    Medeek Project
    122 Posts 3 Posters 18.1k Views 4 Watching
    • medeekM
      medeek
      Version 1.0.1 - 01.14.2023
      • Added the Grid Tool to the main toolbar.
      • Enabled a parametric grid tool with major and minor grid lines.
      http://design.medeek.com/resources/images/project_su_menu_active.jpg
      http://design.medeek.com/resources/projectplugin/images/project_su6_800.jpg
      http://design.medeek.com/resources/projectplugin/images/project_su7_800.jpg
      I'm a huge fan of the free Grid Tool provided by SketchUp in the Extension Warehouse. However my only one complaint is that with a grid like this it is hard to visually tell how many units over you are when trying to measure out a house or any other structure. After giving it some thought, I concluded that major grid lines would go a long way in alleviating this one deficiency.
      I also thought it would be nice to include a grid tool in the plugin since it would eliminate the user from having to go out and install yet another plugin (ie. the SU Grid Tool) from the warehouse.
      I've created an updated version of this classic plugin by adding in major grid lines (that default to 4 feet and minor grid lines that default to 1 foot). Currently these settings are hard coded into the tool however one can easily edit a grid once created and modify both minor and major grid line parameters in both the x and y directions. I will eventually add a global settings tab for this tool so one can set the global defaults.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        First look at the project info tool:
        https://global.discourse-cdn.com/sketchup/original/3X/f/c/fc308bcbd10f1fab850cea5fd6bd0050bd05dbc7.jpeg
        I still have some major changes for the General tab. First and foremost I want to try in incorporate an interactive Google Maps window with a button to auto-geo locate based on the address that is input by the user. Then also have the ability to zoom the map as necessary and refine the geo-location on the map. Using the Google maps API I should be able to get the lat, long and elevation (which will be important for the determination of other site criteria).
        I've already done a good bit of programming using the Google API's on my website (running on my server) but this is something a bit new so I'm still uncertain if it will work within SketchUp. This should prove to be interesting.
        design.medeek.com
        • medeekM
          medeek
          Version 1.0.2 - 01.16.2023
          • Added the General Data tab to the Project Information tool.
          • Enabled a dynamic map (with geolocation) within the General Data tab of the Project Information tool.
          http://design.medeek.com/resources/projectplugin/images/project_su9_800.jpg
          This new feature is quite experimental so I am hoping for some feedback on it.
          design.medeek.com
          • medeekM
            medeek
            Version 1.0.2b - 01.16.2023
            • Fixed a bug with the Grid Tool and the Project Info Tool.
            !ATTENTION!
            This is a critical bug fix for the Grid Tool and the Project Info tool. Please download and replace the previous version of the plugin.
            design.medeek.com
            • medeekM
              medeek
              Version 1.0.2c - 01.17.2023
              • Fixed a namespace bug with the Grid Tool.
              design.medeek.com
              • medeekM
                medeek
                Version 1.0.2d - 01.19.2023
                • Optimized the Google Map API portion of the Project Info tool.
                • Choice of map type made persistent across different sessions.
                Tutorial 1: Introduction (20.01 min.)
                design.medeek.com
                • medeekM
                  medeek
                  First look at the EOR tab:
                  https://global.discourse-cdn.com/sketchup/original/3X/9/9/990e922ccf1166f6cd56682be616aade52192d7d.jpeg
                  design.medeek.com
                  • medeekM
                    medeek
                    First look at the AOR tab:
                    https://global.discourse-cdn.com/sketchup/original/3X/f/2/f22f24c9b235062932e4c487e0eb6c2fef1b358f.jpeg
                    design.medeek.com
                    • medeekM
                      medeek
                      First look at the Title Block tool in action:
                      https://global.discourse-cdn.com/sketchup/optimized/3X/a/b/abee7acd0b238ae14b26139de63585106a490ff5_2_690x436.jpeg
                      https://global.discourse-cdn.com/sketchup/optimized/3X/6/b/6b3b2795d4df24e9a5b6020f7f8b3023cc3ff82d_2_690x201.jpeg
                      Note that these title blocks are being drawn in SketchUp not Layout so they may only have limited utility but I think they still may be useful for those wanting to quickly throw together something for presentation purpose.
                      The Customer, Architect/Designer and Engineers data is pulled as the default but all of this information can be customized completely.
                      I call this title block a "no frills" title block, just a functional element that is simply meant to convey the most basic information.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 1.0.3 - 01.26.2023
                        • Added the EOR tab to the Project Information tool.
                        • Added the AOR tab to the Project Information tool.
                        • Added the Title Block Tool to the main toolbar.
                        • Added a parametric Title Block tool.
                        Let me know what you all think of this feature. Again I don't believe this should replace a proper Title Block in Layout but it will offer a quick and dirty solution in SketchUp for those who don't need or want to go into Layout.
                        I should probably also put out a short tutorial video on this feature and now it integrates with the Project Information data.
                        design.medeek.com
                        • medeekM
                          medeek
                          Tutorial 2 - Title Blocks (16:33 min.)
                          design.medeek.com
                          • medeekM
                            medeek
                            First look at the Seismic tab of the Project Info tool:
                            https://global.discourse-cdn.com/sketchup/original/3X/e/3/e3dac50a83a157e88e53d38fddaffb4536c767cb.jpeg
                            I wish my KML overlay was a little more transparent but it seems to work for now.
                            I just need to implement the code that connects to the USGS API which pulls all of this seismic data from their database.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 1.0.4 - 01.29.2023
                              • Added the Seismic tab to the Project Information tool.
                              • Added site parameters (Building Standard, Risk Category, Site Soil Class) to the General Data tab of the Project Information tool.
                              • Enabled the USGS lookup tool for the following standards: ASCE7-10, ASCE7-16, ASCE7-22.
                              This tab is not quite complete. I would like to add a button which allows one to automatically generate a PDF report with the seismic data. Most of the code for that tool/feature is already in place but I need to still figure out the details between the integration of my website and the back end Ruby connection with SketchUp.
                              Once that piece of the puzzle is added then this tool actually becomes useful in the real world.
                              design.medeek.com
                              • medeekM
                                medeek
                                Once you have enough information specified in the Seismic tab then the “Download PDF Report” button will appear:
                                https://global.discourse-cdn.com/sketchup/original/3X/0/6/06d5c30e5e2124344b2e92c28bd63fe088ff9ecd.jpeg
                                The PDF report will something like this (this one is actually a snow load report):
                                https://global.discourse-cdn.com/sketchup/optimized/3X/d/5/d521a169ab330eabd513010ad2bedbe70a587f39_2_383x500.jpeg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 1.0.5 - 02.04.2023
                                  • Enabled a PDF Seismic Report generator within the Seismic tab of the Project Information tool.
                                  https://global.discourse-cdn.com/sketchup/optimized/3X/0/5/0581531707e645a5b3ac8de2801e2e2ff8a110a2_2_384x500.jpeg
                                  https://forums.sketchup.com/uploads/short-url/n033ufC1CYEjTuq6zTHraGs6xX8.pdf
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Tutorial 3 - Seismic Reports (9:28 min.)
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 1.0.6 - 02.06.2023
                                      • Fixed a bug with the Title Block Tool.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 1.0.7 - 02.08.2023
                                        • Added optional labels (x-axis and/or y-axis) for major grid lines within the Grid Tool.
                                        http://design.medeek.com/resources/projectplugin/images/project_su23_800.jpg
                                        http://design.medeek.com/resources/projectplugin/images/project_su24_800.jpg
                                        This additional feature per customer request.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 1.0.8 - 02.12.2023
                                          • Added floor layers to the Layer Control Tool.
                                          http://design.medeek.com/resources/projectplugin/images/project_su25_800.jpg
                                          Note the Floor plugin has not yet been released, this update is in preparation for when it is released.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 1.0.8b - 02.13.2023
                                            • Fixed a bug in the Estimating module for king stud quantities for windows and doors (metric units).
                                            design.medeek.com
                                            • 1 / 7
