🤑 30% Off | Artisan 2 on sale until April 30th Buy Now
Man
10 Posts 3 Posters 2.6k Views
    djh
    Is there any way to make the man in the Man.skp look like the man in the Man.jpg?
    I don't want to have to File/Export/2DGraphic/*.jpg and then alter the appearance using a photo-editing program. Can it be done in SU?
    Man.skp
      djh
      Here's the original file, Man. skp.
      Man.skp
        You can trace around the figure using the edge, freehand and arc tools and remove the background.
          djh
          Box, thanks for replying.
          Sorry, I don't quite understand what you suggested.
            Ok, I don't quite understand what you are asking for.
              djh
              Box, I'm sorry my question wasn't clear.
              I would like to make the men in the SKP file without any lines or shading - just one solid color as in the JPG.
              Man 002.skp
                djh
                Is it possible?
                This is how it looks in SU.
                Can one make it look like this in SU?
                  Do you mean something like this?
                    djh
                    Can one make the man without shadows and lines in SU and leave it as a 3D object?
                    Man 003.skp
                      sfto1
                      If you uncheck edges and profiles in the styles dialog box and uncheck the cast shadows in the entity info dialog box after you select the "man" these are the results.
                      Not sure if this is what you are after.
