    Sketchup always freezing
    13 Posts 6 Posters 4.1k Views 6 Watching
      @mixzzz007 said:
      So the problem is very anoying, it started a few days ago...
      Sketchup version 2018.
      Since this is new behavior and SketchUp 2018 hasn't changed since 2018, you need to look at what has changed on your computer. What is the graphics card? Did the drivers get an update with an OS update? Go to the graphics card manufacturer's site to get and install their latest drivers. It's not uncommon for Windows updates to include broken graphics drivers.
      Is the file size huge? Where are you saving the file to? Maybe you're waiting for an autosave to complete.
      When you installed SketchUp 2018 did you do so correctly? That involves right clicking on the downloaded installer and selecting Run as administrator while you are logged in as your normal user.
        mixzzz007
        My graphic card is nvidia rtx 2080 ti and as I mentioned before drivers are up to date, updated them after sketchup started these freezes. Maybe there's something with last windows update, but I have already uninstalled almost all, except those that cannot be removed.
        When installed fresh I did install as administrator, so did not help, same situation..
        Autosave and file size has nothing to do with this problem, because it worked fine before
          So what else has changed on your computer since it last worked? Again, SketchUp 2018 didn't change so it has to be something else.
            mixzzz007
            Sometimes when minimizing and opening again browser PC reacts not so fast and not so quickly restores an already open image as before. So this is one of the observations I think relates with sketchup slow performance. It gives the impression that the computer got slower with tasks
              So it could be that you have some software running that is consuming resources or maybe a hardware issue such as failing RAM. Maybe it's as simple as your computer is getting hot because it needs to have the dust and lint cleaned out of it.
                mixzzz007
                Yeah that's not it, cause sketchup 2020 (demo) version works just fine with same files without any problems, that 2018 version having difficulties
                  2020 has some performance increases over previous versions 2018. SU2021 has had even more. Maybe it's time to update to the current version of SketchUp. Again, though, since 2018 did work fine for you until recently, the problem isn't in SU2018.
                  • jujuJ
                    juju
                    I think the problem could be Windows related. Since 01/06/2021 I've had issues in how my machine runs and another program which suddenly started working erroneously, the only answer I could come up with is Windows (10) updates.
                    • G
                      Glenn at home
                      Point of reference: Home PC
                      Windows 10 Pro v 20H2
                      OS build: 19042.1052
                      Current SU version: 21.1.279
                      No issues
                      • K
                        Kenny
                        Could it be a plugin/extension in 2018 causing the issue, that is not in 2020?
                        I would recommend using 2021 if possible. There has been a lot of 'under the hood' improvements with bug fixes etc.
                        http://www.townscapesolutions.co.uk/
