    [Plugin] SJ Batch Export Scenes To Thumbnails
    4 Posts 3 Posters 1.9k Views 3 Watching
    • simjoubertS Offline
      simjoubert
      Hello, (I'm not sure I'm in the right place!)
      I want to share with you my SJ Batch Export Scenes To Thumbnails plugin.
      SJ Batch Export Scenes To Thumbnails is a plugin for Sketchup.
      The plugin allows to batch export the scenes of the model in JPG, PNG, TIF or BMP images, in a subfolder "Export_Scenes" of a folder bearing the same name as the model.
      The name of the folder is purged of all accented characters. Spaces and other characters are substituted with underscores.
      The name of the scenes which serves as a basis for exporting thumbnails is also cleaned up.
      The plugin allows you to optionally add a prefix and a suffix to filenames.
      This is useful when you want to export several variants according to different export parameters.
      You can configure the dimensions of the generated images, with or without proportion constraints (Window, square, 4/3, 16/9, free).
      You can enable PNG transparency, antialiasing and compression rate for JPG outputs.
      The dialog uses Bootrap, Modus and JavaScript.
      A progress box allows you to follow the export.
      The plugin is translated according to the language of Sketchup in French or English.
      https://www.sketchup.simjoubert.com/images/Plugins/SketchUp_SaJfzWdexV.gif
      The plugin is free, the code is not encrypted and commented in French to help French Ruby beginners.
      You can download the plugin :
      • on my site : https://www.sketchup.simjoubert.com/my-plugins/sj-batch-export-scenes-to-thumbnails.html
      • on the Sketchucation plugin store : https://sketchucation.com/plugin/2531-batchexportscenestothumb
      Thank you for your feedback
      Simon
      • judedouchJ Offline
        judedouch
        Hi Simon,
        Nice & Useful plugin.
          Achilles69
          Hi Simon,
          your plugin is best for me around export the scenes to PNG. Thank you very much for this 👍 .
          I have an question for you.
          How can I always save my selection for my preferred format PNG?
          I have to re-enter it every time for every export.
          Maybe my question is a tip for further improvement of an already very useful plugin 😎 .
          Thank you and look forward for your reply
            simjoubert
            @achilles69 said:
            Hi Simon,
            Good evening Achilles
            I'm glad to read that you find my plugin useful for your workflow.
            At the moment, I haven't made saving defaults available!
            I add this to my "To do list".
            Don't hesitate to buy me a coffee to support the project. 😄
            See you soon
