    Joint push pull/ textured faces
    14 Posts 3 Posters 2.3k Views 3 Watching
      It behaves as expected for me...
      https://i.imgur.com/CdYA0HA.png
      Here's a full rollout of what default options...
      https://i.imgur.com/J5fMmhc.png
        Its also worth mentioning you have reversed faces for the 'glass'
        https://i.imgur.com/O8JKkYS.png
        So that and the surface selection method could lead to crazytown
          Mandryka03
          Thanks for your close observation and your hint.
          Adjusting front and back faces did not solve the problem entirely.
          See the new screenshot.
          Notably there appears a new edge connecting the two "bottom glasses" after using j push pull.
          The blue colour is not recognized correctly for the left bottom glass, instead the newly created interior wall gets blue.
          I played around with several options, but the image below shows the "best" result.
          Probably this issue does not refer to the function.
          If you have any idea concerning graphic trouble, please tell me.
          Regards, Christoph
            Send us the .skp after you get the unwanted result. Your earlier file behaves as expected for me. So having your output might highlight what is happening. So if you can make a file like this...
            https://i.imgur.com/QQEPqCl.png
            That way we see both the source geometry and your result.
            One added observation I noticed is errant vertices.
            https://i.imgur.com/OhObrs2.png
            To me it's a case of Reversed Faces + Errant Vertices = Crazy Result
              Mandryka03
              In the attachment you see the window with adjusted faces and the structure
              after employing joint push pull ( produced from a copy of the first).
              The vertices you mentioned belong to faces adjacent to the window. A part of the facade pattern
              of the building model is visible on the screenshot 1 attached in my opening message.
              From my point of view the referred vertices are not errant, because if I would remove the edges to these points the other faces of the facade would be destroyed.
              Thank you for your patience.
              Regards, Christoph
              demo.skp
                Modelling efficiently and in isolation is the preferred way in SketchUp. One continuous lump of geometry to represent many repeatable elements is hard to maintain.
                But if we ignore that, your issue still needs to be explained. In your case you will get 'funky' results if the Face Selection and Finishing methods are not a sensible setting.
                https://i.imgur.com/3Wazokh.png
                Here's an example if I set Face Selection to All Connected Faces and the Finishing to Erase Original for this panel on the left...
                https://i.imgur.com/G8Lslk9.png
                ...now when I hover the geometry JPP will select every face and extrude it and delete the original...
                https://i.imgur.com/h3oYexZ.png
                As you can see the final result is 'funky'.
                https://i.imgur.com/zDpxsiw.png
                To get consistent results you need consistent geometry. A mixture of errant vertices, materials and finishing methods can lead to confusion for JPP.
                With some added discipline to your modelling methods, like grouping geometry to prevent it influencing it's surroundings. Or components for repeated elements would yield consistent outcomes.
                  Mandryka03
                  Removing the "errant" vertices and using groups/components did not resolve the issue.
                  The funky results remain unchanged.
                  Maybe my skills and my experience are too poor for this kind of "problems".
                  So I do not want to waste your time with this question.
                  Thank you for your efforts.
                  Regards, Christoph
                  • BoxB
                    The only way I can replicate your issue is by selecting too many faces and the incorrect finishing.
                    I suspect the material, the blue in particular, is hiding your error and you are selecting too much. Or simply expecting something that doesn't happen.
                    You actually don't need JPP if you just want to thicken the frame, as I've shown here.
                    Make sure what you are selecting when using it and that you have the Finishing set to produce both faces.
                    And as Rich mentioned, you should be grouping or componenting things as you go or you'll run into many errors.
                      Mandryka03
                      Thank you for your explanation.
                      My goal of using jpp is pushing all connected four faces ( white frame plus three glass faces) through the wall so that all these elements stay coplanar. The materials assigned to the faces should be maintained. The original face has to be erased. The result would be a facade consisting of the wall and windows shifted back ( by 10 cm).
                      The model to the right shows the geometry, but lacks some faces/ textures.
                      So I do not want to thicken the windows frame.
                      Possibly the easiest solution is either to restore errant results or to use push pull four times in sequence.
                      Thank you again for your patience.
                      • BoxB
                        Perhaps you just need to learn about components and how to make ones that cut a face.
                          Mandryka03
                          Certainly you are right. Though there is no need for me, I will learn a lot by doing and attempting different approaches.
                          Have a nice sunday. Regards from Austria
