    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 689.7k Views 99 Watching
      rv1974
      Some strange behavior on toolbar editing: dropping new icons in the middle simultaneously delete existing ones in the bottom right corner. Playing with Nb of columns\rows in toolbar properties didn't help.
      • fredo6F
        Is this only withese two command icons, or general, that is, if you insert another icon, the last one will disappear?
        Also, can you go to the Default Parameters and check the field "Maximum number of icons for favorite palettes".
          rv1974
          increasing 'maximum number of icons' param solved the issue- many thanks 👍
          • C
            cinooo
            Hello, after using the FREDO extention “Lordofthetoolbars” to hide and unhide all tool bar i can no more recover the status bar !!!??? any helps please
            Thank u
            • fredo6F
              Does it persist when you restart Sketchup?
              • fredo6F
                NEW RELEASE: LordOfTheToolbars v1.4a - 06 Jul 21
                Requirements
                • LibFredo6: v11.9a or above
                LordOfTheToolbars 1.4a is a major release with more possibilities of configuration of the behavior of LOTT, as well as bug fixing and adjustments, especially
                • Click Mode (versus Hover mode)
                • More Options for the positioning of palettes
                • Shortcuts for palettes and personal command
                Home Page of LordOfTheToolbars for information and Download.
                Main post of this LordOfTheToolbars thread.
                • Gus RG
                  Gus R
                  When I click on menu options it asks me to "Import LOTT COnfig from file." I hit cancel and the menu show ups.
                  www.instagram.com/gusrobatto/
                  www.facebook.com/gusrobatto
                  • fredo6F
                    Thanks for signaling. It will be fixed in the next version.
                    • fredo6F
                      NEW RELEASE: LordOfTheToolbars v1.4b - 07 Jul 21
                      Requirements
                      LordOfTheToolbars 1.4b fixes a bug where, on first utilization, the Import dialog would display when clicking on the control button of the Vignette Stripe.
                      • Gus RG
                        Gus R
                        Thanks Fredo. All fixed.
                        • P
                          PedroE
                          Hi fredo, thanks for listening, great job my congratulations. I want to indicate a possible error. Thanks in advance.
                          error
                          • fredo6F
                            Hi Pedro,
                            Could you do me a favor.
                            Just open the Ruby Console and type Sketchup.get_shortcuts. Then copy the output and paste it in your answer here.
                            I suspect there are some local dependencies (Spanish in your case).
                            • fredo6F
                              NEW RELEASE: LordOfTheToolbars v1.4c - 08 Jul 21
                              Requirements
                              • LibFredo6: v11.9b or above
                              LordOfTheToolbars 1.4c is for bug fixing and adjustments.
                              • P
                                PedroE
                                Is This?
                                "Add help menu!"
                                "create new"
                                "created"
                                #Sketchup::Menu:0x00000197fd20ff58
                                (eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                                ["Ctrl+Mayúsculas+E\tCámara/Ver modelo centrado", "Ctrl+Mayúsculas+W\tCámara/Ventana de zoom", "Mayúsculas+F1\tSketchUp/Ayuda contextual", "Ctrl+T\tEdición/Anular selección", "Ctrl+C\tEdición/Copiar", "Ctrl+Insertar\tEdición/Copiar", "Mayúsculas+Eliminar\tEdición/Cortar", "Ctrl+X\tEdición/Cortar", "Eliminar\tEdición/Eliminar", "Ctrl+V\tEdición/Pegar", "Mayúsculas+Insertar\tEdición/Pegar", "Ctrl+Y\tEdición/Rehacer", "Ctrl+A\tEdición/Seleccionar todo", "Ctrl+Mayúsculas+I\tEdición/Invertir selección", "Alt+Atrás\tEdición/Deshacer", "Ctrl+Z\tEdición/Deshacer", "Ctrl+N\tArchivo/Nuevo", "Ctrl+O\tArchivo/Abrir...", "Ctrl+P\tArchivo/Imprimir...", "Ctrl+S\tArchivo/Guardar", "AvPág\tVer/Animación/Escena siguiente", "RePág\tVer/Animación/Escena anterior", "X\tHerramientas/Escala", "Ctrl+Alt+G\tCámara/Girar", "Alt+S\tExtensiones/Mirror Selection", "B\tHerramientas/Borrar", "G\tEdición/Crear grupo", "Mayúsculas+D\tEdición/Desbloquear/Seleccionado", "I\tExtensiones/FlexTools/ComponentFinder", "Ctrl+I\tVentana/3D Warehouse", "N\tHerramientas/Texto", "Mayúsculas+G\tEdición/Elemento/Editar grupo", "F\tExtensiones/Start FrontFace[TM] Tool", "Ctrl+Q\tExtensiones/Multiple Offsets", "W\tHerramientas/Curic/Align View/Align View Current", "A\tCámara/Vistas estándar /Arriba", "Z\tCámara/Ver modelo centrado", "Mayúsculas+C\tDibujo/Formas/Círculo", "O\tEdición/Ocultar", "Ctrl+F\tEdición/Elemento/Add Faces [to Selected Edges]", "Mayúsculas+Z\tEdición/Elemento/Zoom a selección", "V\tVer/Estilo de arista/Aristas posteriores", "D\tHerramientas/Mover", "Mayúsculas+V\tEdición/Pegar en su sitio", "E\tHerramientas/Fredo6 Collection/JointPushPull/Thickener", "P\tVentana/Preferencias", "Q\tVer/Edición de componentes/Ocultar el resto del modelo", "R\tHerramientas/Rotar", "T\tEdición/Mostrar/Todas", "Y\tHerramientas/Ejes", "U\tEdición/Mostrar/Último", "C\tEdición/Crear componente...", "M\tHerramientas/Make Faces 1.4", "Fin\tArchivo/Salir", "Alt+3\tDibujo/Arcos/Arco de 3 puntos", "Alt+5\tDibujo/Formas/Polígono", "Alt+Q\tAyuda/- CADFATHER PACK/POWERBAR.../ Offset Edge [SD Mitch]", "Mayúsculas+E\tExtensiones/1001bit Pro/Edit and Modify /Offset edges ", "Mayúsculas+Q\tHerramientas/TIG.Smart_offset", "Alt+R\tDibujo/Formas/Rectángulo", "Alt+T\tDibujo/Herramientas 2D.../2D Texto", "Alt+P\tHerramientas/Fredo Tools/ThruPaint", "Alt+A\tDibujo/Arcos/Arco", "Alt+K\tExtensiones/CleanUp³/Clean…", "Alt+C\tHerramientas/Acotaciones", "Alt+M\tHerramientas/Medir", "Mayúsculas+R\tExtensiones/Enscape/Iniciar Enscape", "Alt+L\tDibujo/Líneas/Línea", "Alt+H\tVer/Barras de herramientas...", "Alt+E\tHerramientas/Equidistancia", "J\tExtensiones/1001bit Pro/Edit and Modify /Fillet ", "L\tExtensiones/1001bit Pro/Setting out /Align selected entities (3 points) ", "K\tExtensiones/1001bit Pro/Edit and Modify /Extend ", "F7\tCámara/Desplazar", "F2\tVer/Geometría oculta", "F3\tVer/Objetos ocultos", "Mayúsculas+P\tExtensiones/1001bit Pro/Draw /Draw perpendicular line (3D) ", "Alt+2\tDibujo/Circle from edge", "Ctrl+3\tExtensiones/3 point Rectangle/3 point Rectangle", "Ctrl+E\tHerramientas/Fredo6 Collection/JointPushPull/Quick Launcher...", "F6\tHerramientas/Fredo6 Collection/Souvenir/Task List Current Model", "F5\tHerramientas/Fredo6 Collection/Souvenir/Task List SketchUp", "F4\tHerramientas/Fredo6 Collection/Souvenir/Favorites", "Alt+Z\tCámara/Zoom", "Alt+F\tCámara/Vistas estándar /Frontal", "F12\tCámara/Vistas estándar /Abajo", "F11\tCámara/Anterior", "Alt+J\tHerramientas/Fredo6 Collection/JointPushPull/Joint Push Pull", "Mayúsculas+M\tEdición/Eliminar guías", "Espaciar\tHerramientas/Curic/Recall Command", "Alt+V\tCámara/Ventana de zoom", "Alt+0\tHerramientas/nz_Edge2Polygon/PolygonByEdge", "Ctrl+Mayúsculas+Z\tCámara/Aplicar zoom a fotografía", "`\tEdición/Mostrar/Último", "Ctrl+Alt+Mayúsculas+E\tHerramientas/Fredo6 Collection/JointPushPull/Joint Push Pull", "Mayúsculas+A\tExtensiones/1001bit Pro/Edit and Modify /Extend ", "F9\tVer/Objetos ocultos", "Alt+D\tCámara/Desplazar", "Mayúsculas+Espaciar\tHerramientas/Seleccionar", "S\tHerramientas/Sígueme", "Ctrl+L\tArchivo/Enviar a LayOut...", "Mayúsculas+N\tArchivo/Nuevo a partir de una plantilla...", "Ctrl+W\tArchivo/Exportar/Gráfico 2D...", "Ctrl+R\tArchivo/Generar informe...", "Mayúsculas+T\tHerramientas/Transportador", "Ctrl+Alt+P\tHerramientas/Pintar", "Alt+O\tVer/Objetos ocultos", "Alt+G\tArchivo/Guardar como...", "Alt+8\tArchivo/Guardar una copia como...", "Alt+9\tArchivo/Guardar como plantilla...", "Ctrl+Alt+E\tVentana/Extension Warehouse", "Ctrl+Alt+B\tEdición/Bloquear", "Ctrl+Alt+D\tEdición/Desbloquear/Todas", "Ctrl+D\tEdición/Cerrar grupo/componente", "Ctrl+J\tEdición/Intersecar caras/Con la selección", "Ctrl+K\tDibujo/Mostrar ejes", "Ctrl+M\tVer/Guías", "Ctrl+1\tVentana/Mostrar Sombras", "Ctrl+2\tVer/Estilo de arista/Aristas", "Ctrl+4\tVer/Estilo de arista/Perfiles", "Ctrl+5\tVer/Estilo de cara/Rayos X", "Ctrl+6\tVer/Estilo de cara/Alambre", "Ctrl+7\tVer/Estilo de cara/Líneas ocultas", "Ctrl+8\tVer/Estilo de cara/Sólido", "Ctrl+9\tVer/Estilo de cara/Sólido con texturas", "Ctrl+0\tVer/Estilo de cara/Monocromo", "Alt+W\tCámara/Proyección paralela", "Alt+Y\tCámara/Perspectiva", "Alt+U\tCámara/Vistas estándar /Abajo", "Ctrl+Alt+R\tHerramientas/Fredo6 Collection/SUClock/Configure Tracking Project", "Mayúsculas+W\tCámara/Vistas estándar /Izquierda", "Mayúsculas+Y\tCámara/Vistas estándar /Derecha", "Mayúsculas+U\tCámara/Vistas estándar /Isométrica", "Ctrl+Alt+A\tCámara/Vistas estándar /Atrás", "Mayúsculas+I\tCámara/Orbitar", "Alt+I\tArchivo/Importar...", "Mayúsculas+O\tCámara/Anterior", "Ctrl+Alt+C\tCámara/Caminar", "Ctrl+Mayúsculas+R\tDibujo/Formas/Rectángulo rotado", "Mayúsculas+H\tDibujo/Arcos/Arco de 2 puntos", "Mayúsculas+J\tDibujo/Arcos/Circular", "Mayúsculas+K\tDibujo/Herramientas 2D.../2D Z-Plano", "Alt+X\tDibujo/Herramientas 2D.../2D Estirar", "Ctrl+Alt+X\tExtensiones/FullScreen/Show UI", "Mayúsculas+1\tDibujo/Dibac/Muro", "Mayúsculas+2\tDibujo/Dibac/Muro paralelo", "Mayúsculas+3\tDibujo/Dibac/Prolongar muro", "Mayúsculas+4\tDibujo/Dibac/Puerta", "Mayúsculas+5\tDibujo/Dibac/Ventana", "Mayúsculas+6\tDibujo/Dibac/Armario", "Mayúsculas+7\tDibujo/Dibac/Elegir carpintería", "Mayúsculas+8\tDibujo/Dibac/Escalera", "Mayúsculas+9\tDibujo/Dibac/Cota continua", "Mayúsculas+0\tDibujo/Dibac/Convertir en 2D/3D", "Alt+1\tDibujo/Dibac/Get Dibac", "Alt+N\tHerramientas/Texto 3D", "Mayúsculas+B\tHerramientas/Caja de arena/Estampar", "Alt+4\tVentana/Información del modelo", "Ctrl+Alt+2\tVer/Restaurar ejes (entorno)", "Ctrl+Alt+1\tVer/Ejes", "Ctrl+Mayúsculas+C\tCámara/Caminar", "Ctrl+Alt+Mayúsculas+P\tCámara/Proyección paralela", "Mayúsculas+S\tHerramientas/Fredo6 Collection/Souvenir/Task List SketchUp", "Mayúsculas+F\tHerramientas/Fredo6 Collection/Souvenir/Favorites", "H\tVer/Barras de herramientas...", "Ctrl+Alt+J\tVentana/Mostrar Información de la entidad", "Ctrl+Alt+K\tVentana/Mostrar Esquema", "Ctrl+Alt+L\tVentana/Mostrar etiquetas", "'\tHerramientas/Fredo6 Collection/LordOfTheToolbars/Cycle through Palettes"]
                                • P
                                  PedroE
                                  More errors detected: when you alternate the sketchup full screen with another window using a shortcut (ctrl + alt + tab) vignettes bar disappears, it only appears with popup the vignette stripe command.
                                  The palette windows do not retain the custom size when a shortcut popup is opened with a shortcut key, they adjust automatically.
                                    rv1974
                                    Some minor inconvenience here:
                                    I have some locked favorite toolbar put in some properplace before closing SU. After SU restarting I see it closed and I need to click the dedicated palette icon to restore the status. Could LOTT remember the toolbars position before SU closing?
                                    PS Exporting config file before SU exit doesn't help.
                                    • fredo6F
                                      Thanks for signaling. Bug introduced in latest version (v1.4c) and fixed in next version.
                                      • fredo6F
                                        Which key combination do you use. I don't observe the problem with Alt-Tab and Ctrl-Alt-Tab
                                        This is normal. When you use a shortcut to make a palette appear, LOTT display the palette expanded, so that you can see all command icons. When you click a command (or click in the empty space or press escape), the palette will automatically disappear.
                                        • P
                                          PedroE
                                          The problem is when you have many buttons and the window can be excessively large, if you could keep a custom window size, the most used buttons would be visible and the rest would appear by sliding with the mouse wheel.
                                          Extend
                                          Fit
                                          • fredo6F
                                            Then, I can make it an option.
                                            Again, the shortcut is to make the palette temporarily show so that you can select a command icon. So, even if there are lot of icons, this is just for temporary selection.
                                            • 27
                                            • 28
                                            • 3 / 28
