    'AUTOMATING" SAVE/RELOAD
    4 Posts 2 Posters 1.9k Views 2 Watching
      Mark ADDS
      My work is typically residential building design.
      My work process:
      • a "Base" SU drawing that has all geometry
      • a "Plans & Sections" SU drawing with Scenes, Styles, etc that the Base is loaded into
      • a Layout drawing for CDs and presentation that references P&S
      Once a project is well underway and I am refining and correcting, I may, for example, find a misplaced window while dimensioning in LO. I will typically have both SU drawings open. I go the the Base drawing, make the correction, Save, Reload Base in Plans & Sections, Save, Update reference in LO.
      Many times in a session.
      Any thoughts on "automating" this process?
      Thanks.
        Have you tried TIG's Xref Extension?
        SketchUp Plugins | PluginStore | SketchUcation
        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
        (sketchucation.com)
          Mark ADDS
          Thanks for the suggestion. I have not tried that extension though I am a fan of TIG's work.
          After looking over the documentation it does not appear to me that XREF "status" would impact the process I am looking to streamline. In terms of "click reduction".
            No, its more of a monitoring tool. What you need is a GIT type environment that pushes commits to the master from branches.
            Version control within SketchUp's ecosystem is something I hope they implement to meet the needs of small teams that live/work in the ecosystem.
            Speckle - Intelligent design data layer for AEC
            Speckle is the design data platform for AEC: connect Revit, Rhino, IFC and more, validate every model version automatically, and ask AI questions of live model data.
            Speckle (speckle.systems)
            This is the type of system I'm talking about where interoperability between file formats and teams is seamless.
            Maybe a command line tool could be developed to monitor file changes and push them around as needed.
            The other thing would be a macro via Auto Hotkey that did what you do manually when you execute it.
            All rather flaky solutions tbh... πŸ˜•
