    ·ERROR en validacion de licencia
    5 Posts 3 Posters 422 Views 3 Watching
      CarmensitaBC
      Buenas tardes, tengo una licencia del pluggin FredoScale, pero cuando le doy a validar licencia me dice:
      Error in the Liicecnse Validation
      Request to Sketchucation: ERROR_A0C
      Computer name mismatch - It is advised to erase the Signatura file and revalidate.
      Qué tengo que hacer? me he descarga el archivo de la licencia ya 20 veces, no sé qué hacer.
        Update Sketchucation Tools
        https://sketchucation.com/plugin/696-sketchucationtools
        Update Libfredo
        https://sketchucation.com/pluginstore?pln=LibFredo6
          After that, restart SketchUp.
          If that doesn't help follow the instructions to delete that file, then restart...
          Re-validate the licenses to try again...
          Fore example, you might have changed your computer's name, which will confuse the licensing checker...
            CarmensitaBC
            He probado a hacer todo, he actualizado sketchUcation, he reiniciado SketchUp, he instalado Fredo6 LibFredo6, he vuelto a reiniciar el programa, he instalado FredoScale, y me sigue dando el mismo error.
              Go to C:\Users\SomeName\AppData\Local\SCF Licenses and delete the following
              SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt
              Close SketchUp
              Start SketchUp
              Now go to Tools > Fredo Collection > Fredoscale > License... and activate the license file using the file at https://sketchucation.com/webshop/my-licences.php
              Also please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support in SketchUp and copy/paste the info here please.
