    [Plugin] SU2POV 3.5
    77 Posts 26 Posters 65.7k Views 26 Watching
    • TrixtaT
      Trixta
      Thank you Didier Bur. for SU2POV 7. 😍
      Win7 & SU14 Pro
      • T
        togethearth
        Je ne sais si un autre renderer OS ou gratuit pour SU existe, mais pour ceux qui ont POV 3.7, il faut changer un peu povray.ini et rajouter :
        version = 3.6
        ça permet, par exemple, de retrouver la couche alpha (transparent). Il faudrait un MAJ de su2pov pour intégrer la version ça va devenir obligatoire dans le futur de POV.
        • T
          togethearth
          il y faut enlever la ligne interpolate dans les .pov pour que le rendu se fasse :
          texture {
          uv_mapping pigment {
          image_map {
          jpeg "drifting_planes.jpg"
          map_type 0
          interpolate 0
          • TandemT
            Tandem
            Does anyone got this plugin to work with SU 2014?
            I just installed this using SketchUcation Tools 2.6.0, installation was successful, but after restarting SU I get this error message:
            Error; /users/Jane_Doe/library/application support/sketchup 2014/sketchup/plugins/su2pov35.rbs;859; invalid multibyte char (UTF-8)
            /users/Jane_Doe/library/application support/sketchup 2014/sketchup/plugins/su2pov35.rbs;859; syntax error, unexpected '=', expecting ')'
            	str = str.gsub(/([ -#;'"$£=()|{}&+,;@-])/, '')
            /users/Jane_Doe/library/application support/sketchup 2014/sketchup/plugins/su2pov35.rbs;859; syntax error, unexpected ','
            /users/Jane_Doe/library/application support/sketchup 2014/sketchup/plugins/su2pov35.rbs;859; `@-' is not allowed as an instance variable name
            /Users/Jane_Doe/Library/Application Support/SketchUp 2014/SketchUp/Plugins/su2pov35Toolbar.rb;2;in `eval'
            /Users/Jane_Doe/Library/Application Support/SketchUp 2014/SketchUp/Plugins/su2pov35Toolbar.rb;2;in `require'
            /Users/Jane_Doe/Library/Application Support/SketchUp 2014/SketchUp/Plugins/su2pov35Toolbar.rb;2;in `<top (required)>'
            Error Loading File su2pov35Toolbar.rb
            Error; #<NameError; undefined local variable or method `ocr_env' for main;Object>
            /Users/Jane_Doe/Library/Application Support/SketchUp 2014/SketchUp/Plugins/su2pov35Toolbar.rb;4;in `<top (required)>'
            • majidM
              majid
              Dear Didier
              Thank you for all your efforts on POVray.
              I am still waiting for the nest release with more control on materials, maybe like the previous version please. 😄
              M.
                rx3750
                Hello,
                i tried to start with POV-Ray with SU2POV 3.5 and Sketchup 2015. I installed in into ... Appdata/Roaming/Sketchup/Sketchup2015/Sketchup/Plugins.
                There is now a
                • su2pov35Toolbar.rb
                • su2pov35.rbs
                • su2pov folder with another rbs data and other stuff
                When i start Sketchup i get the following:
                Error: c:/users/benutzer2/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su2pov35.rbs:859: invalid multibyte char (UTF-8)
                c:/users/benutzer2/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su2pov35.rbs:859: syntax error, unexpected '=', expecting ')'
                str = str.gsub(/([ -#:'"$£=()|{}&+,;@-])/, '')
                c:/users/benutzer2/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su2pov35.rbs:859: syntax error, unexpected ','
                c:/users/benutzer2/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su2pov35.rbs:859: @-' is not allowed as an instance variable name C:/Users/Benutzer2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su2pov35Toolbar.rb:2:in eval'
                C:/Users/Benutzer2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su2pov35Toolbar.rb:2:in require' C:/Users/Benutzer2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su2pov35Toolbar.rb:2:in <top (required)>'
                Fehler beim Laden der Datei su2pov35Toolbar.rb
                Error: #<NameError: undefined local variable or method ocr_env' for main:Object> C:/Users/Benutzer2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su2pov35Toolbar.rb:4:in <top (required)>'
                Error: #<LoadError: cannot load such file -- C:/Users/Benutzer2/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SU_Podium_V2/plug_in/extensions/ProgressBar.bundle/Contents/MacOS/ProgressBarLoader.bundle>
                C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                I am not sure if anything comes from SU2POV, because some crap comes from SU-Podium V2, but i wasn't able to deinstall and delete it, it came back again.
                I couldn't find a newer Version of SU2POV and i am also not sure if both are compatible (SU2POV35 + Sketchup 2015).
                It would be nice, if you could help me. Thanks!
                • B
                  bedavisdesign
                  I have used SU2POV for quite awhile with SU8. It has been my favorite rendering exporter. Recently I bit the bullet and updated SU to 2015.
                  I also am trying to successfully run SU2POV 3.5 on SU2015. The installation was "successful", although when I restart sketchup I also receive these errors:
                  Error: c:/users/brian/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su2pov35.rbs:859: invalid multibyte char (UTF-8)
                  c:/users/brian/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su2pov35.rbs:859: syntax error, unexpected '=', expecting ')'
                  c:/users/brian/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su2pov35.rbs:859: syntax error, unexpected ','
                  c:/users/brian/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su2pov35.rbs:859: @-' is not allowed as an instance variable name C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su2pov35Toolbar.rb:2:in eval'
                  C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su2pov35Toolbar.rb:2:in require' C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su2pov35Toolbar.rb:2:in <top (required)>'
                  Error: #<NameError: undefined local variable or method ocr_env' for main:Object> C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su2pov35Toolbar.rb:4:in <top (required)>'
                  Any help with a fix for this would be GREATLY appreciated.
                    Markymarc
                    Bonjour Didier,
                    Après installation de pov-ray 3.7 RC7 et de ton plugin, j'ai ces messages d'erreurs...
                    Error: c:/users/pc marc/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/su2pov35.rbs:859: invalid multibyte char (UTF-8)
                    c:/users/pc marc/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/su2pov35.rbs:859: syntax error, unexpected '=', expecting ')'
                    c:/users/pc marc/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/su2pov35.rbs:859: syntax error, unexpected ','
                    c:/users/pc marc/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/su2pov35.rbs:859: @-' is not allowed as an instance variable name SketchUp:1:in eval'
                    Error: #<NameError: undefined local variable or method ocr_env' for main:Object> C:/Users/Pc Marc/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/su2pov35Toolbar.rb:4:in <top (required)>'
                    Pourrais tu m'aider?
                    D'avance merci
                    • I
                      igorko223341
                      Error: #<SyntaxError: c:/users/routers/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/su2pov35.rbs:859: invalid multibyte char (UTF-8)
                      c:/users/routers/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/su2pov35.rbs:927: invalid multibyte char (UTF-8)
                      c:/users/routers/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/su2pov35.rbs:992: invalid multibyte char (UTF-8)>
                      SketchUp:1:in eval' Ошибка при загрузке файла «su2pov35Toolbar.rb» Error: #<NameError: undefined local variable or method ocr_env' for main:Object>
                      C:/Users/Routers/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/su2pov35Toolbar.rb:4:in `<top (required)>'
                        If you look back through the last few posts you can see that this extension hasn't worked in newer versions of SketchUp for a number of years. At this point it doesn't seem like that's going to change. I don't know what Didier has in mind but for now I would uninstall this and look for some alternative.
                        • 4 / 4
