    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      First look at some framed trapezoid window openings with sloped headers:
      https://aws1.discourse-cdn.com/sketchup/original/3X/d/7/d72c703f6796651e90096666945496ac4bec26cf.jpeg
      I've never seen a raised header with a sloped opening framed like this before but I guess it is a possibility:
      https://aws1.discourse-cdn.com/sketchup/original/3X/6/9/69eed509fd5b3ebbc30760d479595d08a95d372d.jpeg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Stacked openings with various raised headers and trapezoidal window openings:
        https://aws1.discourse-cdn.com/sketchup/original/3X/1/6/16315ccb409b8ccadc3f7645313e4fb2879022df.jpeg
        https://aws1.discourse-cdn.com/sketchup/original/3X/2/0/20a67ff4b4e6e24d05175106988f30acb519fd3a.jpeg
        I still haven't even gotten to the other wall types yet (ie. gable, shed and hip), one step at a time I guess.
        I now need to look at the insulation algorithm and then on to all of the window modules (ie. Trim, Casing and Installation). None of this is really all that difficult to code it just takes time to go through all of the various permutations and make sure nothing breaks down.
        If coded correctly, in other words the logic is efficient and modular, then not every case needs to be accounted for. The same module for the trapezoidal window trimmers and top cripples is used regardless if the windows are stacked or not. Unfortunately, things are not always this neat and tidy but that is my goal if I can achieve it.
        design.medeek.com
        • medeekM Offline
          medeek
          The insulation algorithm is now working correctly with trapezoid windows:
          https://aws1.discourse-cdn.com/sketchup/original/3X/d/3/d3357ebf5e140e9073b8fa50d7a052af7df0a1b7.jpeg
          design.medeek.com
          • medeekM Offline
            medeek
            First look at some trapezoid picture windows:
            https://aws1.discourse-cdn.com/sketchup/original/3X/c/1/c1a83b3c2208f34b2ae4dee2ca7c8dbf2e412528.jpeg
            design.medeek.com
            • medeekM Offline
              medeek
              Only the “perimeter” grille style needed modification for the trapezoid window:
              https://aws1.discourse-cdn.com/sketchup/original/3X/7/1/71878571072f5150e9818abaa57063b6c4375ca0.jpeg
              design.medeek.com
              • medeekM Offline
                medeek
                First look at exterior trim with trapezoid windows:
                https://aws1.discourse-cdn.com/sketchup/original/3X/8/8/8843f3ca150afc0747fa07550739d5ac5490a9d1.jpeg
                The good news is that the various window modules (eg. window installation, trim, casing etc...) are independent of the wall type so enabling trapezoid windows for the various gable wall types should now proceed relatively quickly.
                design.medeek.com
                • medeekM Offline
                  medeek
                  First look at interior casing with trapezoid windows (Style A, B, and C):
                  https://aws1.discourse-cdn.com/sketchup/original/3X/1/f/1fcc6862632b2972e43def21cd40715adce5a1b9.jpeg
                  https://aws1.discourse-cdn.com/sketchup/original/3X/6/6/6642a9dba5d1d78943c6a91496a42541958a2a0d.jpeg
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    First look at trapezoid windows within a gable wall:
                    https://aws1.discourse-cdn.com/sketchup/original/3X/e/5/e5d05eeb5b4eeecc9049a5433845618c8b90c28e.jpeg
                    https://aws1.discourse-cdn.com/sketchup/original/3X/e/7/e7e46f289d9e0fa679fd63db8b069ae7737d6e41.jpeg
                    Notice how the right most window has it's header pushed up against the top plate (no cripples or insulation installed). To achieve this one must adjust the header height until it is at the correct height since "Raised" headers are not currrently enabled for gable, shed or hip walls.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 2.0.6 - 04.29.2021
                      • Added trapezoid windows to the window draw and edit menus for all wall types: rectangular, gable, shed and hip.
                      http://design.medeek.com/resources/wallplugin/images/wall_su522_800.jpg
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 2.0.6b - 04.29.2021
                        • Added triangle windows to the window draw and edit menus for all wall types: rectangular, gable, shed and hip.
                        • Added the "Total Window Height" callout to the trapezoid window's section of the window draw and edit menus.
                        http://design.medeek.com/resources/wallplugin/images/wall_su524_800.jpg
                        http://design.medeek.com/resources/wallplugin/images/wall_su525_800.jpg
                        http://design.medeek.com/resources/wallplugin/images/wall_su526_800.jpg
                        http://design.medeek.com/resources/wallplugin/images/wall_su534_800.jpg
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          http://design.medeek.com/resources/wallplugin/images/wall_su523_800.jpg
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 2.0.6c - 04.30.2021
                            • Fixed a critical bug with the shutter module.
                            ******* CRITICAL FIX *******
                            If you downloaded and installed Version 2.0.6b then you will want to immediately uninstall and download Version 2.0.6c. The previous version introduced a minor bug to the shutter module which will causes errors with any windows that have shutters. Installation of Version 2.0.6c is highly recommended.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              I am very excited with the solid progress made on the Wall plugin these last few weeks and months, especially with the recent addition of both trapezoid and triangular windows. In light of the recent progress and in hopes of allowing more users access to the features of the plugins I will be immediately offering 40% off of the mdkBIM bundle price using the coupon codeMOTHERSDAY21. (May 1, 2021 thru May 10, 2021).
                              This will reduce the bundle price from $170.00 USD to $102.00 USD. This promo code does not apply to any of the extensions purchased separately or to the electrical plugin. The offer ends on May 10th and no rain checks will issued thereafter.
                              http://design.medeek.com/ads/MOTHERSDAY21_BANNER_800.jpg
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 2.0.7 - 05.01.2021
                                • Fixed a bug with the tee intersection gypsum cutout algorithm for shed walls.
                                http://design.medeek.com/resources/wallplugin/images/wall_su527_800.jpg
                                A similar fix will probably be required for gable and hips walls but I haven't dug into that section of the code just yet.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 2.0.7b - 05.01.2021
                                  • Fixed a bug with the tee intersection gypsum cutout algorithm for gable and hip walls.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Here is an interesting framing situation. You have two internal walls that tee into a wall which has a pocket door that bisects the tee:
                                    https://aws1.discourse-cdn.com/sketchup/original/3X/d/c/dc68eb13e7f0091900a65f5d36253a119f51a479.jpeg
                                    Overall no major problems the three walls can be configured correctly with "tee" intersections and the offset can be set to 1.75" for the two tee walls so that they meet properly at the top plate.
                                    The only issue is the that the gypsum backer studs are drawn full length and should be truncated at the header (hence the clash). The offending gypsum backer is colored red in the screenshot.
                                    The manual work around is to use the Trim Tool (Medeek Truss) and quickly trim the gypsum backers. I will have to examine this situation further and see if some additional logic can remedy this clash. This is not a huge deal breaker/ hot item in my opinion but it is a special framing case that needs a second look.
                                    The other obvious (simple) solution is to turn off the tee intersection backers in the global settings but this is really not a good option since it will disable the gypsum backers for all the walls in the model, not just this one.
                                    View model here:
                                    3D Warehouse
                                    (3dwarehouse.sketchup.com)
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      First look at "Pentagon" windows:
                                      https://aws1.discourse-cdn.com/sketchup/original/3X/6/b/6bd497e09085ab60b6274b9a2244ed99c2c79751.jpeg
                                      Note that if one sets the window height to zero you can also achieve an isosceles or equilateral triangle window (the degenerate cases).
                                      Since I'm fresh on windows right now I thought that it might be the opportune time to add in the pentagon picture window as well, one less monkey on my back. The only other significant window missing is probably the quarter circle.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Pentagon window with "Perimeter" style grill:
                                        https://aws1.discourse-cdn.com/sketchup/optimized/3X/f/3/f30fd874b1d23d5d273da5ff5336c9350284d5fd_2_690x396.jpeg
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          First look at exterior trim with a Pentagon window:
                                          https://aws1.discourse-cdn.com/sketchup/original/3X/1/5/15e5f9516ad9cf074bb0dab085c8aeb18bdd9c92.jpeg
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            First look at pentagon windows with the various casing options:
                                            https://aws1.discourse-cdn.com/sketchup/original/3X/8/f/8faa924f666154f3665db8c66c1fb89e6b7d80d2.jpeg
                                            design.medeek.com
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 75
                                            • 76
                                            • 46 / 76
