    Wires
    13 Posts 7 Posters 2.6k Views 7 Watching
    • duanekempD Offline
      duanekemp
      A part of a current project (not showing the project)... allowing a glimpse into some detail due to plugins by Chris Fullmer's Component Stringer and Fredo6's Curviloft.
      Renders took around two minutes each.
      SketchUp 2020 Thea Render V.2
1920x1080 Presto 2 min
2020 Discoball face division3 smoothed-Scene 45
      SketchUp 2020
1920x1080
2020 Discoball face division3 smoothed-Scene 45 SU
Discoball face division3 smoothed-Scene 44
      SketchUp 2020 SU
2020 Discoball face division3 smoothed-Scene 44 SU
2020 Discoball face division3 smoothed-Scene 43
      SketchUp 2020
2020 Discoball face division3 smoothed-Scene 43 SU
      Duane Kemp
      Kemp Productions
      Puidoux, Switzerland
      Gallery:
      https://duanekemp.artstation.com/
      • boofredlayB Offline
        boofredlay
        Nice! πŸ‘Š
        • ntxdaveN Offline
          ntxdave
          Some very interesting and well done work. πŸ‘ πŸ‘
          Press F1...thank me later
            duanekemp
            I've done wires before using the same plugins, but, this was a bit more time consuming as it had many more to deal with. Thanks guys.
            Duane Kemp
            Kemp Productions
            Gallery:
            • Bryan KB Offline
              Excellent work.
              Wires are not easy for me. Free floating ones like are even harder.
              Top notch work. πŸ‘
                That is seriously, great work. Making cables look convincing is not easy, at all πŸ‘
                  Serious brilliant, got me pondering on the model that gets this level of detail, looking forward to find out what it is. πŸ‘
                    duanekemp
                    These are the cables attached to a nuclear bomb reconstruction from photo references. Though the wires were a pain in the butt, the bomb itself was a nightmare. Fortunately, the geometrical issues were solved and the bomb is now complete. But, I remember the day where, "dang... I have to do those wires/cabling" was a bit of a hurdle... wasn't looking forward to it.
                    Duane Kemp
                    Kemp Productions
                    Gallery:
                      "These are the cables attached to a nuclear bomb".......ah, that's why they look so familiar πŸ˜‰
                        From a serious perspective it gets away with being "Milspec" equipment, and you nailed that πŸ‘
                          duanekemp
                          Thank you so much!
                          Duane Kemp
                          Kemp Productions
                          Gallery:
                          • pbacotP Offline
                            Nice Electrical wires
                            Shocking results!
                            Is this a "current" project or "potential" project?
                              duanekemp
                              Thank you very much.
                              This is a current project that has several levels of development. The implosion device with this wire configuration was completed last year and a second variation has been finalised, which has the bomb in place/installed in support rings and frame within a warhead, which is part of one half of the final presentation that includes a different device. The two bombs together are meant to show the direct comparison between the two weapons within their respective warheads with shrouds.
                              This also meant the wiring had to be done a second time for it to be presented within the "case" or protective covering while sitting in the warhead, with the wires' socket connected to a control box.
                              Once published, I'll be able to share renders so that these wires will have a bit more visual context or explanation/reason to be modelled.
                              Duane Kemp
                              Kemp Productions
                              Gallery:
