    Catamaran
    156 Posts 12 Posters 35.7k Views 12 Watching
    • Bryan KB
      @joe wood said:
      You be launching her soon matey!
      Bryan, what's that forward boom? Don't think I've ever seen one on any boat.
      Thanks Joe!
      That's for a jib sail. Sometimes the jib sail is connected to the main mast and sometimes it's not. And sometimes it's connected to the mainsail boom and sometimes it's not. This design, from the plans, shows it connected to both. (I had to look this up)
      • Joe WoodJ
        Joe Wood
        yeah I think this is the same design as yours and it has that boom out front.
        https://www.nauticexpo.com/prod/pedigree-cats/product-20671-478489.html
        Joe Wood
        woodsshop.com/
        • Bryan KB
          @joe wood said:
          Wow check out the architects website! Some beautiful designs!
          Shuttleworth Design - Home
          Shuttleworth Design is a multi-award winning design consultancy that has been working with an international client base at the forefront of yacht design, engineering and naval architecture for more than 35 years. Yacht Designs. Multihulls, Monohulls, Superyachts, Catamarans, Trimarans. Power, Sail. Racing, Cruising. Boat Plans. John Shuttleworth, Orion Shuttleworth,
          (www.shuttleworthdesign.com)
          Yep. Shuttleworth seems to be a name associated with very nice boats. I did not know this when I picked it. It just looked nice and the plans were available for free.
          • Joe WoodJ
            Joe Wood
            where do you get the plans? Got a link?
            Joe Wood
            woodsshop.com/
            • Bryan KB
              That's it exactly. The Aero.
              Being my first boat, I'm taking some, uh, liberties with the design. ๐Ÿ˜†
              • Bryan KB
                Google search, plans for Shuttleworth Aero.
                What you see in my posts are all I could find. Each image had to be scaled when imported.
                • Bryan KB
                  More detailing and proportion change of some objects. And example was the radar bridge was too tall.
                  Hull sections committed and exploded to join all pieces in order to create waterline paint stripe.
                  Fore-deck and helm details next and rigging for very last.
                  • tuna1957T
                    tuna1957
                    Things are really coming together Bryan. Excellent work ๐Ÿ‘
                    • Bryan KB
                      Thanks tuna!
                      Stern steps completed. Non-slip pads are the black rectangles.
                      Vector Push/Pull to move the stern bulkhead forward and then stairs made with triangles on center-line and the regular Push/Pull to extrude outward. Then some fiddling with the outboard edges to get them flush to inner hull. Then Bevel tool on the step edges. Not perfect geometry, but it will pass a close up.
                        Coming along nicely, she looks great. ๐Ÿ‘ ๐Ÿ‘
                        • marked001M
                          marked001
                          We've definitely moved beyond my modeling ability..haha.. great work.
                          http://www.revision21vis.com
                          instagram: revi21on
                          • Bryan KB
                            Thanks marked001!
                            I could not have done this without Curviloft, Tools On Surface, Pipe Along Path and Joint Push/Pull. I also had all that practice with the Nadesico. I realized is was just a space catamaran. ๐Ÿ˜†
                            • Bryan KB
                              Thanks mike!
                              • Bryan KB
                                Several updates:
                                Helm finished. Instruments from the 3D Warehouse.
                                Added aft berths portals. Began mast rigging. Re-proportioned fore deck/net cross beam. Made the top hatches thinner. Will do hull portals and beach ladder next. Fore deck webbing will be last. I expect it will make the model "heavy" so I'm leaving it to last.
                                • tuna1957T
                                  tuna1957
                                  Moving right along ! Most excellent ๐Ÿ‘ ๐Ÿ‘
                                  • Bryan KB
                                    Thanks tuna!
                                    • Bryan KB
                                      Update.
                                      The portals were not easy thanks to all the geometry created by Curviloft. You would think Intersect would work and it sort of did, but I forgot to make my inner hull halves unique and yep, portals where I didn't want them. Hours of fixing. But then the new paint line wouldn't track the same on the new unique parts and then had to fix that! And then Joint Push/Pull (to indent the portals) had issues because of the geometry and had to fix that! Live and learn. Meh.
                                      • tuna1957T
                                        tuna1957
                                        Looking great ! All it needs is a pirate flag and a cannon strapped to the frontโ€ฆ ๐Ÿ˜† ๐Ÿ‘
                                        • Bryan KB
                                          Thanks tuna!
                                          Arrggghh!
                                          • L
                                            Love it Bryan ๐Ÿ‘ Will you be doing an interior?
                                            • 5 / 8
