Divide a face for displacement map
Hello everyone,
For a displacement map to work, the faces must be split or gridded.
Is there a plugin to automatically square or divide a face just by clicking on it?
The conveniently named Split Tools ala TIG
Not completely automatic, but you can use "connect edges" of the "QuadFaceTools" in two directions
https://sketchucation.com/pluginstore?pln=QuadFaceToolsOr if you have "SUbD", you can subdivide a face a couple of times and then convert it to normal geometry
https://evilsoftwareempire.com/subd/manual/entity-info#subdivisions
https://evilsoftwareempire.com/subd/manual/convert-to-plain-mesh -
Thank's a lot !!
