    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      Version 2.0.8 - 05.05.2021
      • Added pentagon windows to the window draw and edit menus for all wall types: rectangular, gable, shed and hip.
      • Added isoceles/equilateral triangle windows to the window draw and edit menus for all wall types: rectangular, gable, shed and hip.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 2.0.8b - 05.06.2021
        • Fixed a bug with exterior trim and wainscoting for trapezoid and pentagon windows.
        http://design.medeek.com/resources/wallplugin/images/wall_su537_800.jpg
        ***** CRITICAL BUG FIX *****
        If you are using either trapezoid or pentagon windows with exterior trim or wainscoting this is a critical bug fix. It is highly recommended to upgrade to this latest release to address this issue.
        design.medeek.com
        • medeekM Offline
          medeek
          Tutorial 20 - Trapezoid and Pentagon Windows (16:59 min.)
          design.medeek.com
          • medeekM Offline
            medeek
            Version 2.0.8c - 05.06.2021
            • Minor update to the window draw and edit menus.
            • Customized the wireframe preview for the Trapezoid and Pentagon window geometry.
            design.medeek.com
            • medeekM Offline
              medeek
              When a wall tees into another wall the “hide wall lines” algorithm does not remove those lines.
              I’m fixing that algorithm so that all the top plate lines/edges are hidden and you end up with a result like this:
              https://aws1.discourse-cdn.com/sketchup/original/3X/7/6/76630ea29bdbc73439f9242c6a06d1ca8d634630.jpeg
              design.medeek.com
              • medeekM Offline
                medeek
                Version 2.0.9 - 05.07.2021
                • Improved the "hide wall lines" feature for all wall types: rectangular, gable, shed and hip.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 2.1.0 - 05.08.2021
                  • Added a 2D symbol for pocket doors to the top of the wall for the following wall types: rectangular, gable and shed.
                  • Introduced additional logic into the Custom Material Library to prevent users from using double or single quotes in custom material names.
                  http://design.medeek.com/resources/wallplugin/images/wall_su539_800.jpg
                  http://design.medeek.com/resources/wallplugin/images/wall_su540_800.jpg
                  design.medeek.com
                  • pbacotP Offline
                    You add a plate below some headers. When is that required?
                    • medeekM Offline
                      medeek
                      The plates below and on top of the header are not required however I have the request for both options so in order to make the plugin as flexible as possible I provide for all options.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 2.1.1 - 05.09.2021
                        • Added an option for subtractive geometry into the Walls tab of the Global Settings.
                        • Sub-groups within wall panels can be made persistent and "subtractive" by naming these groups to (subtract1, subtract2, subtract3, etc...)
                        http://design.medeek.com/resources/wallplugin/images/wall_su542_800.jpg
                        http://design.medeek.com/resources/wallplugin/images/wall_su541_800.jpg
                        This is quite a major breakthrough for the wall plugin. I've been trying to think of a way to enable (manual) customization of the wall geometry for quite some time, specifically subtractive modifications. This system will now allow the user to achieve that goal.
                        Naming a group within the wall assembly to include the key word "CUSTOM" (case insensitive) will allow it to persist upon rebuild.
                        Naming a group within the wall assembly to include the key word "SUBTRACT" (case insensitive) will allow it to persist and boolean subtract from other groups within the assembly upon rebuild.
                        The subtractive group needs to be a valid solid for it to function correctly and its entity name needs to contain the key word "subtract" or "SUBTRACT".
                        What I like to do is create a special tag/layer for the subtraction geometry and then once I am done modifying or creating it I turn off the visibility of the layer/tag and only the holes or results in the wall geometry is shown.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 2.1.1b - 05.09.2021
                          • Components within wall panels can also be made persistent and "subtractive" by naming the component instance to (subtract1, subtract2, subtract3, etc...)
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 2.1.2 - 05.10.2021
                            • Added logic into the add and draw menus to prevent users from using single and double quotes in preset names.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 2.1.3 - 05.20.2021
                              • Fixed a bug with pocket doors when using the "No Frame" or "CMU" wall framing mode.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 2.1.4 - 05.29.2021
                                • Added an option for vertically offsetting text and symbols within the General tab of the Global Settings.
                                • Annotation text and symbols for doors, windows, garage doors, columns, Simpson Strong walls, and shear walls can be vertically offset a custom amount from the bottom of the wall.
                                http://design.medeek.com/resources/wallplugin/images/wall_su543_800.jpg
                                http://design.medeek.com/resources/wallplugin/images/wall_su544_800.jpg
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 2.1.5 - 06.06.2021
                                  • Updated the Medeek Estimator to include lumber/member lengths in both feet-inches (fractional) and decimal inches when using imperial units.
                                  • Further optimized and organized the Medeek Estimator code base in preparation for expansion of its functionality.
                                  http://design.medeek.com/resources/wallplugin/images/wall_su545_800.jpg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 2.1.6 - 06.07.2021
                                    • Enabled an option for a steel framing (Cold Formed Steel) texture for lumber/studs in the global settings.
                                    http://design.medeek.com/resources/wallplugin/images/wall_su547_800.jpg
                                    http://design.medeek.com/resources/wallplugin/images/wall_su546_800.jpg
                                    In the 2D mode the steel framed walls will appear a grey color as shown:
                                    http://design.medeek.com/resources/wallplugin/images/wall_su548_800.jpg
                                    I was about to dive into the estimating module this morning but I received yet another email regarding steel framing. This update only provides what I like to call a "cosmetic" steel framed wall. All I am really doing is applying some textures (and hiding one face) to the otherwise standard wood studs so that they resemble a steel stud. These are not proper steel framed walls in my opinion.
                                    This option in the Materials tab of the global settings is somewhat experimental and I am sure further improvements can be made so please send me any feedback, but realize that dimensionally these are not "real" steel framed walls. To take it to that level would probably involved creating an entirely new plugin devoted only to steel framing (CFS).
                                    Please see model here:
                                    3D Warehouse
                                    (3dwarehouse.sketchup.com)
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 2.1.6b - 06.08.2021
                                      • Steel framing indicated (by color) in 2D or 3D "No Framing" mode.
                                      • Enabled steel framing for gable, shed and hip walls.
                                      • Fixed a bug within the window edit menu regarding window presets.
                                      http://design.medeek.com/resources/wallplugin/images/wall_su549_800.jpg
                                      View model here:
                                      3D Warehouse
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 2.1.6c - 06.09.2021
                                        • Enabled boxed headers (2 ply) for windows, doors and garages by using the key word "BOX" in the header description.
                                        https://design.medeek.com/resources/wallplugin/images/wall_su550_800.jpg
                                        https://design.medeek.com/resources/wallplugin/images/wall_su551_800.jpg
                                        *Note that this type of header works for both wood and steel and one can create boxed headers within the custom header library in the global settings. The only stipulation is that the header must be a 2-ply header.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 2.1.6d - 06.09.2021
                                          • Fixed a minor bug with the custom beam and header libraries (status, edit and delete functions).
                                          This issue affected beams or headers that included brackets in the name, "(" or ")". This particular bug has been around for months but I guess no one noticed that you could not delete, edit or change the status of beams or headers with brackets in the name/description.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 2.1.7 - 06.11.2021
                                            • Enabled holdowns for portal framed garage door openings.
                                            http://design.medeek.com/resources/wallplugin/images2/wall_su553_800.jpg
                                            http://design.medeek.com/resources/wallplugin/images2/wall_su552_800.jpg
                                            View model here:
                                            3D Warehouse
                                            design.medeek.com
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 75
                                            • 76
                                            • 13 / 76
