    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • jujuJ
      juju
      @medeek said:
      Version 3.0.4 - 10.23.2021
      • Added error checking code into various HTML menus for roof and wall materials.
      Is this up on your website yet? Doesn't seem like it?
      v3.0.4 not
      • medeekM
        medeek
        Okay, check it now.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM
          medeek
          Version 3.0.5 - 11.03.2021
          • Added additional energy/raised heels for double fink truss (2 variants: wedge and slider).
          Apparently when I added in the raised heel algorithms for this truss type a couple years ago I only added in the vert with strut option. It was brought to my attention a couple days ago that the other two options were missing. I apologize for the delay in making sure all three options were available for this truss type. We should be good to go now with the double fink truss.
          design.medeek.com
          • medeekM
            medeek
            Version 3.0.6 - 11.30.2021
            • Added ceiling gypsum to shed and shed w/ ledger rafter roofs.
            • Enabled ceiling gypsum for all shed rafter roofs with ceiling joists enabled.
            http://design.medeek.com/resources/trussplugin/images2/truss_su756_800.jpg
            http://design.medeek.com/resources/trussplugin/images2/truss_su757_800.jpg
            http://design.medeek.com/resources/trussplugin/images2/truss_su755_800.jpg
            http://design.medeek.com/resources/trussplugin/images2/truss_su758_800.jpg
            design.medeek.com
            • medeekM
              medeek
              Version 3.0.7 - 01.25.2022
              • Added energy/raised heels for 4/2 scissor trusses (1 variant: vertical w/ strut).
              http://design.medeek.com/resources/trussplugin/images3/truss_su759_800.jpg
              design.medeek.com
              • medeekM
                medeek
                Version 3.0.8 - 01.29.2022
                • Added ceiling gypsum and ceiling battens to all floor assemblies.
                http://design.medeek.com/resources/trussplugin/images3/truss_su761_800.jpg
                I am still working on the new floor plugin however in the meantime it was not difficult to add the gypsum option to the existing floor truss/joist module.
                This feature added per customer request.
                design.medeek.com
                • medeekM
                  medeek
                  Version 3.0.9 - 02.09.2022
                  • Enabled soffit and fascia for hip truss sets.
                  • Fixed a minor bug with the hip truss set module.
                  • Removed the Gutter Extension parameter from the hip truss set edit menu.
                  http://design.medeek.com/resources/trussplugin/images3/truss_su762_800.jpg
                  design.medeek.com
                  • medeekM
                    medeek
                    The last few months have been mostly focused on the Wall Plugin and I have not spent much time on the Truss Plugin. There are still quite a few truss types that do not have advanced options enabled as well as the edit function (ie. monopitch scissor). Some of these truss types are not as commonly used and therefore there has been less pressure to work on them however I would like to get all of the truss and roof types up to speed so I will spend a few weeks doing that. I appreciate everyone's patience in this regard, there are still so many things to check off on the todo list for this plugin.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 3.1.1 - 02.13.2022
                      • Enabled advanced options for mono scissor trusses.
                      • Enabled the "Edit Truss Assembly" function for all mono scissor trusses (imperial and metric units).
                      http://design.medeek.com/resources/trussplugin/images3/truss_su764_800.jpg
                      Also note that one can adjust the bottom chord pitch to be the same as the top chord pitch and with a raised heel (ie. 24") you can effectively create shed roof parallel chord trusses:
                      http://design.medeek.com/resources/trussplugin/images3/truss_su765_800.jpg
                      design.medeek.com
                      • G
                        GFXS
                        I've been waiting for this update -- to date I've been having to manually edit trusses to add the raised heel. Though it's still missing another component that I need: For the heel blocking, could there be an option for a truss block instead of just LVL or whatever the default solid lumber. Also, an option to have the truss block on the high end and/or low end of the span (or just LVL/solid lumber for the low end). The truss block is common for many of our projects where a tall heel is required.
                        Thanks for your hard work and dedication on updating these plug-ins. Best regards.
                        • medeekM
                          medeek
                          Let me give this some further thought. I like the idea of providing another option for truss blocking.
                          Here are a couple examples of manufactured metal plated panels:
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 3.1.2 - 02.15.2022
                            • Enabled MPC wood blocking panels for common trusses.
                            http://design.medeek.com/resources/trussplugin/images3/truss_su767_800.jpg
                            If your heel height exceeds 15" and you have selected "Vertical" heel blocking as your orientation, then rather than solid blocks the plugin will now insert MPC blocking panels instead.
                            I still need to enable heel blocking and blocking panels for various other truss types and also make this available for rafter roofs as well.
                            design.medeek.com
                            • G
                              GFXS
                              Wow! That was fast! Will update the plug-in and play around with this new truss blocking feature. In my post requesting this, I forgot to ask about adding purlins and a second layer of gypsum at the ceiling. The second layer of gypsum for fire-rated assemblies (though a work-around I've used is to show a thicker first layer of gypsum or copying the first layer). I look forward to further developments to the truss plug-in.
                              Thank you and best regards.
                              • medeekM
                                medeek
                                Version 3.1.3 - 04.10.2022
                                • Enabled 3D roof and wall cladding materials for monopitch trusses.
                                • Fixed a bug with the valley set detection option.
                                http://design.medeek.com/resources/trussplugin/images3/truss_su768_800.jpg
                                http://design.medeek.com/resources/trussplugin/images3/truss_su769_800.jpg
                                design.medeek.com
                                  mpacey
                                  I had a project today that I really could have used a 6/12 pitch monotruss for. Have you considered making the pitch configurable? I'm getting more and more "modern" designs with combinations of different pitches of roofs, in different configurations.
                                  • medeekM
                                    medeek
                                    Once you have created a truss assembly you can edit it and adjust the pitch to any pitch you like or even fractional pitch somewhere in between.
                                    design.medeek.com
                                      mpacey
                                      Thank you, Nathaniel.
                                      I learn something new every day.
                                      • medeekM
                                        medeek
                                        Version 3.1.4 - 04.27.2022
                                        • Fixed a minor bug with the advanced options for scissor trusses.
                                        • Updated the scissor truss module so that raised heel trusses are properly rendered/drawn.
                                        http://design.medeek.com/resources/trussplugin/images3/truss_su770_800.jpg
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 3.1.5 - 05.07.2022
                                          • Enabled 3D roof and wall cladding materials for attic trusses.
                                          http://design.medeek.com/resources/trussplugin/images3/truss_su771_800.jpg
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 3.1.6 - 06.05.2022
                                            • Enabled ceiling insulation for common trusses: Batt, Blown-in.
                                            • Enabled ceiling insulation for monopitch trusses: Batt, Blown-in.
                                            • Added an insulation layer in the global settings.
                                            http://design.medeek.com/resources/trussplugin/images3/truss_su774_800.jpg
                                            http://design.medeek.com/resources/trussplugin/images3/truss_su775_800.jpg
                                            http://design.medeek.com/resources/trussplugin/images3/truss_su773_800.jpg
                                            I still have a lot of work with regards to insulation and numerous other truss types and rafter roofs.
                                            design.medeek.com
                                            • 69
                                            • 70
                                            • 71
                                            • 72
                                            • 73
                                            • 76
                                            • 77
                                            • 71 / 77
