Make Ortho Views?
Hi All
Im after a quick tool that can turn models into ortho views that i can export out into AutoCAD. I have seen there used to be this plugin seen in this link http://www.smustard.com/script/MakeOrthoViews. Does anyone know what happened to this?
i know i can do the manually but Im trying to get quicker with my workflow. It would be great if this plugin is still around or if some one can creat a new one maybe?
thanks
The author has withdrawn that plugin so it's no longer available. I can't say that I've seen another one that does the same thing but you might have a look through the PluginStore here and the Extension Warehouse.
Hi there that's unfortunate
i have done a lot of looking for this plugin so i am gutted it has been redrawn, i have also email Smustard also. How easy would it be to write a plug in for this?
I'm not certain of why the author withdrew it but it is his to do with as he sees fit.
I don't know a lot about writing Ruby code but you could probably do it. Personally I prefer to export CAD files from LayOut and it would be easy enough to create a template in SketchUp with scenes for the desired ortho views and a template in LayOut to use for the scenes so everything is set up automatically. (I'd find that easier than writing a script, too.
You could be interested by this one
https://sketchucation.com/pluginstore?pln=CADupit's TIG's CADUP
another cool tool is MAKE 2D from CURIC ... but it's not free.
Hi, you can try this plugin from extension warehouse. This plugin called "M Moser Detail Modeling Mode"
It's worth noting the following which is copied from the Extension Warehouse page for the extension.
This extension is WIP (Work In Progress)
Licensed via Special Licensing Distribution within M Moser Associates for commercial uses
For the public, this extension is only for non-commercial uses only and bounded by Singapore laws and legislations.
