    Mass rename components
    23 Posts 6 Posters 12.5k Views 6 Watching
      You could try editing the code as follows - inside the
      block of
      ...each{|d|...}
      substitute...
      Change the value of
      i=
      to how many characters you want to loose...
      To trim off the end use
      i=10;n=d.name;1.times{n=n.chop};d.name=n;
      To trim off the start use
      i=10;n=d.name;n=n[i..-1];d.name=n;
        MAdel
        block of
        ...each{|d|...}
        substitute...
        Change the value of
        i=
        thanks for your help,much appreciated
        would you please create a file for me with a calling name like
        delete "last_3"
        or
        Delete"frist_5"
        i am able to use the banding "prefix-" script
        i don't know anything about coding
        but your script is what i was looking for and need
          Copy/Paste this code into the Ruby Console to rename all of the model's definitions, with 3 characters off the end of their names - change i=3 to another value as desired...
          m=Sketchup.active_model;m.start_operation('chop defns',true);c=0;m.definitions.each{|d|i=3;n=d.name;(1.times{n=n.chop};d.name=n;c+=1)};puts"#{c} definition-names chopped.";m.commit_operation;
          Or use this code to strip 5 characters off the names' beginnings - again edit i=5 as desired...
          m=Sketchup.active_model;m.start_operation('trim defns',true);c=0;m.definitions.each{|d|i=5;n=d.name;n=n[i..-1];d.name=n;c+=1)};puts"#{c} definition-names trimmed.";m.commit_operation;
          • 2 / 2
