    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.2m Views 120 Watching
    • duanekempD
      duanekemp
      Because Animator exports .png files... the image size is larger than a .jpg (which would be preferable) and so, each image is around 1.46 MB.
      But, now you have me curious... How does Thea know the path and animation created in Animator in order to render the same animation from Thea?
      Ah... hadn't tried the Thea animation tool (Animator plugin).
      Giving this a go in Thea V3: http://kb.thearender.com/thea-for-sketchup-v15/export-animation-studio/
      Duane Kemp
      Kemp Productions
      Puidoux, Switzerland
      Gallery:
      https://duanekemp.artstation.com/
      • fredo6F
        The Thea team was kind enough to integrate Animator in their list of animation programs, based on an API I provided to them.
        Tell me if it works better...
        • duanekempD
          duanekemp
          Tell me if it works better...[/quote]
          So far, it's rendering but not exporting the renders to the folder. For a moment, I thought this was going to be the solution.
          Duane Kemp
          Kemp Productions
          Gallery:
          • duanekempD
            duanekemp
            @jql said:
            Thanks for providing this solution so fast!
            I will resume my endeavours with animator asap!
            @JQL, have you used this plugin since Thea Render V3 came out?
            Duane Kemp
            Kemp Productions
            Gallery:
            • T
              tiquibachaaaaa
              I have a problem while animating. I press the play but it doesn't show the movements, the only way it shows is when I open the window for export images and press the play button.
              • C
                Calcifer
                Hello Fredo,
                I am having an issue I never had before with animator:
                I animated some spinning gears. It works fine when I scroll through animator. But when I export, some gears don't spin. I go back to the project and they spin properly. Here are few odd things: some spin, some don't. The ones that don't, I tried to change the axis (from x to z) and it works. But when I move it again, it doesn't work anymore. I tried several things: changing the group/object axis. I also tried to rotate the gear within the group. It doesn't work. I tried to use the model axis and the object axis, same results. I also exploded the gears, regrouped them, gave them a different name and re animated: still doesn't work. The odd thing is when I create another object (cube, cylinder, I even tried another complex shape), it works.
                I have been using Animator for years now and it's the first time I get this specific issue.
                Thank you in advance
                • fredo6F
                  @calcifer said:
                  Hello Fredo,
                  If you could send me the model, I could have a look.
                  Note that spinning symmetrical objects (like gears), may also give the impression of static movement when it spins too fast or at a multiple of the frame rate. I would suggest you put a color mark on the gears to verify whether they spin or not.
                  • C
                    Calcifer
                    Hello Fredo and thanks for your response.
                    It turns out indeed those specific gears are moving. I did slow them down and put a color mark. It works. Thanks again.
                    I take the opportunity to ask a more genereal question about Animator: when a model is more complex, animator takes a while to respond (it can take up to 30 seconds to have a menu open - like, when I create a new movement). Granted I now have a lot of objects and moving parts in the file. In the past tried to lighten the model buy using proxies (for the static parts) but it remains the same. Outside of animator I can navigate very smoothly.
                    I know my hardware is getting a bit old: which part of the hardware should be updated to increase animator performances? I think i have a decent cpu but my gpu is now very old.
                    Thanks again for your fantastic plugin.
                    • fredo6F
                      Animator is dependent on the complexity of the model for some functions of the editor, as it needs to go through object hierarchy in the model.
                      Which 'menu' can take 30 seconds to open?
                      • C
                        Calcifer
                        The best example is when adding a new movement. Clicking on the icon is instant but accessing the panel (translation, spin, rotate etc...) takes about 30 seconds. Then, it's fine, I can select the object almost instantly. Entering the value takes about 10 seconds to process the information. Then closing the new movement takes a bit of time as well. Also, If I want to edit a clip, it takes about 15 seconds to open it to adjust.
                        My model is quite complex - I believe - so any change can take some time. Hence i was wondering if I could boost my computer in some way.
                        You got me curious about the hierarchy: does it mean that it would take more time to animate an object that is deep into the hierarchy over one that is at the top? I have to say I didn't notice any performance difference depending on which object I work on.
                          Sugareth
                          Hi Fredo,
                          Firstly, thanks for the animator plugin, I have used it many times over the years. I might have missed something obvious, but with the latest update I don't seem to be able to insert a rotation animation? Previous versions of the plugin this was fine.
                          What am I doing wrong?
                          Sugareth
                          https://i.imgur.com/mF2XG51.gif
                          Edit
                          Second issue I am having, previously I could double click on a sequence and it would let me edit the translation etc. - has this functionality been removed?
                          https://i.imgur.com/g2BpDJe.gif
                          Edit 2
                          https://i.imgur.com/eTdT4Re.png
                          Restarted Sketchup, the menu is now appearing OK.
                          Edit 3...
                          Trying to recreate the bug - appears to happen when I temporarily exit to Sketchup. The movement type window then doesn't reappear. When I close Sketchup I also notice that the "Temporarily Exit to Sketchup" dialog from Animator is still open.
                          • fredo6F
                            Could you open the Ruby console to see if there are error messages.
                            • fredo6F
                              New Release: Animator - v3.6a - 21 Sep 21
                              Requirement: LibFredo6 v11.5
                              Maintenance release
                              • Extension of validity
                              See plugin home page of Animator for Download of RBZ from the PluginStore.
                              See Main Post of the Animator thread for more information.
                              • N
                                nate101090
                                HELP! I just installed and started using animator plug in today, and I created a long animation with many moving parts. I successfully saved an animator file along with my progress today, but not there seems to be a glitch. I can see all of the assets in the timeline, but I can't scrub through the timeline. When I click back to beginning it won't take me there, and when I click on generate video...all the windows disappear and I can't see the generate window box that I did see before. Not sure how to solve this glitch and open the generate window box again.
                                • fredo6F
                                  Difficult to say anything without having the model.
                                  At least, could you open the Ruby Console while running Animator.
                                  • duanekempD
                                    duanekemp
                                    Hello,
                                    Trying to test Thea with Animator again with an older version of SketchUp (2020).
                                    When I launched Animator, it said that the version no longer worked and needed updating.
                                    I update LibFredo6 and through the SketchUcation store plugin, tried to update Animator. Didn't work. Tried direct download and SketchUp Extension Manager wouldn't work either, saying Failed to install Animator_v3.6.rbz and with the Extension store the message is UnZip Error: Could not upzip archive.
                                    Has something changed that it won't install on SU2020?
                                    Actuallymessage from SU20 & SU21, just did the same exact thing in SU2021...
                                    Duane Kemp
                                    Kemp Productions
                                    Gallery:
                                    • duanekempD
                                      duanekemp
                                      And... for some reason, with SU2021, there was no problem with the update today! Hmmm.
                                      Interesting. I did nothing different.
                                      Duane Kemp
                                      Kemp Productions
                                      Gallery:
                                        demiremre
                                        Hello Fredo
                                        I've been using Animator for a long time and I love it.
                                        Im working on a important animation work (deadline is tomorrow 😞 ) but suddenly I got an error window like in the picture. I downloaded it and try to update but nothing has changed. It's seems on the latest version in extension manager.
                                        I deleted and reinstalled, used in higher sketchup versions but I got still same error.
                                        Windows 10
                                        Sketchup 2020
                                        • C
                                          Calcifer
                                          Hello Fredo,
                                          Just wanted to mention that I have the same issue. I am also getting the message I have to update the plugin.
                                          Windows 10, SU 2021
                                          • duanekempD
                                            duanekemp
                                            I too downloaded the 3.6 version for SU2022, didn't work. So I installed it with the SketchUcation store plugin... still didn't work.
                                            Continue to get message:
                                            "This version of Animator has expired
                                            Please upgrade to the lattest version
                                            Go to the Download Page on Sketchucation?"
                                            So, thought to try and update LibFredo6 to see if that was the culprit.
                                            No change. Any suggestions?
                                            And I confirm, SU2021 has the same issue.
                                            Duane Kemp
                                            Kemp Productions
                                            Gallery:
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 29
                                            • 30
                                            • 22 / 30
