    Texture A Compound Curved Surface
    7 Posts 3 Posters 49 Views 3 Watching
    • Joe WoodJ Offline
      Joe Wood
      Folks! I forgot how to texture this compound curve roof surface, something about Importing the tex image, exploding it then painting the surface? Not having any luck!
      you can see how I hand stitched the compound roof plane, lots of clicks!
      1 roof texture.skp
      Joe Wood
      woodsshop.com/
        I set four examples of your texture at roughly the average slope of the roof and set the texture to be Projected. Then with the roof component open for editing, I sampled the texture from the appropriate circle and applied it to the roof.
        I also cleaned up the roof geometry filling in missing faces, correcting reversed faces, and getting rid of internal geometry so the roof is a solid component.1 roof texture.skp
        • panixiaP Online
          panixia
          You could easily map those curved surfaces if you just use Thrupaint plugin set to "Natural Mapping" method and "By surface" selection mode. πŸ‘
          • Joe WoodJ Offline
            Joe Wood
            I know nothing about mapping, could you explain that a little panixia?
            Joe Wood
            woodsshop.com/
            • Joe WoodJ Offline
              Joe Wood
              Right on Dave, thanks for explaining how to do that and fixing those things.
              why are reversed faces a problem?
              Joe Wood
              woodsshop.com/
                Face orientation affects the way some tools work, it can cause problems with many rendering applications and it's considered sloppy modeling.
                • panixiaP Online
                  panixia
                  Here's a comprensive video about thrupaint usage.
                  I guess you'll find it useful.
