    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    453 Posts 112 Posters 628.9k Views 113 Watching
    • V
      virtualbreizh
      Bonjour Samuel,
      Merci pour votre plugin, cependant je n'arrive pas à le faire fonctionner sur Sketchup 19 Pro sur Mac. Je vois bien l'extension dans la liste des extensions mais la seule option disponible est "faire un don à l'auteur de l'extension" (ce que j'ai d'ailleurs fait 😉 )
      Tristan Langlois
      • samuel_tS
        samuel_t
        @virtualbreizh said:
        Bonjour Samuel,
        Tristan Langlois
        Hello Tristan,
        You don't need to donate. This plugin is free. In SketchUp menu, use "File > Import with Universal Importer...". Do you want a refund?
        Bonjour Tristan,
        Vous n'avez pas besoin de faire un don. Cette extension est gratuite. Dans le menu de SketchUp, utilisez "Fichier > Importer avec Importateur Universel...". Voulez-vous être remboursé ?
        • samuel_tS
          samuel_t
          @gomo25mail said:
          Hello, great idea, BUT when I tried to reduce the face count on many items, they only went up in face count.
          Windows 11, SketchUp Make 2017.
          Example: Used a simple vehicle (Jeep.skp) with 7537 faces. Tried to reduce to 4000. Ended up with more faces.
          Hello. Can you please send me this "Jeep.skp", as it is before polygon reduction attempt?
          • samuel_tS
            samuel_t
            Hello, I just released 1.1.8 version of SketchUp Universal Importer plugin 🎉 It automatically imports missing textures, even if they are in neighboring folders:
            Old versions asked too many questions! Sometimes, dozens of dialog boxes were displayed 😠 To speed up workflow, I added options that one can enable or disable from "Extensions > Universal Importer" menu.
            Model is no longer resized. I may turn this model height question into an option but I would prefer to find an automatic solution to this issue.
            Under macOS, model now seems to be imported right side up.
            Universal Importer plugin is now compatible with Lord Of The Toolbars plugin from Fredo6.
            There are less copies of temporary files. I will develop the next versions in this direction. Hard drive will be less stressed... 😄
            Download latest Universal Importer plugin from SketchUcation PluginStore.
              Nice update!
              I'll test some stuff I know usually doesn't play nice.
              • samuel_tS
                samuel_t
                1.1.9 version fixes import of textures stored in non-system disk partitions, e.g. D:\path\to\texture.jpg
                  Works for but .blend files throw an error....
                  https://i.imgur.com/bHVy9Nk.png
                  This is on Blender 3.2.1 files. Even a simple cube fails
                  cube.zip
                  • Didier BurD
                    Didier Bur
                    Hi Samuel,
                    Since I updated to v1.1.8, I always got this message:
                    It happens no matter the file or its path, or the file format. In the above case, the file gou.mtl exists at the correct location.
                    Any idea ? Do I have to uninstall the previous version ?
                    Thanks in advance,
                    DB
                    • samuel_tS
                      samuel_t
                      @Rich Thanks for your report.
                      .blend v3 files are no yet supported.
                      And .blend v2 support isn't very good, but next Universal Importer versions will support them better 😄
                      In meanwhile, if you have only a .blend file as source: I recommend to first export this source to .fbx or .gltf from Blender, because FBX/glTF support is rather good in current Universal Importer version.
                        satemorej
                        I have just installed Universal Importer.
                        I guess I missed some setting steps as whatever the file I try to import, there is an error message.
                        SKETCHUP PRO 2017 / MACOS Catalina
                        Thanks for your help
                        Best regards
                        Jerome
                          satemorej
                          I have installed Universal Importer today.
                          I am rather used to installing plugins but I guess I may have missed something.
                          Whatever the file or file type I try to import, I get an error message.
                          Regards
                          Jerome
                          MACOS Catalina / sketchup pro 20217
                          • samuel_tS
                            samuel_t
                            @satemorej said:
                            Best regards
                            Jerome
                            Hi Jérôme,
                            Did you also try to import a file in a "popular" format such as OBJ, FBX or glTF?
                            Compatibility with STEP format is low else broken... See this issue on GitHub.
                            Best regards,
                            Samuel
                              satemorej
                              @samuel_t said:
                              @satemorej said:
                              Best regards,
                              Samuel
                              Hello,
                              I undestand for STEP format lower compatibility.
                              As you suggested, I have tried with two obj files found on 2 different web sites.
                              It works for one, it does not for the other one.
                              Please see error message in attached file.
                              Feel free to provide me link to test obj files. I may test them if you think it helps.
                              Best regards
                              Jerome
                              • samuel_tS
                                samuel_t
                                Hello @satemorej
                                The compatibility with the OBJ format is high.
                                Can you, please, send me the files producing this error?
                                https://sketchucation.com/forums/download/file.php?id=168290&mode=view/rokbox.jpg
                                I would like to inspect every file (.obj, .mtl and textures) in the archive you downloaded.
                                  satemorej
                                  Hello
                                  @samuel_t said:
                                  Hello @satemorej,
                                  Here is the link to the obj file that causes my error.
                                  https://www.artec3d.com/fr/3d-models/bearded-guy-hd
                                  Best regards
                                  Jerome
                                  • samuel_tS
                                    samuel_t
                                    Hello Jérôme,
                                    I inspected the ".obj" file mentioned in your last message. It contains an empty "mtllib" statement, on line 7. This causes the "copy_stream" error...
                                    While waiting for a fix in my plugin code, here is a workaround:
                                    • Open the file "Bearded guy.obj" with a simple text editor.
                                    • Delete line 7 (mtllib) then overwrite the file.
                                    • Import the file again with the plugin.
                                    • Didier BurD
                                      Didier Bur
                                      Hi Samuel,
                                      Thanks again for this cool plugin 😄
                                      I use UniversalImporter to import an OBJ file that is exported from MeshMolder.
                                      As you can see on the images, the 435488 triangles from MM are converted to a 86702 triangles mesh in SU. But when importing, UI does say "The file has 435488 faces. Do you want to reduce the number of faces ?". The triangles decimation occurs even if I answer "No" to this message.
                                      Do I miss something or is there a face count limit in UImporter ?
                                      MeshMolder
                                      SketchUp
                                      DB
                                      • samuel_tS
                                        samuel_t
                                        Hi Didier,
                                        No, I didn't put such a limit in the Universal Importer plugin.
                                        For information, polygon reduction is done thanks to MeshLab.
                                        If you target 200 000 faces when the plugin proposes a polygon reduction, what is the final result in SketchUp?
                                        • Didier BurD
                                          Didier Bur
                                          Hi Samuel,
                                          I'll try with a 200k faces mesh as time permits.
                                          I've tried with TIG's "OBJ Importer" plugin and it doesn't decimate the triangles. Cool 😎
                                          Regards,
                                          DB
                                          • Didier BurD
                                            Didier Bur
                                            Hi Samuel,
                                            Here are the results with a 200k triangles mesh:
                                            The triangles loss is far less than with a 400k mesh, but it is still there.
                                            Regards,
                                            DB
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 22
                                            • 23
                                            • 17 / 23
