    The Nadesico A
    194 Posts 10 Posters 53.2k Views 10 Watching
    • Bryan KB Offline
      Thanks as always Mike! πŸ‘
      • Bryan KB Offline
        2 more views.
        • Bryan KB Offline
          Rear engine pods block-out completed. Also testing smoothing using Erase+ctrl on lines. Did not change geometry at this stage.
          Not committed to this smoothing just yet. Just testing. It might be good for some places where Curviloft might not be needed.
          Man did I have to fiddle with those rear hook things. Total different shape than the front ones.
          • tuna1957T Offline
            tuna1957
            Nice πŸ‘ now I’ll go quietly wait in my corner for the renders πŸ˜†
            • Bryan KB Offline
              ...but your children may be grown by the time I finish this one. πŸ˜†
              I was doing some other preliminary smoothing tests and, man, have I got trouble. Curviloft worked great on the nose of the front nacelles, but another section toward the rear of the front nacelles are going to require complete rebuilds.
              No problem though. I'm really learning new things on this one. πŸ‘ It's also the cleanest complex build I've done to date. Minimal stray line to hunt down and erase, that sort of thing.
              • Bryan KB Offline
                Damn. I am really excited about this model. I want to keep working on it non-stop.
                Nope. Got to call it a night. 😎
                • L Online
                  Epic Bryan, I know about not being able to put it down πŸ˜‰ Have you saved it to an external thumb drive?
                  • Bryan KB Offline
                    Thanks L i am. πŸ‘
                    I do indeed have an external backup store on my desk. I also used Google Drive.
                    • Bryan KB Offline
                      HA! Did I get lucky!
                      So a combination of Curviloft for some areas and Erase+ctrl for larger flat areas seems to do the trick. I rebuilt the problem sections far faster than I anticipated. Far faster and they look soooo much better!
                      Thanks to the changes I was able to make the large black holes on the lower section flat and make a clean Push/Pull indent as well. Also able to straighten out a lot of other areas that were kind of jagged. OK, they were very jagged.
                      Well huh. I'm already halfway through clean up far faster than I would have thought!
                      • Bryan KB Offline
                        Partially complete detailing rear engine pods. I'm happy with them so I started detailing but will stop here for now and move on to the next sections.
                        Mostly just blocks with some very basic angle shaping and some Joint Push/Pull to help with the weird angles. So MANY weird angles on this thing.
                        Then Tools on Surface for some of the other blocks.
                        Also widened the rear center thingies and change the geometry just a tiny bit to better match my references.
                          πŸ˜„ πŸ‘
                          • Bryan KB Offline
                            @mike amos said:
                            πŸ™‚ πŸ‘
                            It's getting there!
                            • Bryan KB Offline
                              Overview.
                              Go back to the bottom of the previous page to see the rear engine details.
                              • Bryan KB Offline
                                Completed the rear engine struts. There is no right or wrong way to make these. There were no good references except that I could see it's sort of a wing-thing and the top profile is about "that" big.
                                • Bryan KB Offline
                                  2 more views.
                                  • Bryan KB Offline
                                    Alright! On to the neck and bridge decks!
                                    • L Online
                                      πŸ‘ πŸ‘ πŸ‘ πŸ˜„
                                      • Bryan KB Offline
                                        @l i am said:
                                        :thumb: πŸ‘ πŸ‘ πŸ˜„
                                          Very sharp but you put a lot into them. Definitely very nice to see mate. πŸ‘Š πŸ‘
                                          • Bryan KB Offline
                                            Thanks Mike!
                                            • 5 / 10
