    3D Truss Models
    1.5k Posts 32 Posters 1.9m Views 31 Watching
    • medeekM
      medeek
      Version 3.0.7 - 01.25.2022
      • Added energy/raised heels for 4/2 scissor trusses (1 variant: vertical w/ strut).
      http://design.medeek.com/resources/trussplugin/images3/truss_su759_800.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 3.0.8 - 01.29.2022
        • Added ceiling gypsum and ceiling battens to all floor assemblies.
        http://design.medeek.com/resources/trussplugin/images3/truss_su761_800.jpg
        I am still working on the new floor plugin however in the meantime it was not difficult to add the gypsum option to the existing floor truss/joist module.
        This feature added per customer request.
        design.medeek.com
        • medeekM
          medeek
          Version 3.0.9 - 02.09.2022
          • Enabled soffit and fascia for hip truss sets.
          • Fixed a minor bug with the hip truss set module.
          • Removed the Gutter Extension parameter from the hip truss set edit menu.
          http://design.medeek.com/resources/trussplugin/images3/truss_su762_800.jpg
          design.medeek.com
          • medeekM
            medeek
            The last few months have been mostly focused on the Wall Plugin and I have not spent much time on the Truss Plugin. There are still quite a few truss types that do not have advanced options enabled as well as the edit function (ie. monopitch scissor). Some of these truss types are not as commonly used and therefore there has been less pressure to work on them however I would like to get all of the truss and roof types up to speed so I will spend a few weeks doing that. I appreciate everyone's patience in this regard, there are still so many things to check off on the todo list for this plugin.
            design.medeek.com
            • medeekM
              medeek
              Version 3.1.1 - 02.13.2022
              • Enabled advanced options for mono scissor trusses.
              • Enabled the "Edit Truss Assembly" function for all mono scissor trusses (imperial and metric units).
              http://design.medeek.com/resources/trussplugin/images3/truss_su764_800.jpg
              Also note that one can adjust the bottom chord pitch to be the same as the top chord pitch and with a raised heel (ie. 24") you can effectively create shed roof parallel chord trusses:
              http://design.medeek.com/resources/trussplugin/images3/truss_su765_800.jpg
              design.medeek.com
              • G
                GFXS
                I've been waiting for this update -- to date I've been having to manually edit trusses to add the raised heel. Though it's still missing another component that I need: For the heel blocking, could there be an option for a truss block instead of just LVL or whatever the default solid lumber. Also, an option to have the truss block on the high end and/or low end of the span (or just LVL/solid lumber for the low end). The truss block is common for many of our projects where a tall heel is required.
                Thanks for your hard work and dedication on updating these plug-ins. Best regards.
                • medeekM
                  medeek
                  Let me give this some further thought. I like the idea of providing another option for truss blocking.
                  Here are a couple examples of manufactured metal plated panels:
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 3.1.2 - 02.15.2022
                    • Enabled MPC wood blocking panels for common trusses.
                    http://design.medeek.com/resources/trussplugin/images3/truss_su767_800.jpg
                    If your heel height exceeds 15" and you have selected "Vertical" heel blocking as your orientation, then rather than solid blocks the plugin will now insert MPC blocking panels instead.
                    I still need to enable heel blocking and blocking panels for various other truss types and also make this available for rafter roofs as well.
                    design.medeek.com
                    • G
                      GFXS
                      Wow! That was fast! Will update the plug-in and play around with this new truss blocking feature. In my post requesting this, I forgot to ask about adding purlins and a second layer of gypsum at the ceiling. The second layer of gypsum for fire-rated assemblies (though a work-around I've used is to show a thicker first layer of gypsum or copying the first layer). I look forward to further developments to the truss plug-in.
                      Thank you and best regards.
                      • medeekM
                        medeek
                        Version 3.1.3 - 04.10.2022
                        • Enabled 3D roof and wall cladding materials for monopitch trusses.
                        • Fixed a bug with the valley set detection option.
                        http://design.medeek.com/resources/trussplugin/images3/truss_su768_800.jpg
                        http://design.medeek.com/resources/trussplugin/images3/truss_su769_800.jpg
                        design.medeek.com
                          mpacey
                          I had a project today that I really could have used a 6/12 pitch monotruss for. Have you considered making the pitch configurable? I'm getting more and more "modern" designs with combinations of different pitches of roofs, in different configurations.
                          • medeekM
                            medeek
                            Once you have created a truss assembly you can edit it and adjust the pitch to any pitch you like or even fractional pitch somewhere in between.
                            design.medeek.com
                              mpacey
                              Thank you, Nathaniel.
                              I learn something new every day.
                              • medeekM
                                medeek
                                Version 3.1.4 - 04.27.2022
                                • Fixed a minor bug with the advanced options for scissor trusses.
                                • Updated the scissor truss module so that raised heel trusses are properly rendered/drawn.
                                http://design.medeek.com/resources/trussplugin/images3/truss_su770_800.jpg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 3.1.5 - 05.07.2022
                                  • Enabled 3D roof and wall cladding materials for attic trusses.
                                  http://design.medeek.com/resources/trussplugin/images3/truss_su771_800.jpg
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 3.1.6 - 06.05.2022
                                    • Enabled ceiling insulation for common trusses: Batt, Blown-in.
                                    • Enabled ceiling insulation for monopitch trusses: Batt, Blown-in.
                                    • Added an insulation layer in the global settings.
                                    http://design.medeek.com/resources/trussplugin/images3/truss_su774_800.jpg
                                    http://design.medeek.com/resources/trussplugin/images3/truss_su775_800.jpg
                                    http://design.medeek.com/resources/trussplugin/images3/truss_su773_800.jpg
                                    I still have a lot of work with regards to insulation and numerous other truss types and rafter roofs.
                                    design.medeek.com
                                    • gullfoG
                                      gullfo
                                      nicely done - probably need "sprayed foam" insulation which would be incorporated into the rafters as well as joists + combinations. here in FL it's pretty common to have a layer of pink stuff in the joists against the drywall ceiling, then 1-2 ft of blown-in insulation. newer construction seems to use a lot of sprayed insulation on the rafter/sheathing but still using the pink and/or blown-in on the joists.
                                      Glenn
                                      http://www.runnel.com
                                      • medeekM
                                        medeek
                                        Version 3.1.8 - 08.29.2022
                                        • Added a parameter into the general tab of the global settings to allow for adjustment of the size of labels and annotations.
                                        • Added a parameter into the general tab of the global settings to allow for adjustment of the font for text found within annotations and labels.
                                        • Added a "resolution" parameter into the general tab of the global settings for adjusting the smoothness of annotation text.
                                        • Added a "Label Rotation" parameter (0 or 180 degrees).
                                        • Enabled various annotation options/parameters for truss roofs.
                                        http://design.medeek.com/resources/trussplugin/images3/truss_su778_800.jpg
                                        http://design.medeek.com/resources/trussplugin/images3/truss_su777_800.jpg
                                        Basically just bringing some of the annotation formatting options over from the Wall Plugin. I will still need to enable these options for rafter roofs, hip sets and complex roofs. This update per user request.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 3.1.9 - 11.25.2022
                                          • Enabled subtractive geometry for all shed rafter roofs.
                                          http://design.medeek.com/resources/trussplugin/images3/truss_su779_800.jpg
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 3.2.0 - 11.28.2022
                                            • Fixed a minor bug with the roof cladding thickness parameter when the materials option is toggled off.
                                            http://design.medeek.com/resources/trussplugin/images3/truss_su780_800.jpg
                                            Strange that I never noticed this bug before but I guess most of us turn on the materials option so that is probably why no one ever really noticed. I highly recommend turning on the materials options to get the full bang for your buck out of the plugin but in the rare chance you don't want to this bug fix will take care of the previous issue reported above.
                                            design.medeek.com
                                            • 69
                                            • 70
                                            • 71
                                            • 72
                                            • 73
                                            • 76
                                            • 77
                                            • 71 / 77
