    Export transparent colored object
    3 Posts 3 Posters 1.5k Views 3 Watching
    • I
      its3Dmade
      I have an object I’ve colored using a light source for gradient color and a part of the object has a transparent color. I’m importing the 2d EPS graphic into photoshop. The gradient color scheme is showing up correctly but the transparent colorized section does not. Specifically, it is colored yellow at 35% of 100% color. It shows up as solid yellow in photoshop. Any way to get this to work? I have turned off edges, profiles and more in styles, but still no luck.
      -mark
        Does EPS even support transparency?
          Derek Edison
          EPS is postscript so no.
