    Angle between two polygons
    4 Posts 3 Posters 1.7k Views 3 Watching
    • N Offline
      nlipovac
      Hi guys,
      I need an angle between two poygons.
      It needs to show angle as an object not just info in the measurement window.
      Is there such a plugin that I can select two polygons and it would draw an angle between two polygons?
      Preferably both, inner and outer angles.
      There is an angle dimension tool, but you need to draw a 90° line or use a 90°angle in the plugin to draw the desired angle, and it draws just the inner angle, I am in search of just select two polygons and you get angles drawn.
      If there is such a plugin please point me to.
      • Rich O BrienR Online
        SketchUp Plugins | PluginStore | SketchUcation
        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
        (sketchucation.com)
        Something like that?
          FredoTools has an angle inspector tool also
          https://i.imgur.com/EPVWgY9.png
            rv1974
            Are you talking of bisection (Симетрала)?
            Unfortunately (I even requested in vain long time ago) there's no such tool.
            the closest one (and indispensable) is:
            http://www.smustard.com/script/Midpoint
