    [Plugin] SU2POV 3.5
    77 Posts 26 Posters 65.7k Views 26 Watching
      alanr
      I may be missing something but maybe not - applied a texture to a surface (tiles in fact) and although I can edit the texture in SU especially the scale and obviously SU shows this, when rendered the pattern remains unaffected by whatever scale I set in SU. Is there a way around this, so that the view in SU comes out exactly the same when rendered?
      Thanks.
        alanr
        Created a sphere in SU - gave it a colour (or texture makes no difference) but right click over it and I am not offerred "edit pov finish" option - why is that? I'm sure I've just missed something. Yes its been saved and renders with POV succesfully, but I'm just not able to set any of the preset finishes or surface effects. Can do it with a cube so whats wrong?
        Thanks.
        • Didier BurD
          Didier Bur
          I think there are some bugs with curved/round surfaces still remaining 😳
          Will check that when time permits,
          Regards
          DB
            alanr
            Ok thanks for that - sometimes it seems to work but so far I have not been able to pin down the exact circustances - when and if I do I'll let you know in case it helps you.
            Another point - I applied a texture to a surface (tiles texture in fact) and although I can edit the texture in SU especially the scale and obviously SU shows this, when rendered, the pattern remains unaffected by whatever scale I set in SU. Is there a way around this, so that the view in SU comes out exactly the same when rendered? I can search out the definition in the pov file and obviously edit the scale element, but this is tedious and has to be repeated for every new render.
            Thanks.
            • P
              paisleyatlarge
              I have downloaded sketchup 8, and downloaded SU2POV, and dropped the Su2pov35 folder intact with all its subfolders inside into the plugins folder according to instructions. In the sketchup 8 menu bar I don't see the plugins drop menu just to the left of the help drop menu as is shown in the tutorial's picture. Is that only on sketchup 7 or does it work on 8 as well? If this only works with 7, where would I find a copy of that version?
              I hate to appear so dumb, but I can't figure this out. I feel like I am really missing something very obvious here.
              • P
                paisleyatlarge
                OK, I figured it out! You have to COPY (or cut) OUT of the Su2pov35 folder everything in it and then paste that into the plugin folder exactly as it was in the Su2pov35 folder.
                NOT just drop the entire Su2pov folder into the plugin folder, ONLY the contents.
                I bet it must be quite tedious to hear that question a lot.
                  JPMedallion
                  I am having a problem with SU2Pov 3.5 plugin (using SU 8 pro with XP). It is loaded and all works except none of the windows from the tool bar close when I click OK or Cancel, therefore not generating any commands. To close the window I have to click the X in the upper right hand corner. After doing that a light will be placed in the scene for example, but is not active in the ".pov" file. Also, the scene is sent to POV when the Render button is clicked. The scene does render but is without lights or any other features, only renders the default SU settings. Any ideas? Could it be my computer?
                  Many thanks for your plugin and any suggestions you may have.
                    artfreak
                    I am also having a problem with with this plugin I have windows XP SketchUp Pro 8 I was using su2pov 3.4 and it was working fine but when I uninstalled the the old one and installed the new 3.5 update Aug.31 edition(the latest).
                    I get this message:
                    Error loading file su2pov35 toolbar.rb
                    private method "split" called for nil:Nilclass
                    Any answer for this, please?
                    artfreak
                    • Didier BurD
                      Didier Bur
                      Hi artfreak,
                      Weird. Mine works like a charm. Please open the ruby console, run su2pov and copy-paste the entire error message please (so I can see at what line the "split" crashes. Thanks.
                      DB
                        artfreak
                        Here is the results from the Ruby Console.
                        Run su2pov
                        Error: #<NameError: undefined local variable or method su2pov' for #<Object:0x5d0f9e4>> (eval):155 Run su2pov35Toolbar.rb Error: #<NameError: undefined local variable or method su2pov35Toolbar' for #Object:0x5d0f9e4>
                        (eval):155
                        • Didier BurD
                          Didier Bur
                          @artfreak,
                          By "run su2pov" I was meaning "click on the render icon".
                          Sorry it was not clear, please try again. Thank you.
                          DB
                            Seriago
                            Didier,
                            Do I understand the 3.6 does not work for on Mac and since there is no Beta version 3.7 its no go so far?
                            I get this message:"You can’t open the application “POV-Ray Mac 3.6” because PowerPC applications are no longer supported."
                            Thanks with hope there is a light.
                              Jesty
                              Bonjour, j'ai une erreur quand je lance sketchup avec pov²ray35 ça me met une erreur su2pov35Toolbar.rb avec undefined local variable or method 'ocr_env' for main:object
                              merci de m'indiquer la solution pour y remedier et bonne continuation.
                              • Didier BurD
                                Didier Bur
                                @Jesty:
                                Bonjour,
                                Il y a 2 possibilités:
                                • soit le fichier "povray_reserved.txt" n'est pas là ou pas au bon endroit (dans Plugins/su2pov)
                                • soit le fichier "su2pov35.rbs" n'est pas là ou pas au bon endroit (dans Plugins)
                                Tiens moi au courant
                                DB
                                  Jesty
                                  @didier bur said:
                                  @Jesty:
                                  Bonjour,
                                  Bonjour, merci de votre aide
                                  voila j'ai mis les fichiers au bon endroits mais une erreur surviens
                                  from message 000_AdditionalPluginFolders
                                  Erreur : undefined local variable or method 'ocr_env' for main:Object
                                  ok j'ai enlever tout les plugins puis reinstaller supov35 et ça fonctionne a part que ça me met une erreur
                                  povray errors occurred when renaming your textures files probably because
                                  No such files or directory c:/user/.../.../povray
                                  /.........texture.jpg
                                  • TrixtaT
                                    Trixta
                                    Thank you Didier Bur. for SU2POV 7. 😍
                                    Win7 & SU14 Pro
                                    • T
                                      togethearth
                                      Je ne sais si un autre renderer OS ou gratuit pour SU existe, mais pour ceux qui ont POV 3.7, il faut changer un peu povray.ini et rajouter :
                                      version = 3.6
                                      ça permet, par exemple, de retrouver la couche alpha (transparent). Il faudrait un MAJ de su2pov pour intégrer la version ça va devenir obligatoire dans le futur de POV.
                                      • T
                                        togethearth
                                        il y faut enlever la ligne interpolate dans les .pov pour que le rendu se fasse :
                                        texture {
                                        uv_mapping pigment {
                                        image_map {
                                        jpeg "drifting_planes.jpg"
                                        map_type 0
                                        interpolate 0
                                        • TandemT
                                          Tandem
                                          Does anyone got this plugin to work with SU 2014?
                                          I just installed this using SketchUcation Tools 2.6.0, installation was successful, but after restarting SU I get this error message:
                                          Error; /users/Jane_Doe/library/application support/sketchup 2014/sketchup/plugins/su2pov35.rbs;859; invalid multibyte char (UTF-8)
                                          /users/Jane_Doe/library/application support/sketchup 2014/sketchup/plugins/su2pov35.rbs;859; syntax error, unexpected '=', expecting ')'
                                          	str = str.gsub(/([ -#;'"$£=()|{}&+,;@-])/, '')
                                          /users/Jane_Doe/library/application support/sketchup 2014/sketchup/plugins/su2pov35.rbs;859; syntax error, unexpected ','
                                          /users/Jane_Doe/library/application support/sketchup 2014/sketchup/plugins/su2pov35.rbs;859; `@-' is not allowed as an instance variable name
                                          /Users/Jane_Doe/Library/Application Support/SketchUp 2014/SketchUp/Plugins/su2pov35Toolbar.rb;2;in `eval'
                                          /Users/Jane_Doe/Library/Application Support/SketchUp 2014/SketchUp/Plugins/su2pov35Toolbar.rb;2;in `require'
                                          /Users/Jane_Doe/Library/Application Support/SketchUp 2014/SketchUp/Plugins/su2pov35Toolbar.rb;2;in `<top (required)>'
                                          Error Loading File su2pov35Toolbar.rb
                                          Error; #<NameError; undefined local variable or method `ocr_env' for main;Object>
                                          /Users/Jane_Doe/Library/Application Support/SketchUp 2014/SketchUp/Plugins/su2pov35Toolbar.rb;4;in `<top (required)>'
                                          • majidM
                                            majid
                                            Dear Didier
                                            Thank you for all your efforts on POVray.
                                            I am still waiting for the nest release with more control on materials, maybe like the previous version please. 😄
                                            M.
                                            • 4 / 4
