    A home office/study area.
    12 Posts 5 Posters 175 Views 5 Watching
      I think I am geting closer so have moved this to the Gallery.
        Well, I think I'm done with this now.
        • ntxdaveN Offline
          ntxdave
          πŸ‘ πŸ‘
          Press F1...thank me later
          • tuna1957T Offline
            tuna1957
            πŸ‘ good job
            • Bryan KB Offline
              Well done!
                Hi Mike, the colour temperature of those lamps would be in the 2500-2700k range, so pretty orrange kind of cast.
                  Thanks folks, Liam, I meant to do something like that but it went right out of my mind. Not so finished as I thought but I need these luittle nudges to get me further along.
                  It's a privelege folks.
                  β˜€
                    I changed the light temp but not very close it seems. Closeup anyone Mr Devillain?
                      A re render for a mate.
                      • ntxdaveN Offline
                        ntxdave
                        I like the model and render except the lamps are a little too pink for me.
                        Still πŸ‘ πŸ‘ is appropriate to me.
                          Hi Mike the camera angle is better maybe down a bit more. I do not know which Render Engine you use but can't you dial-in the colour temperature?
                            The glass is not coloured, there is an emitter type in Twilight V2 to mimic the gas lamp, I need to find a way to adjust the temp for a better facsimile. Going by temp gives the result you see.
