    [Plugin] ChrisP_ColorEdge
    67 Posts 35 Posters 102.0k Views 35 Watching
    • OxerO
      Oxer
      I use Sketchup with my students in the technical drawing lessons and it's very useful draw the edges with different colors. Would be possible assign another different key to TAB to select the different colors on Mac?
      For example in Ivy plugin the ALT and SHIFT keys work fine.
      • sdmitchS
        sdmitch
        Yes. Any key that works for you will do. However, there is one other problem that I found. On two occasions, colr1 = results and color1 = results should be colr1 = results[0] and color1 = results[0]. These statements appear around line 233 and 754.
        Another problem is the number of Sketchup Colors far exceeds the number the inputbox pull-down can handle. It needs to be a WebDialog if you really want all the color choices.
        http://sdmitch.blogspot.com/
        • OxerO
          Oxer
          Thanks for the info sdmitch but I changed the lines 233 and 754 but nothing, the TAB key doesn't work 😞
          • sdmitchS
            sdmitch
            Remember nothing happens until the Tab key is released. Please check messages. I have sent a copy of the plugin I modified and tested.
            • boofredlayB
              boofredlay
              I understand this is an old plugin. Maybe someone has a quick fix but if not no problem.
              I am experiencing the lines being drawn outside the group or component being edited. See attached.
              • FrederikF
                Frederik
                What happens if you mark them
                Cut them to the clipboard
                Open the model group and paste them back where you want them...?
                Cheers
                Kim Frederik
                • boofredlayB
                  boofredlay
                  That works just fine, which is what I did most of the day (large building with joint lines). But it is an extra step not needed if they were drawn inside the group/component.
                  Edit: If I had started it the other way (draw default lines in a separate group and just painted the group) I might have saved some time today. However, once down a path...
                    Skatepark
                    Hey Chris, I am having trouble modifying colours on mac. I am clicking TAB but the color menu doesn't open so it's on default all the time... Any suggestions?
                    Cheers
                    • H
                      hygicell
                      how do I install the other icons ?
                      • P
                        pribadi
                        saya tidak bisa menemukan file coloredge untuk mengunakannya
                        mohon petunjuk dimana downloadnya dan cara instalnya di sketchup pro 8
                          Download its .RBZ file from the SketchUcation PluginStore...
                          https://sketchucation.com/pluginstore?pln=ChrisP_ColorEdge_EN
                          If your version-8 is the latest update you can install that RBZ using the Preferences > Extension > Install button...
                          Otherwise you can rename the .RBZ file as .ZIP, then extract all of its contents into a temp folder, and then move everything into your v8 Plugins folder, ensuring everything is kept properly as extracted...
                          Then restart SketchUp to load things...
                          Unduh file .RBZ-nya dari SketchUcation PluginStore ...
                          Jika versi-8 Anda adalah pembaruan terbaru, Anda dapat menginstal nya menggunakan Preferensi > Ekstensi > tombol Instal ...
                          Jika tidak, Anda dapat mengganti nama file .RBZ menjadi .ZIP, kemudian mengekstrak semua isinya ke folder temp, dan kemudian memindahkan semuanya ke folder Plugin v8 Anda, memastikan semuanya disimpan dengan benar seperti yang diekstrak ...
                          Kemudian mulai ulang SketchUp untuk memuat sesuatu ...
                          • 4 / 4
