    [Plugin] LordOfTheToolbars - v2.9c - 20 Dec 24
    471 Posts 89 Posters 340.6k Views 88 Watching
      Gordon McLaren
      Thanks for all the suggestions/workarounds, I will give them a try.
        rv1974
        @Fredo is implementing of multiple key shortcuts is possible via plugin? A-la Revit, for example - EP for 'edit profile builder's path'?
          Gordon McLaren
          @Panixia - Thanks once again for the work-around, I have implemented it and it works like a charm.
          • panixiaP Offline
            panixia
            Glad that it helped 😄
              AISmebel
              @panixia said:
              @gordon mclaren said:
              I use the "Personal Command Menu" often and would definitely like to see it working again.
              I have a workaround for this.
              Assign some weird shortcut to your menu item (I say "weird" because maybe you don't want to waste some available handy keyboard shortcut for this).
              Then create a ruby script button and type in the following:
              shell = WIN32OLE;;new("WScript.Shell")
              > shell.SendKeys "InsertYourWeirdSendkeyShortcutHere"
              Insert your shortcut between quotes using the "Microsoft sendkeys" syntax, you can find the reference at this link:
              SendKeys statement (VBA)
              VBA language reference
              (learn.microsoft.com)
              Here's an example.. this one would be equivalent to press "Ctrl+Shift+Alt+F11" each time you hit the toolbar button.
              [attachment=0:16wbl6tz]<!-- ia0 -->SendKeysShortchut.JPG<!-- ia0 -->[/attachment:16wbl6tz]
              Hi. I could not figure out your instructions on how to restore the tools from the "Menu" ((
              Maybe write in more detail? Thank you in advance.
              • panixiaP Offline
                panixia
                I wrote exactly the more detailed description I can think of.
                Is actually the "step by step" explaination and I also added the code you need and the reference page for the syntax you should use to recall your shortcuts from SendKeys.
                Please notice that this DOES NOT restore the "menu button" functionality of LOTT in SU23.
                This is just a workaround to create a ruby script button in LOTT that can mimic the missing "menu button" feature.
                The ruby script just invokes a shortcut when you hit the toolbar button.
                You need to assign that shortcut (to the menu item you want to create a button for) before creating the button itself.
                  laurent002
                  Bonjour,
                  J'ai installé LordOfTheToolbars sur la version 2023, mais il semble qu'il ne trouve pas le chemin pour accéder aux menus, y a-t-il une procédure manuel pour lui indiquer le chemin ? Il semble que je n'ai pas trouvé comment faire. Du coup je me suis remis à la version 2022 faute de pouvoir retrouver mon organisation fonctionnel. Faut-il attendre une mise à jour ou est-ce qu'il y a un moyen de rendre fonctionnel l'accÚs aux menus.
                  Merci
                  • panixiaP Offline
                    panixia
                    @laurent002 said:
                    Bonjour,
                    Merci
                    Tout est expliqué en anglais dans les derniers posts précédant celui-ci
                      AISmebel
                      Hi. I'm ashamed that I can't figure out how it works. Maybe someone will record a training video?)))
                      • fredo6F Offline
                        There are videos in the first post of this thread. There are others on YouTube.
                          AISmebel
                          Hi Fredo. Perhaps you misunderstood me. I wanted to see a video in which, with the help of a script from the author of panixida, it will be possible to use the command menu. The menu is a very convenient tool, its absence does not allow me to switch to SU2023.
                            laurent002
                            Hello,
                            I have installed LordOfTheToolBars on sketchup 2023, but there is no access to any menus tools. Only icons. It means that i can't creat icons, anything.
                            The most interresting thing about your plugin.
                            What can I do to fixe or modify to fixe that link problem.
                            Thanks for your help.
                            • fredo6F Offline
                              @laurent002 said:
                              Hello,
                              Yes. Menu disappeared due to change of UI framework for Su2023 on Windows (on Mac this is still available). No workaround possible, unless Trimble provides new API methods.
                              • panixiaP Offline
                                panixia
                                @laurent002 said:
                                Hello,
                                Not exactly the same, but you can achieve similar result with this workaround.
                                http://sketchucation.com/forums/viewtopic.php?f=323&t=73776&view=unread#p687744
                                  Julien 2
                                  Thanks for the suggestion, I will give a try 😉
                                  • H Offline
                                    HouseOfBOP
                                    I seem to have lost the Quick Command finder. I'm using Sketchup 2021 pro, and have the latest LibFredo and LOTT. I've tried reinstalling LOTT and have Sketchup installed as admin.
                                    Is there any way to reset the position of where the quick command finder dialog pops up - or have I broken something?
                                    Thanks v much
                                    T
                                    • H Offline
                                      HouseOfBOP
                                      I seem to have lost my Quick Command Finder pop up. I'm all up to date, Sketchup installed as admin, and have reinstalled LOTT.
                                      Is there a way to reset where the popup pops up - or have I missed or broken something? I'm on 2021 Pro.
                                      • fredo6F Offline
                                        Do you have several monitors?
                                        • H Offline
                                          HouseOfBOP
                                          I'm on a laptop with an extra screen. I disconnected the second screen when I was trying to retrieve the popup. No luck though.
                                          • fredo6F Offline
                                            Could you do the following
                                            1. Open the Ruby Console
                                            2. Launch the LOTT Find dialog
                                            3. Copy paste the following command in the Ruby console and press Enter
                                              Traductor::ChromiumWdlg.check_instance_displayed("LOTT_MiniFindDialog", true).set_position(0, 0)
                                            The Find dialog should go to the position top left corner of your screen.
                                            • 23
                                            • 24
                                            • 8 / 24
