
That folder is most definitely included in the RBZ installer... -
SCFLicense
Is it there ?
That folder is most definitely included in the RBZ installer...The folders are there, permissions are ok, Roaming folder and its contents are writable.
SCFLicense
" is where it should be:
I've reinstalled SU 2022, started and just installed SketchUcation Tools.
Extensions > SketchUcation > SCFLicense: Global Status...
does nothing.This is gonna be next "X Files" movie...
The above path doesn't contain your licenses. It is extension related.
The path below is where you are experiencing issues...
This folder should have the .txt files and the signature file.
Well, first problem solved: SU now reads my licenses at
C:\Users\Javi\AppData\Local\SCF Licenses
.Fredo6 Plugins Information on 2023-08-01 15;27;29 +0100 -------------------------- - Platform; x64-mswin64_140 - Ruby; 2.7.2 - Sketchup; 22.0.354 - LibFredo6; v14.1a - LibFredo6 Binary loaded - Sketchucation ExtensionStore; 4.3.1 - SCFLicense; v6.1a - 72 - Fredo6 Plugins - SCFLicense directory present > Signature File; 2022-03-30 01;28;02 +0100 > Curviloft; 2022-04-28 20;01;36 +0100 > FredoScale; 2022-04-16 20;20;36 +0100 > JointPushPull; 2022-06-22 20;11;35 +0100 > RoundCorner; 2022-05-11 10;12;30 +0100 > ToolsOnSurface; 2022-04-28 21;50;30 +0100
Second part is still unreachable: if I install a Fredo6 plugin, I get the same error. This is what I get after installing Curviloft:
Fredo6 Plugins Information on 2023-08-01 15;28;54 +0100 -------------------------- - Platform; x64-mswin64_140 - Ruby; 2.7.2 - Sketchup; 22.0.354 - LibFredo6; v14.1a - LibFredo6 Binary loaded - Sketchucation ExtensionStore; 4.3.1 - SCFLicense; v6.1a - 72 - Fredo6 Plugins Error; #<TypeError; no implicit conversion of nil into String> c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;603;in `exist?' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;603;in `licensed?' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;331;in `initialize' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;73;in `new' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;73;in `licensed?' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;797;in `block in info' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;791;in `each' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;791;in `info' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;368;in `block in populate_support_menu' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1385;in `block in add_command'
I'm thinking it's because I have customized Windows paths at Advanced System Setup (even though I haven't had this problem in years):
- C:\Windows\Temp --> D:-WinCache\Windows\Temp
- C:\Users\javi\AppData\Local\Temp --> D:-WinCache\Temp
I think this because in my work laptop, SCF and SCF Licenses are subfolders at
, but in my home PC is SCF is atD:\-WinCache\SCF
and SCF Licences keeps as aC:\Users\Javi\AppData\Local
subfolder. -
It seems I'm in a dead end... "SCFLicense: Global Status" refuses to show, even LibFredo6 is installed or not. Then, the same issues as posted before.
Any idea?
I think this unconventional path is likely your issue...
D:\-WinCache\SCF
TIG and Fredo would be better placed to comment on the nuances of the 'ideal' setup for such scenarios.
