    Ocean view
    14 Posts 5 Posters 4.1k Views 5 Watching
    • Bryan KB Offline
      Thanks loco. πŸ‘
      • ntxdaveN Offline
        ntxdave
        I do not use/have not used Raylectron. Can you please explain an HDRI dome to me.
        • Is it something special to Raylectron?
        • How is it different different from a normal HDRI?
        Press F1...thank me later
        • Bryan KB Offline
          Raylectron, like other render software, can take an HDRI and convert it into a picture "dome" that provides both scenery and overhead sky light for a render. No special adjustment is need, just load the HDRI in the Raylectron Environment settings and Raylectron does the rest. You can then rotate the HDRI horizontally to achieve your desired effect.
          The old way in SketchUp, IIRC, was to create a dome in SketchUp that covered the model and then apply an image texture to the inside of the dome, then create a render from inside the dome.
          Modern HDRIs ( and this may be true for older HDRIs as well) are pictures of combined landscapes and skies that look weirdly wide angle when viewed flat.
          You can search for free HDRIs to test on future renders to see what I mean. But be warned, not all HDRIs are good and still takes some adjustments (tilt, zoom, rotate) to make them look real with your model in the final render, so sometimes, you are limited in the composition of your final render.
          • ntxdaveN Offline
            ntxdave
            Thanks for the reply Bryan. If I understand what you are saying, there is nothing really special about the HDRI itself but rather how it is applied to the model. I use Twilight Render and it seems that there are settings in it to accomplish some of the things you are describing (again if I am understanding you correctly). I was thinking that the β€œdome” was some special thing/HDRI type.
            • Bryan KB Offline
              I'm still getting up to speed on the correct jargon and learning as I go, so my comments may be confusing at times. πŸ˜‰
              • ntxdaveN Offline
                ntxdave
                πŸ˜„
                I know the feeling. I have not done anything at all for a while but enjoy reading the forum and seeing the work of people like you, 😎
                • Bryan KB Offline
                  Thanks ntxdave. πŸ‘
                  Re-rendered only using environment map lighting, with and without interior lights.
                  • pbacotP Offline
                    This looks like a difficult scene, that you've handled really well. I like the many light patterns. Makes the scene lively.
                      On point and perfect. πŸ‘
                      • Bryan KB Offline
                        Thanks pbacot. πŸ‘
                        Thanks Mike. πŸ‘
