    Space Bar As Enter Functionality In CleanUp - SU 2022 Pro
    3 Posts 2 Posters 2.7k Views 2 Watching
    • Gus RG Offline
      Gus R
      I just updated Sketchup 2022 Pro and seem to have lost the "enter" function for the space bar for certain tasks. Was just using it all afternoon on 2022 and it's still working in 2021. Anyone else experiencing this?
      Was using it as enter for CleanUp. I know it's for Tools/Select but for some reason it was working as "OK" for CleanUp Validity Check both in 2021 and the previous version of 2022.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
        slbaumgartner
        By default the spacebar activates the Selection Tool. Doing so will also deactivate whatever other Tool was previously active. Could that be what you were actually experiencing?
        • Gus RG Offline
          Gus R
          Yes. I don't remember when I started using the space key for OK while using CleanUp. I was churning through a bunch of Vray proxies from Vizpark to clear them from errors while trying to debug the V-Ray caused bugplats in Sketchup. It's a close click away when you're in production mode.
          It was working in 2022 before the update and still works in 2021. Both were able to function that way in addition to changing over to the select mode. Not really a big issue. I frequently change around shortcuts for specific tasks I'm working on.
          Sketchup could sure use macros for routine tasks. Always did.
