    LAYERS COLORS TO TEXTURE OR MATERIAL
    2 Posts 2 Posters 87 Views 2 Watching
      JTESTUDIO Newcomers
      HI THERE, I WANNA KNOW IF THERE ARE ANY EASY WAY TO CONVERT MY LAYERS COLORS TO MATERIALS.
      THANKS
        Please don't SHOUT at us !
        Typing everything in capital letters is considered to be bad-manners...
        Now to answer your question...
        Layers [Tags] can have colors set manually from your model's materials - including transparency and textures...
        But only their colors are accessible [get/set] through the Ruby API - i.e. not transparency or textures.
        SketchUp can have materials which include simple colors and textures - with or without transparency.
        So if you want to 'extract' your layer/tag colors with Ruby it is possible, then you can use the color' RGB data to make a new material in your model [perhaps named after the layer/tag name ?].
        However, although it's possible, it's not simple !
        There have previously been several threads discussing this... try searching the forums' posts...
        There are working code examples...
