    Increase default line segments of a curves
    3 Posts 2 Posters 2.2k Views 2 Watching
    • L
      Hi, I am drawing a lot of curves similar to contour lines. When I draw the (many) lines they all default to 12 segments. I need them to have much more segments for the required purpose. Is there any way I can change the amount of segments by default?
      • BoxB
        Select the arc tool, type the number you want and hit enter. This will stay as the default until you change it or start a new instance of sketchup.
        • L
          So easy, thanks
