    [Plugin] LordOfTheToolbars - v2.9c - 20 Dec 24
    471 Posts 89 Posters 339.7k Views 88 Watching
      rv1974
      Some observations:
      The plugin misbehaves heavily in large files*:
      Open command search window makes navigation (lags &freezing) in complex and heavy files practically impossible.
      Command search itself becomes super slow.
      Icons refuse to disappear when user tries to remove them.
      Restoring from a good config file has no effect. Restart is needed to see the change.
      *- normally 3-6+ SU windows are opened simultaneously. Hard to say if it influence, but standard UI elements in every file run perfectly.
      • fredo6F Offline
        Could you check if there is a lag when you do a right-click in selection mode (with the LOTT Search closed)?
        Where do you try to remove icons from?
        Are you referring to the synchronization mechanisms between SU instances on Windows?
          rv1974
          *) no lags with SU right click menu (whith LOTT Search closed) IIRC.
          *) removed icons remain (untill restart) in user LOTT pallets
          *) I mean normally I keep open numerous different skp files (maybe it affects, but unlikely)
          Maybe its a good idea to send you some heavy file later on to take a look..
          Thank you
          • W Offline
            whiterabbit
            I noticed that a number of plugins don't function when they are in a favorites folder, but work with the regular toolbar? attached a gif to show.\Is there something I have done wrong - windows 10 with skup 2018
            • fredo6F Offline
              Can you open the Ruby Console before clicking on the LOTT palette. There may be errors displayed.
              • H Offline
                Hypernurd
                I was really excited to add this essential plug-in to my SU installation. Unfortunately, it isn't functioning for me.
                My system :
                • iMac Pro (2017) - 32GB Ram, 3.2Ghz Xeon W
                • macOS Monterey (12.0.1)
                • Sketchup 2021 & 2020
                Problem :
                • Cannot drag and drop icons to custom tool palettes or toolbars.
                Initially I thought this was a SU2021 problem so I reinstalled 2020 but the problem persists. I have done a thorough system clean (Caches, etc) but still the problem persists in both versions of SU.
                Any help or advice would be appreciated.
                BWm,
                Hypernurd
                • fredo6F Offline
                  @hypernurd said:
                  Problem :
                  Could you open the Ruby console to see what is the error. Thanks
                  • fredo6F Offline
                    NEW RELEASE: LordOfTheToolbars v1.6a - 27 Dec 21
                    Requirements
                    • LibFredo6: v12.3a or above
                    LordOfTheToolbars 1.6a includes
                    • Adjustments for future compatibility
                    • Bug fixing and visual adjustments
                    Home Page of LordOfTheToolbars for information and Download.
                    Main post of this LordOfTheToolbars thread.
                      rv1974
                      Manipulations with large palettes became (so far) much more predictable and stable with latest release. Thank you very much Fredo 👍
                      P.S. Could theoretically LOTT show user's shortcuts directly in tool tips and command search?
                      • H Offline
                        haymaker
                        Please help
                        I have set up LOTT but the vignette strip is stuck on my laptop screen and will not drag to my 2nd larger screen where I use SU. I can solve this by making the 2nd screen the main screen in windows11 but then SU does not allow me to access the standard menus and SU freezes. I run lot s of pluggins and this is the first time I have had this issue. Having the vignette strip on the laptop screen also means The favourite pallets I have made open on that screen as well and the shortcuts don't work. This make LOTT un useable for me which would be a shame because it looks awesome.
                        I would be extremely grateful if you cold help trouble shoot this issue.
                        Kind regards
                        Mike
                        • H Offline
                          haymaker
                          Further to previous post. It is worth noting that the LOTT toolbar is open on the main screen. The favourite, master and shortcut menus open on laptop and can be dragged to main screen but everything else is stuck on the laptop screen. Its like the vignette strip does not recognise the second screen.
                          I am using LOTT V1.6a and LIBfredo6 v12.3a. SU2021 all up to date.
                          • fredo6F Offline
                            It's funny, because other users have complained that the Vignette Stripe does not follow Sketchup when the main SU window is moved to another monitor (hence the changes I made to keep the Vignette Stripe position relative to the Sketchup viewport).
                            I need to think a little bit to see how to accommodate all requirements.
                            • H Offline
                              haymaker
                              Thanks for the prompt response.
                              Would it be possible for me to download an earlier version that would work?
                              Cheers
                              Mike
                                rv1974
                                Talking of moving to 2nd monitor.. I'm so pleased with rosette behavior - it preserves location perfectly and no more disappearings ☀
                                Hope one day palettes will be able to keep their relative location while manipulating SU viewport in precise manner as well.
                                • fredo6F Offline
                                  What is the rosette behavior again?
                                    rv1974
                                    I mean vignette. I got addicted to Stromae's Sante lately Haha
                                    • fredo6F Offline
                                      Instead, I would suggest that you install LOTT V1.6b, which includes an option for setting or unsetting the stickiness of the Vignette Stripe to the Sketchup window (ON by default, so you would need to disable it in the Default Parameters).
                                      • fredo6F Offline
                                        NEW RELEASE: LordOfTheToolbars v1.6b - 06 Jan 22
                                        Requirements
                                        LordOfTheToolbars 1.6b includes
                                        • New parameter (in the Default Parameter dialog box) to enable / disable the stickiness of the Vignette Stripe to the Sketchup Window (default is enabled).
                                        • H Offline
                                          haymaker
                                          Hey.
                                          Great customer service.
                                          I have updated LOTT to 6b but the problem persists. The vignette strip and the favourite pallets that I have made are stuck on the main laptop screen. I also have the problem that whenever I enter text into a dialogue box then the shortcut keys are activated. For example when I make a component with the name 'nog' as soon as I type O the Edit pallet opens up.
                                          I have disabled all my other extensions but it makes no difference. Could this be an installation error. If delete the LOTT extension and reinstall it will I lose all my pallets and shortcuts.
                                          Thank you for your help so far. I am really looking forward to getting this sorted as your plugin will improve my workflow.
                                          Mike
                                          • fredo6F Offline
                                            Did you disable the stickiness of the Vignette Stripe in the Default Parameters?
                                            For palettes, they are sticky. So I will make an option to release stickiness for them.
                                            Good catch. I will fix that.
                                            • 23
                                            • 24
                                            • 7 / 24
