    Fredo Corner - getting Ruby Error
    14 Posts 2 Posters 9.0k Views 2 Watching
      Please attached the .skp file.
      Are you still using SketchUp 2017 Make?
        blueman2
        Yes Sketchup 2017
        skp is too large by 1700 kb
        sending via dropbox
        https://www.sendspace.com/file/kmqphm
          Please upload it to DropBox of Google Drive. All I get from your link is spam and the site trying to install garbage I don't want.
            blueman2
            try this:
            VRS6-VR.skp
            Google Docs (drive.google.com)
              That worked.
              It looks like your model runs afoul of a thing that Fredo6 referred to in the FredoCorner thread. See: https://sketchucation.com/forums/viewtopic.php?f=323&t=70149&start=210#p668828
              RoundCorner still works, though.
              FWIW, I see you have Units set to Architectural, Precision is faily coarse for the size of the component, and you have Length Snapping enabled. I would suggest that you at least set precision finer and turn off Length Snapping. I would also use Fractional instead of Architectural units but that's just a preference.
              And you might want to reset the Advanced Camera tools to get rid of the wide gray bars.
              I see why your file is so large. The plywood texture file is huge. Considerably larger than a texture image like that ought to be for SketchUp.
                Here's the component with rounded edges. I have no idea what radius you really want. The dimension shown in your screen shot surely isn't correct but that's due to the coarse Display Precision you are using.
                I reduced the texture size a bit, purged unused stuff from the file, and reset the axes to their default location. The file size is still a little large for a single component but it's a lot better than it was.
                VRS6-VR purged.skp
                  blueman2
                  Thanks guys, I will try your suggestions.
                    blueman2
                    Thanks, I finally got a chance to check out the model. I did take your advice with changing the setting for units and type.
                    The two bands on the side were because I was in the midst of working with vray and I had the safe frame turned on. I neglected to turn it off before sending you the model.
                    I did get round corner to work, but I see that I'm having problems that you did not have in that the edge material is getting picked up and probably reverting to the 90 degree rotation it had before I adjusted it. I tried getting down to 1/64 offset thinking I could avoid it, but it's still showing. I'm wondering what offset you did use and if you possibly repainted after rounding? Though I don't think that would make the difference.
                    Thanks again
                    My attempt
                    Your version
                      If you look at the texture for the edge grain, you'll see that I set it to be projected and the aplied it to the edges of the piece.
                        blueman2
                        Ah, makes sense. I'll take a look. Did you use ThruPaint?
                          No. I thought about it but decided that the native tools would do the job just fine.
                          I forgot to mention that I did select the edges border the large faces and hide them instead of softening/smoothing them.
                            blueman2
                            I got it using ThruPaint
                            thanks
                              Good enough. If it's a simple thing like this and can be handled in a couple of clicks with native tools I usually don't bother using an extension but there's often more than one way to accomplish things in SketchUp.
