    [Plugin] importDXFtext
    165 Posts 18 Posters 114.2k Views 18 Watching
    • uwesketchU
      uwesketch
      Much better. Thanks. πŸ˜„
      in the test file "dxf issues with special chars.dxf" there are now only two issues left.
      The text "Knickarmmarkise" has the attachment point in the "middle center", but I think you take the point "left center". Therefore the text is shifted to the right. Can you implement the attachment point "middle center" / "right center"?
      In below screen shot, green is the position where it should be, red the position produced by version v4.0
      wrong attachment point.
      The large text starting with "Masse am Bau:" is nicely aligned left, but it is shifted downwards by exactly one letter height. In version 3.4 (to which I compare version 4.0) this was correctly placed.
      In below screen shot, green is the (correct) position from version 3.4, red the position produced by version 4.0.
      text shifted by one letter height downwards
      P.S. TEXT entities still not working properly:
      version 4.0, says in the console, it is doing TEXT, but they are not created in SketchUp!
      I get :
      74 TEXT ENTITIES:
      Making 74 TEXT Entities...
      Making 25 MTEXT Entities...
      Making 436 ATTRIBUTE TEXT Entities...
      BUT: the TEXT entities are NOT CREATED in SketchUp.
        The text "Knickarmmarkise" has the attachmentpoint [71] in the "middle right" - i.e. set to 6
        Which is MR - the associated Ruby align assignment is flaky !
        As it doesn't reset it properly I've rewritten that code - should work now...
        Please check...
        The alignment of the "Masse am..." text is more complex as its alignment is set to TR 3 and there are 2no \P characters in the string - equivalent to \n newline in Ruby - that splits the text-string into its 'lines'...
        Please test as I'm not sure this update fixes it, because the number of lines in a string affect the overall group's height and sometimes this might mess up vertical alignment adjustments ??
        If if does mess up, then I have to look at analyzing the string for \n and adjust any vertical alignment accordingly [using string.lines.count etc]
        Here's v4.1
        https://sketchucation.com/pluginstore?pln=importDXFtext
        • uwesketchU
          uwesketch
          The "Knickarmmarkise" is now good and yes, the attachment point is 6, not 5.
          But all other MTEXTs are now either a bit off or completely off.
          It looks like that the higher the rotation angle the more off the text is placed.
          The "SN Q4" texts are about 26meter off, the dimension value 17^5 is 23m off, the 1.24^5 dimension value is 34meter off. the "OK Mauer ca. 549.79" is about 6m off to the right.
          The "Masse am Bau:" has not changed position compared to version 4.0.
          BTW in version 3.4, 3.5, 3.6, etc it was correct. Can you not compare to the code of v3.4?
            One step forward, one step back !
            I'll investigate...
            • uwesketchU
              uwesketch
              Thanks. Can you also look into why TEXTs are not created anymore in SketchUp, even though in the console it says that "Making .. TEXT Entities"
                Another problem !
                  I'll look at the alignment issue shortly...
                  However, the current TEXT import does work for me, albeit with text pieces miles from the origin, making selecting / viewing / editing them very awkward [even with the help of the Outliner] - when using your TEXT dxf example - is this the issue you are referring to ?
                  e.g. the first piece of TEXT processed is -
                  X = 2677161.876174174 [42.25 miles from the origin] Y = 1237562.802 ... Text = "430287"
                  Also note that in that file several ATTRIBS also have no 'string' at all [code 1] - the omission is in the DXF file, not the ruby side...
                  • uwesketchU
                    uwesketch
                    Yes, it is the file called map with Isocontours TEXT.dxf.
                    I am running with v4.1
                    after the import finished, I see only 250 sub groups. 225 ATEXT and 25 MTEXT.
                    They are either called "ATEXT #..." or "MTEXT #...".
                    But there are no sub groups called "TEXT #..." in the outliner.
                    The first TEXT entry listed in the console is:
                    Layer = 01139
                    Color = 0
                    Y = 1237562.802
                    Z = 0.0
                    Height = 0.9999999999999997
                    Text = 430287
                    Oblique = 15.0
                    Justification_H = 2
                    Justification_V = 2
                    Style = STANDARD
                    Rotation = 0.0
                    Yes, the origin is far off. This is the Swiss coordinate system LV95.
                    There are or instance two TEXT called Rinderweidstrasse and Rinderweidweg. These should be easily visible in Sketchup in the very top right of he imported group, but they do not exist.
                    (choose parallel projection, top view, then in the outliner select an ATEXT and then "yoom selection" in the context menu)
                    BTW, the first 12 MTEXT are in the bottom left corner of the group near the Origin, the other MTEXTs and the ATEXTs are in the top right corner of the group.
                      Here's v4.2
                      Which attempts to address some of the recent issues...
                      Please test and report...
                      • uwesketchU
                        uwesketch
                        I tested v4.2: better again πŸ˜„
                        TEXTs are still not imported, the console output is a bit different now, but in Sketchup there are no TEXT groups created. Only 25 MTEXT and 225 ATEXT groups.
                        I am testing btw with SketchUp 2022. DXFImport v3.4 is running on SketchUp 2021.
                        console output of importing "map with Isocontours TEXT.dxf":
                        74 : 0
                        25 : 0
                        225 : 211
                        Rotation testing (dxf issues with special chars.dxf):
                        Here the 3DText objects that were far off in the lat version, are now closer again, but still not fully correct:
                        It seems the attachment point for rotation is not read correctly:
                        In below screen shots, black is the unrotated text from v3.4, green is where it should be according to the DXF definition, red is where the import is placed.
                        Looks like all are attachment point issues, except the "Masse am Bau:" which is shifted down since version 3.4.
                          The TEXT is NOT imported for me.
                          Says 74 made, 0 failed.
                          But in the Outliner there's nothing ! a mystery...
                          Investigating...
                            I got to the bottom of this !
                            It did process all of the TEXT but then it wasn't adding the 3d-text geometry !!
                            Another stupid temp-typo...
                            Now it's fixed...
                            Here's v4.3
                            I'll look at the rotation reports next...
                            • uwesketchU
                              uwesketch
                              Now it's fixed...
                              I tested v4.3 re TEXT: IT IS BACK πŸ˜„ Great!
                              And the position and rotation of TEXT is very precise.
                              Funny, that two TEXTs ("Sunnenberg" and "Rinderweidweg") are slightly off (only by a 1/4 of the font height).
                              In below screen shots, green are TEXTs that are precisely positioned, red marked the two longer TEXTs that are a bit shifted. I think it can be ignored, but still wanted to let you know.
                                The dropped tail of the 'g' is causing the issue - it's fixable...
                                • uwesketchU
                                  uwesketch
                                  Makes sense. Then it could be fixed consistently as done with MTEXT.
                                    Here's v4.4 which fixes the dropped letters, like 'g', affecting the text's insertion-point.
                                    Please re-comment on the rotation/alignment issues you've previously raised, as recent changes might have had an influence...
                                    • uwesketchU
                                      uwesketch
                                      TEXT is now all fine. Perfect!
                                      In the same file there are as well some MTEXTs. (The blueish texts).
                                      These MTEXTS are still shifted as soon as there is a rotation involved.
                                      Later I will also send a report based on our other test file.
                                        Thanks, I'll investigate it all tomorrow...
                                        • uwesketchU
                                          uwesketch
                                          I tested v4.4 with the testfile "dxf issues with special chars.dxf".
                                          The displacement of rotated MTexts is the same as with v4.2 reported in this post:
                                          404 Not Found
                                          (sketchucation.com)
                                            Here's v4.5
                                            I'm hopeful it addresses the alignment / rotation weirdness...
                                            Please test and report back...
                                            • 7 / 9
