    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.0m Views 329 Watching
      kakashi66
      Does this plugin work with 2020? I've installed it several times and I can't find it anywhere.
        Yes. It works in SketchUp 2020. It should show up under Extensions>Chris Fullmer Tools or you can activate its toolbar.
          Grey24601
          Hi Tig,
          Sketchup 2020
          I can not work out why the shapebender is not working. It creates the correct ghost but when I accept it, it just rotates the object? Any ideas/ What have I done wrong.
          shape.skp
            You've set up the model incorrectly. You should have the straight line directly in front of the straight component as I have here. Not strung out down the red axis as you did.
            Correct setup.
            Bent result
            Set up as I show it, Shape Bender works as expected. It put the bent version the same distance behind the curve as the straight component is behind the straight line.
            You want to remember that the relationship between the location of the straight component and straight line affects the relationship of the bent component to the curve. Shape Bender did exactly what you asked it to do even though it's not what you were hoping for.
              AndressaRPassos
              Please, I need Help.
              Using Sketchup 2019, using shape bender and doing all the steps, the console ruby returns...
              Error: #<NoMethodError: undefined method /' for nil:NilClass> C:/Users/andre/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/clf_shape_bender/clf_shape_bender_data.rb:624:in draw'
              I need help!
                Go to the Extension Warehouse and install the latest version from there. Then restart SketchUp and see how it goes.
                When you installed SketchUp 2019 did you right click on the downloaded installer and choose Run as administrator from the Context menu? If not, or if you don't remember, do so now and choose the Repair option when it is presented. That'll make sure you have folder permissions set correctly.
                If you don't have the 2019 installer you can get it from sketchup.com/download/all
                • V Offline
                  vmayol
                  Hi i can not install the plug in. it says unsigned. what should i do. thank you vicky.
                    Why can't you install it? "Unsigned" has no bearing on whether of not an extension will work. It will load if you have the Loading Policy set to allow it.
                    What version of SketchUp are you actually using? Your profile indicates SketchUp 2021 Make which does not exist.
                    • pep75P Offline
                      pep75
                      Can't manage it to work in 2021....😞 Anyone a solution?
                        Probably incorrect set up. It works fine in 2021 here. Click on the picture.
                        Make sure you've set up the model correctly.
                        Share the file so we can see what you've got.
                        • pep75P Offline
                          pep75
                          Thanks Dave, but I can't install it!
                          • pep75P Offline
                            pep75
                            Sorry, it works now...in the Extension Manager the 'disabled' switch was on....😞 (?)
                              That's different than it not working.
                              Did you disable it at some point?
                              • pep75P Offline
                                pep75
                                Not that I'm aware of...don't know why I would do that. Strange..But thanks for you support!
                                  dothibichngoc
                                  I have taken the steps
                                  but when i click on the curve it doesn't show the histogram
                                  I keep pressing enter but no result
                                    Share the .skp file so we can see what you have.
                                    What version of SketchUp are you actually using? Your profile says 2019 Make but there is no such version.
                                      cboy1980
                                      Something I noticed, but probably already posted somewhere here is that if the group and accordingly the straight line is bigger than the curve (in length) it will give very strange outcomes.
                                      So make sure that the part that needs to be bend is in length shorter than the curve.
                                      Hope that helps
                                        If the object being bent is not the same length as the curve, it will be stretched or compressed to the length of the curve. If you don't want that distortion, make the straight object the same length as the curve. Also keep in mind that the location of the straight line relative to the straight object affects the bent object.
                                          mrdg Newcomers
                                          Can you fix the end of a bent object where the edges get soften for no reason.
                                            Yes. You can quickly fix that by triple clicking on the bent component with Select and then right click on it and choose Soften/Smooth.
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 63 / 64
