    Mass rename components
    23 Posts 6 Posters 12.8k Views 6 Watching
      defs=[]
      Sketchup.active_model.selection.each{|e|
        defs<<e.definition if e.class==Sketchup;;ComponentInstance
      defs.uniq!
      defs.each{|d|d.name=d.name+"-SUFFIX"}
      This processes the definitions - I'm assuming that you want to rename the component-definition NOT the component-instance which can also have a separate name... It's easy to adjust the code if instances are to be renamed... like this...
      insts=[]
        insts<<e if e.class==Sketchup;;ComponentInstance
      insts.each{|i|i.name=i.name+"-SUFFIX"}
      ### NOTE; the component-definition's name is NOT changed by this...
        dedmin
        Thanks!! Yes, I want to change component-definition.
        I saved the ruby as a banding.rb in the Plugins folder, selected the components and run the script in the ruby console. Never been messed with this before - maybe I'm doing something wrong here?
        banding
        Error; #<NameError; (eval);42; undefined local variable or method `banding' for main;Object>
        (eval);42
          Without seeing your code I don't know what's up - what have you pasted into the file - I only showed snippets which need some 'structure' ! You have to have
          def banding()
           ### The code...
          end#def
          To run it by typing 'banding'...
          It'd be relatively easy to sort - please paste you code inside a [ code ][ /code ] set...
            dedmin
            I see. I thought it's a finished script ready to run. Never touched any scripting before. Thanks - will do it by hand.
              Copy/paste this into a banding.rb file, then typing banding "-suffix" in the console should work on selected components...
              def banding(suffix="")
                suffix=suffix.to_s
                model=Sketchup.active_model
                model.start_operation("banding "+suffix)
                ss=model.selection
                defs=[]
                ss.each{|e|
                    defs<<e.definition if not defs.include?(e.definition)
                  end#if
                defnames=[]
                defs.each{|d|
                  d.name=d.name+suffix
                  defnames<<d.name
                puts "Processed "+defs.length.to_s+" Component Definitions"
                defnames.each{|n|puts n}
                puts ""
                model.commit_operation
              end#def
              PS: I've attached the .rb too...banding.rb
                dedmin
                banding "-0W-1L"
                Processed 2 Component Definitions
                drawer_right-0W-1L
                drawer_left-0W-1L
                true
                It works!!!!
                  dedmin
                  It works great, but there is a problem. If I make a cabinet component with all the banding info for the parts set and then stretch with FredoScale to get new dimensions the components get renamed
                  drawer_left;0W-1L#1
                  • they become new components. Since i'm using the names as a way to export banding info into the CutList Plus using ";" as a delimiter i have to rename again. But if i put this info as a prefix then everything will be fine and no need to rename again. Can You please make this script do the same but as a prefix? Sorry, if i sound too insolent 😳
                    dedmin
                    true
                    banding "0W-1L;"
                    0W-1L;drawer_right
                    0W-1L;drawer_left
                    true
                               :+1:  :+1:  :+1:  :+1:
                      Here's an update:banding.rb
                      Usage:
                      banding "prefix-" [or banding "prefix-","" or banding "prefix-",nil] adds a prefix
                      banding "","-suffix" [or banding nil,"-suffix"] adds a suffix
                      banding "prefix-","-suffix" adds a suffix and a prefix
                        DavorP
                        Is there a plugin that would export list of component names, definitions and perhaps other details to .csv file
                        And the more tricky part - to import back the new filenames after you are done with editing?
                        Or a plugin that would list all components with details in an editable spreadsheet within SU?
                        • Dan RathbunD
                          Dan Rathbun
                          What "other details" ?
                          I'm not here much anymore.
                            jeynay
                            Is there a way to remove certain words from multiple components at the same time?
                            for example I have 50 components that their name has "3D - johnsmith_google_com level 1" at the end of the name. like:
                            "10016001_S_DLGBldg1_Central_detached_rvt-1-3D - 3D - johnsmith_google_com level 1"
                            "4_ Light Fixture - 4_ Light Fixture-1847101- 3D - johnsmith_google_com level 1"
                            "Aluminum Sill Extension - Aluminum Sill Extension-2131210-3D - johnsmith_google_com level 1"
                            Is there a script that can remove a certain prefix or suffix? or just removing the first/last 15 or 10 characters in the name would also work.
                            This issue is very annoying since the models imported from revit to sektchup end up having more than 100 characters. πŸ˜•
                              @jeynay said:
                              You can batch rename components.
                              I assume you mean component-definitions, rather than component-instances which can have individual names based on a shared definition...
                              Here's a simple one-liner to do it...
                              Edit the initial togo="..."; to suit your needs...
                              togo=" - 3D - johnsmith_google_com level 1";m=Sketchup.active_model;m.start_operation('rename defns',true);c=0;m.definitions.each{|d|(d.name=d.name.gsub(/#{togo}/,'');c+=1) if d.name=~/#{togo}/};puts"#{c} definitions renamed.";m.commit_operation;
                              Paste it into the Ruby Console + <enter>, it's one step undoable...
                                jeynay
                                Thanks for the quick reply TIG.I'm assuming this would rename that portion of component's name as well? for exampe if i have 50 instances like
                                "4_ Light Fixture - 4_ Light Fixture-1847101- 3D - johnsmith_google_com level 1-01"
                                "4_ Light Fixture - 4_ Light Fixture-1847101- 3D - johnsmith_google_com level 1-02" so on so forth, would i be able to remove the" 3D - johnsmith_google_com level" portion of those instance names?
                                Thanks in advance
                                @tig said:
                                @jeynay said:
                                  The initial part of the code snippet togo=" - 3D - johnsmith_google_com level 1";
                                  specifies which string will be deleted in the components' names.
                                  I you example:
                                  "4_ Light Fixture - 4_ Light Fixture-1847101- 3D - johnsmith_google_com level 1-01" "4_ Light Fixture - 4_ Light Fixture-1847101- 3D - johnsmith_google_com level 1-02"
                                  etc
                                  become
                                  "4_ Light Fixture - 4_ Light Fixture-1847101-01" "4_ Light Fixture - 4_ Light Fixture-1847101-02"
                                  etc
                                  Just edit that to cover what you want to delete...
                                  So to leave the final 'ref' as say "1-01", you simply change the togo to say:
                                  togo=" - 3D - johnsmith_google_com level";
                                  and the renaming is then:
                                  "4_ Light Fixture - 4_ Light Fixture-1847101 1-01" "4_ Light Fixture - 4_ Light Fixture-1847101 1-02"
                                  etc
                                  You choose what's to be deleted...
                                  You can always run the code a second time with a new togo string, e.g.
                                  togo="4_ Light Fixture - ";
                                  Would strip off the duplicated starting reference, leaving:
                                  "4_ Light Fixture-1847101 1-01" "4_ Light Fixture-1847101 1-02"
                                  etc
                                    jeynay
                                    I you example:
                                    etc
                                    become
                                    etc
                                    etc
                                    etc
                                    This worked beautifully!!! thank you much appreciated πŸ˜„
                                      MAdel
                                      thanks TIG for those amazing scripts
                                      i hope you could add the option for
                                      removing the first/last 15 or 10 characters from the name
                                      @tig said:
                                      @jeynay said:
                                        You could try editing the code as follows - inside the
                                        block of
                                        ...each{|d|...}
                                        substitute...
                                        Change the value of
                                        i=
                                        to how many characters you want to loose...
                                        To trim off the end use
                                        i=10;n=d.name;1.times{n=n.chop};d.name=n;
                                        To trim off the start use
                                        i=10;n=d.name;n=n[i..-1];d.name=n;
                                          MAdel
                                          block of
                                          ...each{|d|...}
                                          substitute...
                                          Change the value of
                                          i=
                                          thanks for your help,much appreciated
                                          would you please create a file for me with a calling name like
                                          delete "last_3"
                                          or
                                          Delete"frist_5"
                                          i am able to use the banding "prefix-" script
                                          i don't know anything about coding
                                          but your script is what i was looking for and need
                                            Copy/Paste this code into the Ruby Console to rename all of the model's definitions, with 3 characters off the end of their names - change i=3 to another value as desired...
                                            m=Sketchup.active_model;m.start_operation('chop defns',true);c=0;m.definitions.each{|d|i=3;n=d.name;(1.times{n=n.chop};d.name=n;c+=1)};puts"#{c} definition-names chopped.";m.commit_operation;
                                            Or use this code to strip 5 characters off the names' beginnings - again edit i=5 as desired...
                                            m=Sketchup.active_model;m.start_operation('trim defns',true);c=0;m.definitions.each{|d|i=5;n=d.name;n=n[i..-1];d.name=n;c+=1)};puts"#{c} definition-names trimmed.";m.commit_operation;
