    Alphabet to sketch(up)
    212 Posts 7 Posters 62.3k Views 7 Watching
      Father of the Alphabet Letters! πŸ˜‰
      http://indexgrafik.fr/albrecht-durer-construction-des-lettres/ (English / French)
      • majidM
        majid
        Playing with a sketch of "W".
        W
        • ntxdaveN
          ntxdave
          Nice πŸ‘ πŸ‘
          How did you produce the reflections?
          Now for the practical side, how would you walk around in side the structure? This is an issue I have with some letters of the alphabet (like say a W or Y). πŸ˜•
          Press F1...thank me later
          • majidM
            majid
            For the water, I used a plane with pure reflection and a "noise" as bump map.
            There are a few tricks to get inside the close volumes; switching between styles maybe is the easiest one. then I place the "look around " tool...
            • ntxdaveN
              ntxdave
              I really was asking about moving around inside if was a β€œreal” building. πŸ˜„
              • majidM
                majid
                Do you mind discribing more, please? I can not get you (I am not a native English speaker and so there are language barriars, you know.)
                • ntxdaveN
                  ntxdave
                  A: How do you enter the building?
                  B: Once a person is inside the building, how does a person walk around unless the is a floor above the v shape of the bottom of the building sections?
                  Again, I am looking at this like a person who builds the building or lives in it. πŸ˜„
                  • majidM
                    majid
                    Aha, Got it. The question of solving unusable "sharp corners" needs some practice in architecture. The simplest way is to add a decent "room" to part of it. i.e. in "W" I have added a cube to part of it. Rest may be used as storage or a room for the "mechanical" part of the building.
                    Please also consider that in this book I was not considered to be practical. The following links also may help, the first is about the 4x4 house (2003) project by Tadao Ando:
                    https://en.wikiarquitectura.com/building/4x4-house/
                    And this is to brainstorm rules:
                    https://www.atlassian.com/work-management/project-collaboration/brainstorming
                    I may draw your attention to rule 2.
                    During the creativity phase, it would be way better if do not criticize the job. Later on, when "developing" the idea you may adjust it to make it works practically. That was not the purpose of my sketches.
                    As you might have seen in the book the original sketch includes an "entrance" room which I have changed in the render.
                    • ntxdaveN
                      ntxdave
                      #2 πŸ‘
                      I was not trying to be critical (although I understand how it comes across). Part of my problem when doing the stuff is getting caught hop n the β€œpractical” side and not being more β€œimaginative”. Something I need to practice! 😲
                      • majidM
                        majid
                        As far as I know, in all design-related jobs at least two things are inevitable: "Being practical, and not leaving undesigned parts". So you are right about being practical.
                        About critics: The tip is that at the early stages (of creativity) one must let it go and prevent criticizing. Then later on, during the development phase, you can make it work.
                        About not leaving undesigned: (In architecture) if the designer does not design everything, the builder will do! and they will do on their taste! So preferably it would be better to design everything under one hood.
                        My sketches are to encourage creativity and belong to the early stages of the design process (also called schematic design). Needless to say, it is a back-forth process.
                        i.e. please see: https://www.masterclass.com/articles/phases-of-the-architectural-design-process
                        • ntxdaveN
                          ntxdave
                          Valid points Majid.
                          In the little experience I have in this area, my job was to produce 3D (isometric) drawing and renders of car was equipment and a couple of times, renders of buildings where the equipment was going to be installed. So a lot of the processes you are talking about had already been done when I was brought into the picture things had already been completed.
                          Thanks to you, I need to step back and experience these earlier stages. πŸ˜„ Please don’t give up on me. I want to learn. 😎
                          • majidM
                            majid
                            Dave, I am so pleased to share what I know. This way I myself benefit by being criticised and rectified by others!
                              About the inclined architecture we had a French one specialized in this! πŸ˜‰
                              Claude Parent! (1923 - 2016)
                              Take a look at "La fonction Oblique" in Google image...
                              • ntxdaveN
                                ntxdave
                                Wow Pilou ❗ πŸ‘ πŸ‘
                                Majid, you should really enjoy this stuff. I did a search on Bing and there were some awesome images that really kind of fall into your thought pattern.
                                • majidM
                                  majid
                                  Definitely a constructive corroboration!
                                  P.S:To give an explanation and make clarification of the inception of the book, let me draw your attention to Bruno Munary's classic book; Design As Art. I read it 3 decades ago but it is still one of the most inspiring books I have ever read.
                                  https://www.giuseppegallo.design/books-for-architects-and-designers/design-as-art-by-bruno-munari/
                                  • majidM
                                    majid
                                    I found this book (Bruno Munari's book ) very inspiring. I am wondering if anybody else has read it.
                                    p.s. Maybe sharing some images makes sense:
                                    • majidM
                                      majid
                                      I am wondering if anyone has read this rather old yet inspiring book?
                                        I am thinking about it but it's a way down the list at the moment, very busy with stuff.
                                        It does look very interesting, insightful.
                                        • majidM
                                          majid
                                          It is worth reading IMO. I found it inspiring and influential.
                                          The good news is that the paperback version of my book is also available: https://lnkd.in/dGkuAFXW
                                          • ntxdaveN
                                            ntxdave
                                            Just looked at the pdf about your book again and I need to go off and play with all the letters some more. I have tried to be too precise which can put restrictions on the building designs. πŸ‘Ž
                                            I am still trying to lear both Krita (for laptop) and Sketchbook for iPad to do my sketching. Hope to be able to post something soon. πŸ˜„
                                            • 11
                                            • 5 / 11
