    Bugsplat on making surfaces
    21 Posts 3 Posters 421 Views 3 Watching
      3D warehouse link.
      app.sketchup.com/app?3dwid=6dd034b7-a81b-4cc6-a2e1-db15fe2d01a3
        • BoxB Offline
          You appear to trying to share the app.
          Just go to the model in the warehouse and copy the address in the top bar and paste that.
            3D Warehouse
            (3dwarehouse.sketchup.com)
            • BoxB Offline
              That works, I'll take a look.
                Thanks much appreciated πŸ‘
                • BoxB Offline
                  It looks like it will eventually get there. It is too many segments but Curvisard Cleanup seems to be working.
                  You would need to work through it in sections...
                  Hmm just crashed while I was writing this. I have two others running though.
                  Ideally a an import with less segments would work better.
                    Thanks Box, so helpfull as usual, I never heard of Curvisard Cleanup but will look into it πŸ‘
                    • BoxB Offline
                      Cleanup Contours is one of the options in Curvizard. I always misspell it.
                      https://sketchucation.com/pluginstore?pln=Curvizard
                      • BoxB Offline
                        And keep in mind that you should make some 'cuts' through the tree. In other words create gaps in the outer edge of the tree, break it into several 'trees' so that you don't have one continuous border edge that ends up with a huge number of segments. When I first looked at it the whole thing contained over 330,000 segments. It would be highly likely that the border edge would contain more than 10,000 and 10,000 is a finite limit. Sketchup will shutdown without a bugsplat if you attempt to manipulate a continuous edge of over 10,000.
                          Why not use transparent png texture?
                          • BoxB Offline
                            This is what I mean about breaking it up.
                            This section on its own has just over 10000 segments in the border, so it is borderline. I deliberately didn't weld the whole border.
                              Cheers Rich, because I am trying to emulate a laser cut piece of corten steel with thickness
                                This was only an experiment. I found some images from "clean png" site and conerted it to a DXF using https://convertio.co/png-dxf/, I thought that particular png was extremely complex but now I will look for a less complex subject for my experiment.
                                I think this method of converting a raster image into a DXF and then importing into SU has some promise though.
