Plugin Search
Hi All - Is there any plugin that helps me to arrange multiple groups or components:
A: in a row? and at the same time
B: allows me to define a desired distance between them?
similar to a row of bricks of a wall layer, and all of them have the same joint between each other.thanks in advance
Sam D Mitch's Comp String might sort you out.
http://sdmitch.blogspot.com/
Or his align. -
Thanks Box (*) - that was exactly what I searched for
(*also for your speed
Maybe someone has Sam D Mitch's "Comp String" plugin? I am just looking for a similar solution. https://forums.sketchup.com/t/arrange-components/169188
Sam D Mitch has withdrawn his extensions and it wouldn't be right to share them. You might look at S4U Align from the SCF Plugin Store or Curic Align from the Extension Warehouse.
Thanks Dave R. Yes, others have suggested a solution to me too using Curic plugins. Curic Reset Rotation + Curic Space + Curic Align
