    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 689.7k Views 99 Watching
    • L
      ltchest
      OK so i realise now that there is a switch to "Exclude" vray from the options, so i turned that off and it solved my problem. Amazing ! The only thing i really would appreciate would be to have control over where the vignette appears every time i start sketchup. Currently, i have to move it from Screen 2 onto Screen 1 every time 😞
      Sketchup 21.2.332 (windows 10.0.19043 Build 19043)
      RTX2070 + GTX1080, Driver 472.12
      R 1 Reply Last reply
      • L
        ltchest
        @simoncbevans said:
        Great extension. I wonder if it is possible to make a custom made toolbar fly out? Would save getting in the way when you have it in the work area.
        that is exactly what the vignette gives you
        • C
          coreyfox
          @fredo6 said:
          @coreyfox said:
          This is an amazing plugin! I have moved my workflow into using it, but as of yesterday it has been crashing my sketchup, before it can fully load, every time. See attachment - any suggestions on what might be happening here?
          Which version of Sketchup are you running? If SU2021, please migrate to the latest version, because it solves issues related to menus.
          I'm on sketchup 2021.1.332
          • L
            ltchest
            one more thing about the Vignette. I am finding that, even without closing Sketchup, the Vignette jumps back over to the second screen (monitor). This doesnt happen all the time - just happens sometimes / occasionally. I will open a different drawing from Sketchup and the vignette moves back to where it was at startup 😞
              SingulArita
              Thank you for a great extension. Unfortunately, I have a few bugs. Line breaks are lost for some favorite vignettes. Icons rearrange and arrangement lose clarity. There is a problem with the line break for sure. Sometimes it happens to me that the icon duplicates and the original cannot be deleted, moved - right-clicked or removed the break before. I have not yet discovered the exact cause or procedure. But it's happening significantly and it's incredibly annoying.
              SketchUp 2020 20.0.363. Martin
              • H
                hsy7758258
                on master toolbar manager,i can do noting,cant click or move the icon...
                show page dev tools,there are bug reporter
                • cmeedC
                  cmeed
                  Hi Fredo,
                  An amazing plugin - truly a game changer for Plugin reliant Su users! especially helpful on my laptop
                  I got a suggestion and an issue.
                  My suggestion is - could the palettes appear with the use of a shortcut then disappear when a plugin has been hit. with an option for the Palette to appear where the cursor is and in a user defined locations.
                  My issue
                  I'm having trouble altering my palettes. Icons/separators double up when I move them, with these ghost icons/separators I can't right click on them. Ive done al ot of combinations of holding shift / control but the its seems the same what ever combo i use....
                  go here for a video of what i mean and then - of all things a crash!!
                  https://www.dropbox.com/s/2rzj2dadzplgqxd/2021-11-10_21-58-55.mp4?dl=0
                  Cheers
                    rv1974
                    Some observations:
                    The plugin misbehaves heavily in large files*:
                    Open command search window makes navigation (lags &freezing) in complex and heavy files practically impossible.
                    Command search itself becomes super slow.
                    Icons refuse to disappear when user tries to remove them.
                    Restoring from a good config file has no effect. Restart is needed to see the change.
                    *- normally 3-6+ SU windows are opened simultaneously. Hard to say if it influence, but standard UI elements in every file run perfectly.
                    • fredo6F
                      Could you check if there is a lag when you do a right-click in selection mode (with the LOTT Search closed)?
                      Where do you try to remove icons from?
                      Are you referring to the synchronization mechanisms between SU instances on Windows?
                        rv1974
                        *) no lags with SU right click menu (whith LOTT Search closed) IIRC.
                        *) removed icons remain (untill restart) in user LOTT pallets
                        *) I mean normally I keep open numerous different skp files (maybe it affects, but unlikely)
                        Maybe its a good idea to send you some heavy file later on to take a look..
                        Thank you
                        • W
                          whiterabbit
                          I noticed that a number of plugins don't function when they are in a favorites folder, but work with the regular toolbar? attached a gif to show.\Is there something I have done wrong - windows 10 with skup 2018
                          • fredo6F
                            Can you open the Ruby Console before clicking on the LOTT palette. There may be errors displayed.
                            • H
                              Hypernurd
                              I was really excited to add this essential plug-in to my SU installation. Unfortunately, it isn't functioning for me.
                              My system :
                              • iMac Pro (2017) - 32GB Ram, 3.2Ghz Xeon W
                              • macOS Monterey (12.0.1)
                              • Sketchup 2021 & 2020
                              Problem :
                              • Cannot drag and drop icons to custom tool palettes or toolbars.
                              Initially I thought this was a SU2021 problem so I reinstalled 2020 but the problem persists. I have done a thorough system clean (Caches, etc) but still the problem persists in both versions of SU.
                              Any help or advice would be appreciated.
                              BWm,
                              Hypernurd
                              • fredo6F
                                @hypernurd said:
                                Problem :
                                Could you open the Ruby console to see what is the error. Thanks
                                • fredo6F
                                  NEW RELEASE: LordOfTheToolbars v1.6a - 27 Dec 21
                                  Requirements
                                  • LibFredo6: v12.3a or above
                                  LordOfTheToolbars 1.6a includes
                                  • Adjustments for future compatibility
                                  • Bug fixing and visual adjustments
                                  Home Page of LordOfTheToolbars for information and Download.
                                  Main post of this LordOfTheToolbars thread.
                                    rv1974
                                    Manipulations with large palettes became (so far) much more predictable and stable with latest release. Thank you very much Fredo 👍
                                    P.S. Could theoretically LOTT show user's shortcuts directly in tool tips and command search?
                                    • H
                                      haymaker
                                      Please help
                                      I have set up LOTT but the vignette strip is stuck on my laptop screen and will not drag to my 2nd larger screen where I use SU. I can solve this by making the 2nd screen the main screen in windows11 but then SU does not allow me to access the standard menus and SU freezes. I run lot s of pluggins and this is the first time I have had this issue. Having the vignette strip on the laptop screen also means The favourite pallets I have made open on that screen as well and the shortcuts don't work. This make LOTT un useable for me which would be a shame because it looks awesome.
                                      I would be extremely grateful if you cold help trouble shoot this issue.
                                      Kind regards
                                      Mike
                                      • H
                                        haymaker
                                        Further to previous post. It is worth noting that the LOTT toolbar is open on the main screen. The favourite, master and shortcut menus open on laptop and can be dragged to main screen but everything else is stuck on the laptop screen. Its like the vignette strip does not recognise the second screen.
                                        I am using LOTT V1.6a and LIBfredo6 v12.3a. SU2021 all up to date.
                                        • fredo6F
                                          It's funny, because other users have complained that the Vignette Stripe does not follow Sketchup when the main SU window is moved to another monitor (hence the changes I made to keep the Vignette Stripe position relative to the Sketchup viewport).
                                          I need to think a little bit to see how to accommodate all requirements.
                                          • H
                                            haymaker
                                            Thanks for the prompt response.
                                            Would it be possible for me to download an earlier version that would work?
                                            Cheers
                                            Mike
                                            • 27
                                            • 28
                                            • 6 / 28
