    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      Version 2.6.8 - 01.15.2022
      • Fixed bug with exterior trim when doors and garage doors are vertically offset.
      http://design.medeek.com/resources/wallplugin/images3/wall_su611_800.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 2.6.8b - 01.18.2022
        • Fixed a bug with exterior wainscoting when doors and garage doors are vertically offset negative or positive values.
        !!!! Critical Bug Fix !!!!
        This addresses the issues with door and garage doors that have been vertically offset within the wall. This bug fix addresses all wall types: rectangular, shed, gable and hip.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 2.6.8c - 01.20.2022
          • Fixed a minor bug with custom labels for doors, windows and garage doors.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 2.6.9 - 01.22.2022
            • Added an additional layer for furring into the Layers tab of the Global Settings.
            • Fixed a bug with Door tab (HTML) of the Global Settings.
            http://design.medeek.com/resources/wallplugin/images3/wall_su612_800.jpg
            !!!! Critical Fix !!!!
            The HTML file of the Door tab of the Global Settings was updated back in October (Version 2.4.9). However at that time it appears that this updated version of the file somehow did not make it into the compiled codebase. I just discovered this today and have moved the file into the correct location and released this latest update which corrects this oversight. My apologies that this bug was introduced in the first place but it pains me further that it took until now to actually discover it. Please upgrade to this latest version to resolve this issue.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 2.7.0 - 01.23.2022
              • Enabled custom materials for cavity insulation.
              http://design.medeek.com/resources/wallplugin/images3/wall_su613_800.jpg
              This update was per customer request.
              design.medeek.com
              • medeekM Offline
                medeek
                Just loaded up SU 2022 Pro on my PC and promptly installed all of the plugins.
                So far I’m not seeing any issues running 2022 with any of plugins, of course far more testing is required but so far so good.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 2.7.1 - 01.27.2022
                  • Converted the door preset system to a Hash data structure.
                  • Converted the garage door preset system to a Hash data structure.
                  !!! WARNING !!!
                  This update will require deleting and recreating any door and/or garage door presets. This update will not affect any other preset types (ie. walls, windows, etc…)
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 2.7.2 - 01.31.2022
                    • Fixed a bug with the window preset system within the window edit menu.
                    !!!!Alert!!!!
                    This bug existed within the window edit menu when creating a new window preset. Any window presets created prior to this bug fix may need to be manually removed from the window preset config file. This can be easily done by editing the file with any basic text editor (ie. Notepad).
                    Properly configured window presets will begin with the following character string "b1=". If the preset does not have this specific string followed by a number (the preset number) it is corrupt and should be deleted from the preset file.
                    In Microsoft Windows the presets are found here:
                    C:\Users%Username%\AppData\Roaming\Medeek\2022\medeek_wall_ext\presets
                    The window preset file is named:
                    WINDOW_PRESETS.txt
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 2.7.3 - 02.01.2022
                      • Added casing "Style D" for rectangle doors (Victorian style casing with plinths and rosettes).
                      • Added casing "Style D" for rectangle windows (Victorian style casing with rosettes).
                      http://design.medeek.com/resources/wallplugin/images3/wall_su614_800.jpg
                      http://design.medeek.com/resources/wallplugin/images3/wall_su615_800.jpg
                      This is a low-poly version of a Victorian style casing. The details in the rosettes and plinth blocks are missing and the typical fluting in the jamb and header are also missing.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 2.7.4 - 02.03.2022
                        • Added two additional (advanced framing) layers: Bottom Plate, Header 2.
                        • Added an option for the cutting of bottom plates for doors and garage doors.
                        http://design.medeek.com/resources/wallplugin/images3/wall_su616_800.jpg
                        http://design.medeek.com/resources/wallplugin/images3/wall_su617_800.jpg
                        The "Cut Bottom Plates" option by default is turned on (YES), however when it is turned off then the bottom plates are not cut out for door and garage doors. This is useful for wall panel manufacturers who would rather leave the bottom plates intact for shipping/transportation and other reasons.
                        The "Header 2" layer is specifically for the sheathing placed between the lumber of spaced headers:
                        http://design.medeek.com/resources/wallplugin/images2/wall_su572_800.jpg
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 2.7.5 - 02.06.2022
                          • Added casing "Style E" for rectangle windows (Victorian style casing with rosettes).
                          • Fixed a bug related to upgrades introduced in Version 2.6.8 specifically for CMU and "No Framing" walls.
                          http://design.medeek.com/resources/wallplugin/images3/wall_su618_800.jpg
                          If you are using CMU walls or the "No Framing" option, this update is a critical fix for doors and garage doors. Please update your plugin to this latest version. Always remember to first uninstall the existing version first before installing the updated plugin within the Extension Manager in SketchUp.
                          Style E is another common variant of the Victorian style of casing that I thought would be a good addition and complete the recent window and door casing upgrades to the plugin. Again my objective here is to provide a low poly version to represent the overall configuration rather than all of the minute details of such a typically ornate window treatment.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 2.7.6 - 02.07.2022
                            • Added casing "Style F" for rectangle doors.
                            • Added casing "Style F" for rectangle windows.
                            • Enabled a VTP (very top plate) Offset option for rectangular walls.
                            http://design.medeek.com/resources/wallplugin/images3/wall_su620_800.jpg
                            http://design.medeek.com/resources/wallplugin/images3/wall_su619_800.jpg
                            http://design.medeek.com/resources/wallplugin/images3/wall_su621_800.jpg
                            The VTP offset allows for more manual control of the "very top plate" and how it overshoots or undershoots the wall on either end (start and/or end of the wall panel). In order to use this parameter the "Trim Top Plate" must be set to "NO" (ie. manual mode is then enabled), and then either a positive or negative length can be entered which will offset the VTP accordingly as shown.
                            This feature was specifically requested by wall panel manufacturers so that they could more closely control the overlapping of the top plates in their shop models and construction drawings.
                            *Note that Trim Top Plate and VTP Offset options are currently only active for rectangular walls.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 2.7.7 - 02.08.2022
                              • Added a "NO" header option for windows, doors and garage doors.
                              • Fixed a bug with ladder blocking when the stud offset is non-zero.
                              • Fixed a minor bug with ladder blocking for hip walls.
                              http://design.medeek.com/resources/wallplugin/images3/wall_su623_800.jpg
                              http://design.medeek.com/resources/wallplugin/images3/wall_su624_800.jpg
                              http://design.medeek.com/resources/wallplugin/images3/wall_su622_800.jpg
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                I've had quite a few requests for a tool that will draw circular walls however I need to wrap my head around the geometry and some of the issues that arise when you curve the entire wall (or partial arc) like this:
                                https://aws1.discourse-cdn.com/sketchup/original/3X/0/9/098c32ea2fd2d8156a2a598639b8e548e12c0a14.jpeg
                                As you can see things get a bit interesting when you introduce windows and doors into a tightly curved wall. In particular notice how the window opening is framed normally (no curve) and the cripple stud in the middle of this opening is problematic. So how does one handle this? The problem really is how to frame a straight opening like a window or a door into a curved wall.
                                View model here:
                                3D Warehouse
                                (3dwarehouse.sketchup.com)
                                Before I can make this a functioning tool I need to iron out some of these details in a rational manner.
                                design.medeek.com
                                • gullfoG Offline
                                  gullfo
                                  my guess? i would find a way to generally mimic the radius (e.g. splitting the window or door frame) as an option, and presume that the window or door finishing will finalize the curved (or not) surface with jamb, extensions, etc. also i would presume the rough framing of the walls (and domed / curved ceilings 😄 ) will use various finishing techniques (e.g. curved/kerfed plywood + gwb, steamed lumber, etc) rather than expect the framing to be perfectly curved. this gives options for going from 6-8-12 sided gazebos to circular or elliptical structures...
                                  Glenn
                                  http://www.runnel.com
                                  • medeekM Offline
                                    medeek
                                    Version 2.7.8 - 02.11.2022
                                    • Enabled staggered studs for rectangular walls.
                                    http://design.medeek.com/resources/wallplugin/images3/wall_su626_800.jpg
                                    Rather than enable yet another parameter and make the menu that much bigger I decided to utilize the "Stud Ply" parameter to toggle this option. If you set the stud ply to "0", you will get a staggered stud wall as shown.
                                    View model here:
                                    3D Warehouse
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 2.7.8b - 02.14.2022
                                      • Enabled staggered stud walls within the Copy Wall tool.
                                      Tutorial 27 - Staggered Stud Walls (15:09 min.)
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 2.7.9 - 02.16.2022
                                        • Fixed a bug with vertically offset doors and garage doors in the "No Framing" mode.
                                        • Fixed a bug with (arched) half or full glass doors that have a prairie or perimeter grilles installed.
                                        Some minor fixes but annoying little bugs nonetheless, one was just a simple typo that has been waiting to be found for months. Highly recommend updating to this latest version if only to make these two bugs go away. A big thank-you to the user base who finds these bugs and notifies me so that I can address them.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 2.8.0 - 02.19.2022
                                          • Enabled insulation within the preview menu of the estimating module.
                                          http://design.medeek.com/resources/wallplugin/images3/wall_su627_800.jpg
                                          The insulation was already part of the CSV file output however I had not added it to the preview screen.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Tutorial 28 - Estimating Preview (12:02 min.)
                                            I'm still not entirely sure what direction I am going to take the estimating module but much work remains to be done.
                                            design.medeek.com
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 75
                                            • 76
                                            • 27 / 76
