    Crash help please
    15 Posts 2 Posters 2.4k Views 2 Watching
    • L
      I followed the same logic and as impluasable as it may sound I tried it 3 different ways. all good I did each sheet one by one, all good until I get nearly to the end ....crash all crashed with different
      size sheets about at the same point. Believe it or not, I can come to no other conclusion than it is not a one by one real time thing...........it is cumulative ❗ ❗ ❗ ❗ That is a bug ❗
      • BoxB
        If you attach your model we may be able to sort it out.
        • BoxB
          This is a quick example of how I would look at it.
          • L
            Ok I will, thank you. Image is how I did it, or one of three ways not to do it. 😉
            Crash-0.skp
            • L
              Box, I never would have considered using a section plane for construction. Hand on heart you are a true master 👍
              • BoxB
                I was able to make a paneled triangular section of roof with your model after I did a bit of cleaning up. I move the model near the origin and removed all the extraneous hidden geometry in the panel.
                Have a go doing what you want with this version and see if it makes a difference.
                Crash-0Box.skp
                • L
                  Cheers Box but this is what I recieved
                  • BoxB
                    Yes, I gave you back the pieces for you to try.
                    • BoxB
                      By cleaning up the corrugated geometry I was able to make it one sheet and simply intersect it with the triangle.
                      Try not to creat so many hidden edges. And the 'thickness' faces are not necessary if you are going to chop through the faces.
                      • L
                        Cheers again Box. I will try it again following your last vid.
                        • L
                          Here is an image off the corrugated steel roof. It did my head in 😉
